Calibrating Speedo
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fruitaboy, Dec 21, 2011.
  1. Dec 21, 2011 at 8:26 AM
    fruitaboy
    fruitaboy [OP] Member
    TRD
    I am looking at replacing my stock tires and wheels. I would like to put 265/75/16's on, but I would like to keep my speedo accurate! I talked with the toyota shop and they told me toyota does not have the capabilities to re-cal the speedo. Does anyone kwow of another way to keep my speedo accurate??
  2. Dec 21, 2011 at 8:28 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    It's spendy, but the hypertech speedometer calibrator works.
    but just going to 265/75R16 - that's a pretty small change - I'd try it first before I went off and changed anything.
  3. Dec 21, 2011 at 8:29 AM
    Aw9d
    Aw9d That one guy
    Az
    Not sure if you can do it on the toyota's or not.. I had my 95 acura done at a local shop when I adjusted my rim's and what not.
    Really, best thing to do is fine one of those photo radar speed things, fly by it at 50 and see what it pegs you at.. you shouldn't be off that much from wheels and tires.
  4. Dec 21, 2011 at 8:31 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    What model truck do you drive?
    I found that the 2009 TRD Sport that I had was +3mph by default. Now that I put the 265 Duratracs on my spedo reads dead on. You should be fine without any calibration. It should actually fix your overzealous stock speedo.
  5. Dec 21, 2011 at 8:31 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Beat me to it.
  6. Dec 21, 2011 at 9:06 AM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    Try comparing to GPS. You might find the speedometer reports you traveling faster than you actually are (which is a good thing).
    Most cars are off a bit but know how much could keep you out of trouble.
    Welcome to toyotaworld.
  7. Dec 21, 2011 at 9:24 AM
    Bloodhound
    Bloodhound Space For Rent
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    That's what I was gonna say. Or if you don't have access to one, try to find a cop and ask him if he would radar your truck, around here they will and tell you your speed without a problem.
  8. Dec 21, 2011 at 9:37 AM
    rhavin42
    rhavin42 Well-Known Member
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    Exact same scenario for me. Stock 265/65/17 spedo was +3-5 MPH went to 265/70/17 spedo is DEAD on with gps. However the odometer is now off by ~3%, which coincidentally is the same difference in tire size 265/70 is ~3% larger than 265/65
  9. Dec 22, 2011 at 8:25 AM
    LMR
    LMR GO JETS GO
    Lee
    In The True North
    2008 Tacoma DCSB TRD
    Shorty antenna, Weathertech digital fit, tonneau cover
    I noticed it too on a recent trip. Compared it with my GPS and I was 4-5 MPH off.
  10. Dec 22, 2011 at 8:26 AM
    Brunes
    Brunes abides.
    Rotorhead
    How was the distance traveled compared to the ODO??
  11. Dec 22, 2011 at 8:29 AM
    LMR
    LMR GO JETS GO
    Lee
    In The True North
    It seemed fairly accurate but my GPS is in Kilometers and the truck is in miles so my calculations may be a bit off.
  12. Dec 22, 2011 at 8:44 AM
    fruitaboy
    TRD
    Thank you all, I sure appreciate the info!!
  13. Dec 22, 2011 at 4:19 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    To add one more confirm (and we have been saying this for years): 265/75-16 will make your speedometer become accurate finally! It reads too fast with the factory tires.
  14. Dec 23, 2011 at 10:19 AM
    rhavin42
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    for me was about 3% off. so when the ODO said i traveled 100 miles i really traveled 103 miles
  15. Dec 23, 2011 at 3:57 PM
    bigtex2884
    bigtex2884 Well-Known Member
    Austin, Texas
    08 prerunner
    Retro Projectors, tinted tails, nfab nerf bars, avhp4000dvd, kicker 700.5, 2 8" comps, full components front and back, scangague 2, HID Fogs, Muth Mirrors, 5100s front, 90000s rear. Maxtrac spindles, all pro expo pack, level 8 tracker 16" x 8 1/2
    So since everyone is aware stock tires read faster than you are actually going wouldnt that cause your mileage to be more than you really traveled and if that's the case wouldn't this effect your warranty coverage. Haha just a thought
    Truck says you've hit 40k
    You've really only gone 38,800k
  16. Dec 23, 2011 at 4:00 PM
    bigtex2884
    Austin, Texas
    08 prerunner
    Also effect resale value haha
  17. Dec 23, 2011 at 4:07 PM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    Thats why I didn't recalibrate with larger tires. really going more miles than truck says
