Calif. Tacos:Are CAIs not street Legal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomtn, Jul 6, 2011.
  1. Jul 6, 2011 at 6:23 PM
    Grande
    Grande Well-Known Member
    Victorville, CA
    Thomas, The little truck that could
    Painted badges. Bedlined grille, wheels and lower valence. Billies 5100 @.85 up front. Dodger Jack Ball Mod. Custom trail damaged rear bumper (for the time being). Lil LED light bar on grill. Hard-wired Radar Det. Custom Projector fog lights, Anytime Fog Mod, HIDS, White LED accent lighting on a Single post double toggle swicht, so they light up wit my door/dome light, or always on, or never on. LED map and dome lights.
    it might of "help guide" air in, might be about it, atleast for my old car lol. and the pic is off google, ima chevy dude when it comes to muscle
    :stayontopic:
    forced induction is the next step, ram air is like a pusy forced induction, only really see the best Ram at higher speed since the air eventually would get forced in instead of sucked in, then of course u gotta hav actual hood scoops, or if ur an OG, u would run hoodless :cool:
  2. Jul 6, 2011 at 6:24 PM
    tacomtn
    tacomtn [OP] Well-Known Member
    TRD OR,OME,Deaver AAL
    wow, i posted this a couple of hours ago and wham-o... a bunch of replies.
    yeah, i was wondering if any of these CAIs have real dyno test results to back up their claims. same with aftermarket exhausts. these companies make them for so many applications. i kinda doubt they've taken each exhaust and CAI and dyno'd all the cars they make them for.
    so besides that problem, they're not street legal. kinda a hassle to take off/on for smog checks too...and for something that does not improve performance or worse yet, decrease performance since some of them do not seal out hot engine bay air but in fact, may increase the vacuum thereby sucking more hot air in than a stock intake.
    i'll pass and save my money for more important mods like the lift and wheels.
  3. Jul 6, 2011 at 6:26 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  4. Jul 6, 2011 at 7:41 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Not true. The newer TRD CAI is CARB legal. I believe there is a Volant CAI that is also CARB legal.
  5. Jul 6, 2011 at 7:51 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    the most important thing isnt the "intake" itself, its the filter!! So the CAI isnt exactly what you wanna replace, u wanna replace that shit ass paper air filter u have that does nothing but restrict air!!!! If you want an actually, very small, HP gain and a few more mpgs then just get a drop-in-filter! They ARE smog legal and a good one is only about $40, problem solved!!!!!
  6. Jul 6, 2011 at 7:53 PM
    tacomtn
    yeah, gnarly.
    how's the wheelin in chino hills area? or do you head south to san diego?
  7. Jul 7, 2011 at 6:13 AM
    Evil Monkey
    Robert
    Escondido, CA
    Each vehicle and each engine type has to have it's own CARB legal authorization. So a 2nd Gen Tacoma may have different CAIs that are legal for 4cyldr vs 6 cyldr. For a long time the Tundra had a CARB legal CAI while the 2nd gen Tacoma had none.
  8. Aug 20, 2012 at 9:30 AM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    So I've browsed this thread and did some minor searching. But, my Tacoma is due for it's first smog check this year. I have a drop in K&N filter. Will this be a problem when getting it smogged? It's been a while since I've had a smog check done and I'm not sure, do they do a visual and inspect the filter? No stickers or anything else that would make it look aftermarket without actually looking at the filter. And I'd guess tail pipe emissions wouldn't be much more either, but wanted to verify from anyone who has smogged their V6's with the drop in K&N!
    Thanks!
  9. Aug 20, 2012 at 9:57 AM
    Evil Monkey
    Robert
    Escondido, CA
    If it's just a filter, you should have no problem. The only way they could tell is to take parts off to look at it, which they won't do. It's usually only the CAIs that fail. The CAIs fail the visual inspection portion of the check if they don't have a CARB sticker on them.
  10. Aug 20, 2012 at 10:06 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    there isnt much in CA that is allowed to be put on your vehicle other than stock replacement parts with out it being illegal. Its more a question of will you get caught and what cna you get away with unfortunately
  11. Oct 16, 2012 at 10:39 AM
    Tillers_Rule
    Jeff
    San Diego
    4x4 Sport, debadged
    Had the smog check today, 0.0's across the board (11 on NO, with a max allowable of 508), with the K&N drop in:cool:
