California emissions on a 2000 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by HelenaTDI, Feb 4, 2016.
  1. Feb 4, 2016 at 1:36 PM
    HelenaTDI
    HelenaTDI [OP] Well-Known Member
    Montana
    2000 Tacoma TRD
    I've got a 2000 Tacoma, 5spd, 4x4 with 109k miles. Just picked it up last year in December. Threw a P0420 last week. I understand it can be caused by other issues besides the CATS or o2 sensors. My original plan before this happened was deleting the 2nd CAT and installing a URD o2 simulator. Would this cure any future P0420's providing my o2 sensors, fuel pressure , Maf, clean throttle body, etc... is all good? I see if I buy any future o2 sensors it has to be the specific ones for Cali. Also would like to install a high flow primary CAT and a flow master exhaust. Just curious with the non OEM high flow CAT, o2 simulator and aftermarket exhaust that I wouldn't continue to throw codes and if the ECU wouldn't freak out since it's not up to Cali standards. I live in Montana so no emission testing here. Pisses me off this is a California rig with 2 cats. No point of it here so it's gonna be one dead cat real soon.
  2. Feb 4, 2016 at 2:23 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I have the California Emission Package in Pa.
    I just fix things as needed
  3. Feb 4, 2016 at 3:04 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    good thing mine is only fed, non cali sht. 1 cat ftw. hell, if there is no emission stuff delete both the cats and install 02 simulator.
  4. Feb 4, 2016 at 5:01 PM
    HelenaTDI
    Montana
    2000 Tacoma TRD
    Yeah I'd imagine as long as both o2 sensors front and rear work shouldn't matter if no cats. However high flow magnaflows aren't too expensive and I'd be legal with the Feds.
  5. Feb 4, 2016 at 6:43 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    yes, so long as everything else is working fine, this will solve your issue up to the point that the wiring is still in good condition. most likely.
    problem with not correcting the issue in cali to begin with is that when you go to get your truck smogged, they WILL look and make sure everything is in their proper place and working correctly. either that or during the test they will see that the o2 readings and their exhaust testing equipment aren't matching and investigate if not call the authorities.
    so even if you do go with this, youll have to buy enough parts to get a working setup going for when you want to smog. plus buy all those accessories and replace the components when you want to run without a cat. youre better off just finding and repairing the issue. and honestly, its probably something little like an exhaust leak.
  6. Feb 4, 2016 at 6:52 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    He doesn't live in California.
    California emissions are.. not the problem.
  7. Feb 4, 2016 at 6:54 PM
    CodeSeven
    Serge.
    Coachella Valley
    huh.... guess i read all the way up to the final sentence and didn't bother.... nevermind :anonymous:
  8. Feb 5, 2016 at 6:10 AM
    HelenaTDI
    Montana
    2000 Tacoma TRD
    So in nutshell if I install the o2 simulator I can do whatever the hell I want with cats then? Correct?
  9. Feb 5, 2016 at 10:12 PM
    00yotasr5
    lee
    merced, ca
    pretty much since you don't have emission. that what I did when I live in Minnesota, took out all the cats and installed o2 simulators (turbo ftw).
  10. Feb 6, 2016 at 8:35 AM
    HelenaTDI
    Montana
    2000 Tacoma TRD
    Works for me. However I will still have one cat a high flow type to be legal fed wise. Like the sound of them flow master 40's for a muffler. Just glad I don't live in California and have to deal with emissions
