Caliber problem...
Discussion in 'Wheels & Tires' started by ccrider59, Aug 10, 2007.
  1. Aug 10, 2007 at 1:16 PM
    ccrider59
    ccrider59 [OP] New Member
    05 4x4 Tacoma Black
    So I went to get some black rims.. Nothing fancy..Just some black steel rims. When they mounted the tire the rims rubbed on the front brake calipers. Has anyone heard of this problem? Is there a solution with out having to drop some cash on upper end rims.
    Thanks,
    Calvin
  2. Aug 10, 2007 at 1:52 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    What year and configuration is your rig? You need to make sure you have the correct offset and backspacing (which for the life of me I can't recall). Toyota is funky that way.
  3. Aug 10, 2007 at 2:01 PM
    nceguystaco
    nceguystaco Well-Known Member
    yes i delt with this last month for a month with 4wheelparts to find out that even though tacoma has a stock 16 steel wheel when you go to a custome it has to be at least a 17" wheel when i did that problem was solved
  4. Aug 10, 2007 at 2:01 PM
    ccrider59
    05 4x4 Tacoma Black
    its a 2005 sr5, 4x4 extra cab v6. i went to discount tires and they ordered what their computer system told them to. they said that due to the oversized caliper it was causing a rub issue.
    thanks for your input,
    calvin
