California catalytic converters
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kdsyoder, Apr 11, 2022.
  1. Apr 11, 2022 at 9:12 PM
    Kdsyoder
    Kdsyoder [OP] Member
    2001 Toyota Tacoma 4X4 2.7 liter 4 clyinder Californi emisuonsa
    Help :). 2001 Tacoma 2.7 4wd
    I have replaced both cats once. At 370000 miles, cats no longer necessary. No DEQ reqd. What year "brain" can I replace mine with so truck will start?
    C'mon Tacoma World, help a disabled vet out.
  2. Apr 11, 2022 at 9:24 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  3. Apr 11, 2022 at 9:33 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    So many independent thoughts at once....can you make them more dependent?
  4. Apr 11, 2022 at 10:01 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    My 99’ has 1 cat, and I don’t think has a sensor in it or after it
  5. Apr 11, 2022 at 10:22 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Trying to decode this. Not sure what DEQ is but it sounds like you want to remove the CATs and want to verify the truck will still run afterward.
    If that is it, yeah, it'll run. It'll be obnoxiously loud, but it'll run.
    There is a downstream sensor (after the CAT) but it only tells the ECU how well (or not) the CATs are functioning. It does not have anything to do with engine tuning or performance.
  6. Apr 12, 2022 at 3:47 PM
    Kdsyoder
  7. Apr 12, 2022 at 3:49 PM
    Kdsyoder
    Thank you sir. Is your '99 a 2.7 4cylinder? Then that is control module/brain I will get at a wrecking yard.
  8. Apr 12, 2022 at 3:50 PM
    Kdsyoder
    Well, 2nd sensor tells computer it's too lean, feed more gas. My mileage down to 14mpg.
  9. Apr 12, 2022 at 3:51 PM
    Kdsyoder
  10. Apr 12, 2022 at 4:01 PM
    Kdsyoder
    DEQ is a emission test
    No catalytic converters/O2;sensors No Engine Start. Does that narrow independent thought Sir?
  11. Apr 12, 2022 at 4:09 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Ok... plug the upstream O2 sensor into an exhaust-rich chamber (like the pre-cat pipe where it came from). The upstream tells your ECU how much fuel to inject.
    Do note that without both it will error after a few minutes, then log bad data, then stop auto-correcting fuel. So over time you'll probably develop drivability problems.
    If you hate cats that bad, I would at least put a straight pipe in. You'll have CELs any way, but at least it'll run properly.
    I have no clue from what you've provided why it won't start though...unless you just went hacking and killed something else in the process
  12. Apr 12, 2022 at 4:21 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This is not correct. The sensor after the CATs does nothing related to engine management. Your bad MPGs are unrelated to not having any downstream sensor data.
  13. Apr 12, 2022 at 4:23 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Not sure what the thought process is here?
    The truck will run just fine with no converters, you will just have a P0420 (catalyst efficiency) code.
    If the truck isn't starting it's not because the converters or O2 sensors are missing (O2 sensors arent even used at startup until the exhaust is up to temp).
    Now if the converter is plugged it can cause a no-start but not the lack of one being there.
    b_r_o likes this.
  14. Apr 12, 2022 at 4:24 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    It sounds like he took them both out. Which means it reverts to open loop, which is notoriously rich.
  15. Apr 12, 2022 at 4:30 PM
    Kdsyoder
    It has front cat. Rear cat hollow, spoof wired in to offset no rear converter. I want exhaust pipe, muffler and tail pipe. That's it.
    I'm told that if cats/O2 sensors unplugged, the truck won't run.
    That's why I'm looking at earlier brain/module for 2200RE 4cylinder. Is it necessary? Or can I just hollow front cat and un hook O2 sensors?
  16. Apr 12, 2022 at 4:33 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    A different ECU isn't gona change anything, they all have catalyst monitoring since 96.
    Leave the sensors hooked up at most you will have a P0420 and engine light on.
    Why are you wanting to gut the converters anyway are they plugged?
    treyus30 likes this.
  17. Apr 12, 2022 at 4:39 PM
    Kdsyoder
    Rear cat hollowed out. I replaced both years ago, too expensive to do again. Don't live in California or a state that requires DEQ. So then I need a 1995 ECU?
  18. Apr 12, 2022 at 4:50 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    A 95 ECU will not run a 2001 truck(engine management and wiring is different), there's little to no performance or economy benefit to gutting them but you can run the truck with no issues other than a check engine light.
    If you don't want the light on look into O2 simulators.
  19. Apr 12, 2022 at 4:52 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    I don't see how you can afford these bandaid mods but not pay $100 for a cat (or two)
  20. Apr 12, 2022 at 4:59 PM
    Kdsyoder
    $1500 for cat replacement first time bro. Never again. Spoof works thanks for your input Sir
