California smog woes
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4x4 billy bob, Aug 15, 2016.
  1. Aug 15, 2016 at 7:02 PM
    4x4 billy bob
    4x4 billy bob [OP] New Member
    1996 Tacoma 4x4 dlx
    bilstien shocks add on cruse control 8 ohm speakers an CD player
    I've got a 96 Tacoma an there's a smog valve on driver side under hood that always buzzes when engine is off mine doesn't make that noise any more does anyone know if there's a relay or a trouble tree to check this system out.
  2. Aug 15, 2016 at 11:50 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Download the pdf repair manual and look through the emission chapter. It sounds like you are talking about the evaporative emission system. The charcoal canister accumulates gas vapors from the gas tank, then releases them into the engine when the engine is running.
    Is your check engine light (CEL) on? Did you already fail the smog test?
  3. Aug 17, 2016 at 12:47 AM
    4x4 billy bob
    1996 Tacoma 4x4 dlx
    No lites I just noticed it wasn't cycling like it did the last 20 years I thought it might have a relay probably the selinod I'll check to see its got power, it's always passed emission tests
