California emissions
Discussion in 'New Members' started by Kdsyoder, Mar 23, 2022.
  1. Mar 23, 2022 at 9:41 AM
    Kdsyoder
    Kdsyoder [OP] Member
    2001 Toyota Tacoma 4X4 2.7 liter 4 clyinder Californi emisuonsa
    I am removing both catalytic converters, replacing with pipe. I'm a retired UA Steamfitter local26. She has 388,000 miles on her. Don't have to go through DEQ. It wants to breathe. I have been told a earlier brain module for 2.7L 4 cylinder will allow her to start. Please help?
    I have replaced both cat's once. I will not afford them again. Truck isn't worth that $$$$. Again, help Tacoma brothers!
  2. Mar 23, 2022 at 9:45 AM
    Tacko21
    Tacko21 Well-Known Member
    find a shop iyk
  3. Mar 23, 2022 at 9:48 AM
    Kdsyoder
    LMFAO! That's not helpful take
  4. Mar 23, 2022 at 9:50 AM
    Tacko21
    yet useful but on a real note a helpful take is to move out of California unfortunately but also to just put a cat back on
  5. Mar 23, 2022 at 9:56 AM
    eon_blue
    Azusa, CA
    It should still run without cats. It will throw a P0420 code/check engine light, sound awful and smell like crap...but that's another matter.
    URD used to sell o2 simulators that would trick the ECU into thinking the o2 sensor is satisfied by the catalyst so you don't get any codes. But they pulled it off their website a year or two ago.
    I've heard there's some way you can use spark plug foulers to do the same thing but I'm not familiar with it, someone on here probably is.
  6. Mar 23, 2022 at 10:07 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    What @eon_blue said with the exception of clogged cats not just cats operating below minimum efficiency.
    If the cats aren't clogged mounting the downstream sensor (BIS2) In a spark plug extension threaded into a universal threaded type O2 flange keeps the P0420 code from tripping the CEL.
    buckhuntin-tacoma likes this.
  7. Mar 23, 2022 at 10:08 AM
    Black DOG Lila
    Virginia
    OP said no DEQ= no emissions test.
  8. Mar 23, 2022 at 10:12 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Edited
    I just saw someone said it doesn’t need to pass emissions. In that case just make sure you leave the o2 sensors where they need to be and ignore the check engine light on the dash it will still run fine.
  9. Mar 23, 2022 at 10:20 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
