Calibrating Overhead Compass - How Many Turns with Truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tunngavik, May 15, 2011.
  1. May 15, 2011 at 6:45 PM
    Tunngavik
    Tunngavik [OP] Well-Known Member
    Alberta, Canada
    2010 Access Cab SR5 4x4 5 speed 2.7l
    Fog lights with OEM switch - Heated mirrors with OEM style switch - Cab sound deadening - Lighted 4x4 switch - URD short shifter - Rear backup camera - 2012 rear view mirror (compass, outdoor temperature and backup video mirror) - Heated seats - 2014 Tacoma stereo install - Bluetooth with OEM steering wheel controls, Access roll-up tonneau cover
    I'm trying to recalibrate my overhead compass and have followed the owners manual to a T.
    1. Program in correct declination
    2. Have display on CAL and drive slowly in a counterclockwise circle in an open parking lot (i.e. no nearby buildings, no powerlines etc).
    It won't go off the CAL setting. I've done this twice - one time making 13 circles and still nothing. I'm worried if I do it any more someone is going to call the cops on me for weird behavior. I've programmed a family members GMC truck and Nissan X-Terra so I've done thing before with other makes/models.
    How many times do you have to turn in a circle to calibrate this thing? If anyone can provide some helpful feedback it would be greatly appreciated.
  2. May 15, 2011 at 6:50 PM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    What are the exact instructions? Could you type em out here for posterity or take a pic even? I have the compass. I set the correct declination then just pressed the button to get out of programming mode, but might not have been right (tho seems to be working 100%).
    There is also a VAR setting and CAL setting and I'm not sure which is which.
  3. May 16, 2011 at 9:23 AM
    Tunngavik
    Alberta, Canada
    1. stop vehicle where it is safe to drive in a circle
    2. press overhead console switch until VAR appears on display
    3. press switch until your declination code is complete - if the direction is displayed several seconds after adjustment then calibration is complete
    4. if not complete, press the switch until CAL appears on the display - at this time compass direction is locked at N
    5. Drive vehicle in a circle at 8kph until direction is displayed
    6. when CAL goes off and the compass display returns to normal mode then calibration is complete
  4. May 16, 2011 at 10:01 AM
    vtdog
    vtdog Well-Known Member
    I used the instructions in the owners manual and it set after 1 circle. The compass was set to TX (where built) and showed a noticable change in ordinal points after the re-set
  5. May 16, 2011 at 10:06 PM
    anethema
    J
    Dawson Creek,BC
    Awesome thanks for the info!
