Caliper problems 2004 Double Cab
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tucker771, Apr 27, 2015.
  1. Apr 27, 2015 at 2:13 PM
    Tucker771
    Tucker771 [OP] Tacoma Beast
    Tucker
    Raleigh, NC
    2004 Tacoma Doublecab 4x4 TRD
    Gray wire mod, 4" coil lift, 2" block lift+2" AAL, rear air bags, re-located trailer wiring plugs, trail gear front bumper, kicker sound w/pioneer in-dash, 8" kicker sub, airaid MIT kit, trail gear rock sliders, arrow antenna, blacked out grille, HID kit, Smittybilt 8k winch, extended brake lines, LED overhead lighting, LED turn signals, Explorer Rock Lights, removable doors, Re-wired 4x4, Roof Rack
    Alright Yall so I've been having some issues with my brakes. All out of the blue they started squeaking roughly a week ago. Today I went and picked up that goo that you put on the back of the pads to keep them from squeaking.
    Good news: no more squeak :D
    Bad news: my upper left caliper piston would not compress when I tried to compress it to remove the brake pads. All the other 3 moved with slight force but nothing abnormal. The 4th one would not compress no matter how hard I tried squeezing it. I know I probably have to change the caliper but I'm hoping someone has some suggestions as to other causes. Also, since putting everything back together, my brake pedal has been a bit spongy. Still stops fine but the pedal requires more pressure than usual.
  2. Apr 27, 2015 at 4:07 PM
    Tucker771
    Tucker
    Raleigh, NC
