Caliper pins grease or not?
Discussion in '1st Gen. Tacomas (1995-2004)' started by pontoon, Jun 30, 2022.
  1. Jun 30, 2022 at 1:09 PM
    pontoon
    pontoon [OP] Well-Known Member
    2000 Tacoma SR5 TRD V6 3.4 5MT
    Hi all,
    I did my brakes the other day and followed the FSM. The FSM indicates where to grease with arrows. From what I recall seeing the FSM did not have arrows pointing to the slide pins. Is the FSM indicating that the slide pins should not be greased?
    In the past I used silicone grease on the slide pins. I have had issues with my brakes sticking and I’ve seen notching in the slide pins. Idk if the grease was causing problems or what.
    I am in California so we don’t have major issues with rust.
    So yeah, right now my slide pins are not greased. Should I go grease them?
  2. Jun 30, 2022 at 1:12 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
  3. Jun 30, 2022 at 2:21 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Yup- put some grease on them. Not silicone though- use caliper grease.
    NAAC3TACO likes this.
  4. Jun 30, 2022 at 2:24 PM
    pontoon
    Thanks I’ll grease them. I was thinking about using sil glyde which is advertised as good for slide pins.
  5. Jun 30, 2022 at 2:26 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    If it's the sil glyde specifically made for brake parts, sure. Otherwise, just stick to a grease to designed for brake parts.
    VTCAL likes this.
  6. Jun 30, 2022 at 7:14 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I do, but I find it’s just as important to make sure true pins are CLEAN. I use a wire wheel or scotch-brite pad.
    Anymore, I just order new pins with the pads. Along with retaining clips.
    t0p_d0g, wi_taco and Chungas like this.
  7. Jun 30, 2022 at 7:16 PM
    Chungas
    Chungas Help! My Ferret has lost its stank!
    Waylon
    Bushwood CC
    Cocain 2003 3.4 4x4
    And they are dirt cheap. Or at least they used to be.
    t0p_d0g and TnShooter[QUOTED] like this.
  8. Jun 30, 2022 at 7:22 PM
    TnShooter
    Deogee
    STOCK
    The last set I bought came with them. But then again, I bought a whole package deal.
    Front and back
  9. Jun 30, 2022 at 8:19 PM
    pontoon
    Same, I’m working with all new OEM parts including pins and clips. Learned my lesson not to use aftermarket (centrik) garbage
  10. Aug 28, 2025 at 5:12 PM
    pinktaco808
    pinktaco808 Hot Steppa
    Where the how to and is it easy
  11. Aug 28, 2025 at 5:35 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    I always brush on a thin coating of never seize.
  12. Aug 28, 2025 at 6:40 PM
    t0p_d0g
    t0p_d0g My Tacoma is my happy place
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I agree with everyone else, clean and grease them with caliper grease.
  13. Aug 28, 2025 at 6:55 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    The issue always seems to be tapping out the original pins for the 1 st time. It's easy to peen over the ends and they won't push out at that time.
    If you get the originals out, grease them!
    pinktaco808 and Bishop84 like this.
  14. Aug 28, 2025 at 6:56 PM
    Bishop84
    Bishop84 Well-Known Member
    Big trick I do professionally is spray, whack in, spray whack out. Work the penetrating fluid.
    So many people on here seem to think spraying fluid makes things come loose. It's not magic, but it works well with movement.
    pinktaco808 and koditten[QUOTED] like this.
  15. Aug 28, 2025 at 7:04 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Skip the grease, all it does is give dirt something to stick to. A few drives in the rain and it washes off anyway
    Just wire brush them so they're clean
    You'll notice they don't grease those retainer pins at the factory, and factory brakes last 60k miles
    In my opinion grease only goes on sliders that are protected from the elements by a rubber boot. Like slider pins on a floating caliper
    skeezix and pinktaco808 like this.
