Calibrating the overhead outside temperature gage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hillbillynwv, Oct 5, 2009.
  1. Oct 5, 2009 at 8:02 AM
    hillbillynwv
    hillbillynwv [OP] Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    My overhead outside temperature gage reads 2 degrees higher than what it really is outside. I've compared it to radio stations giving the temperature, my desktop weather channel temperature, and bank signs and it is exactly 2 degrees higher. Is there anyway to calibrate it to make it correct?
  2. Oct 5, 2009 at 8:12 AM
    nasty ned
    nasty ned Well-Known Member
    mass
    05v6trd access
    nerf bars ventvisor kit nose & windows
    subtract 2.o degrees when viewing
  3. Oct 5, 2009 at 8:13 AM
    testedone
    testedone Speak English..it's America
    Rick
    U.S.A.
    2010 Tacoma TRD Sport
    Weathertec Mats, Pioneer AVIC-X930BT, Pioneer GEX-P920XM (SAT), Pioneer Premier TS-D602P 6.2, Blaupunkt THb 200A Sub, Trimmed Mud Flaps, BF Goodrich AT/KO 285/70/17 ... Toytec Ultimate Lift, Tuffy Bed Box, A.R.E. Cover, Pop-n-Lock, TRD Exhaust
    That's Nasty...Ned... :)
  4. Oct 5, 2009 at 8:24 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Epic.
    Honestly if you're within 2 degrees you're better than most. Remember the sensor is reading it from in the truck, it will be skewed. To the best of my knowledge you can not calibrate it.
  5. Oct 5, 2009 at 8:55 AM
    viperstd
    viperstd Tacoma convert
    Maryland
    09 4x4 TRD SR5 DC LB
    AllPro Front and Rear trail armor & full skid plates, Demello Hybrid Rock Crushers, Old Man Emu suspension, Warn 8000# winch, PIAA SMR fogs, perforated + heated leather seats, in-dash DVD/NAV/Sound, RE subs
    install a potentiometer and turn the dial until the temperature reads correctly, measure the resistance, and then install a resistor of that value (or closest match).
