Calibrate speedometer?
Discussion in 'Wheels & Tires' started by Tbryson2, May 31, 2014.
  1. May 31, 2014 at 8:04 PM
    Tbryson2
    Tbryson2 [OP] Well-Known Member
    Terry
    Central Florida
    05 PreRunner SR5
    Recently purchased a Tacoma that has aluminum rims / bigger tires than stock. My speedometer is about 3 - 5 mph slower than my GPS shows current speed.
    Is there a way to calibrate the speedometer based on different (non-stock) wheels/tires?
    Terry
  2. May 31, 2014 at 8:09 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Tacomas run 5mph slow on the speedometer compared to a gps, but the odometer is pretty accurate. The 2.7L 4wd has a gear in the x-fer case that can adjust readings by swapping in a different tooth count. I think the 4.0 transmissions come off the abs sensors. There is a add on electronic box that might do what you need. I don't recall the make.
    Jet or hyper tech make calibrators, no idea how good they may be though
  3. May 31, 2014 at 8:49 PM
    Tbryson2
    Terry
    Central Florida
    05 PreRunner SR5
    I figured it would be something like that. Not so important I have to spend money on!
  4. May 31, 2014 at 8:52 PM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Dakota digital makes one as well treating me well with my 35's
  5. Jun 1, 2014 at 5:24 PM
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
    You didn't mention what size you're running. I went from 265/70-16 to 265/75-16's and now my speedo matches exactly to my GPS...
  6. Jun 2, 2014 at 5:04 PM
    Tbryson2
    Terry
    Central Florida
    05 PreRunner SR5
    I guess that would be good to share. :D
    P275/55/R18
