Caliper rebuild, painting, and rotor upgrade
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 68vert, May 7, 2012.
  1. May 7, 2012 at 8:45 PM
    68vert
    68vert [OP] Well-Known Member
    AZ
    DCSB 4X
    I bought a set of calipers off feebay to tear down, paint, and rebuild with new parts. Thought I would document it, even though it might take a few months to buy all the parts.
    Heres the calipers as shipped. A little bit of rust since they are from the midwest, but nothing too horrible.
    first off I started by pulling the safety clips out, and removing the rods that the pads slide on
    This allows for removal of the anti-rattle clip, pads, and the pad backing plates
    Use an air hose to blow the pistons out of the caliper. They will most likely come out 1 at a time. Thats ok. Remove the boot and seal re-insert the piston back into the caliper to free other pistions. I used blocks of wood to hold the pistons in that already have seals removed. This forces the remaining pistons that still has the seals in to be forced out by the air pressure.
  2. May 7, 2012 at 10:35 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Were the inboard pistons seized? If not, you should be able to reuse them, along with everything else exept for a seal kit. Good luck. :)
  3. Jun 9, 2012 at 7:52 AM
    68vert
    AZ
    DCSB 4X
    New drilled and slotted rotors came in. They look really nice. Sanded the front of the calipers to remove some of that rough casting finish. They are masked, cleaned, and ready for caliper paint.
  4. Jun 9, 2012 at 11:01 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2007 AC TRD OFFROAD
    Send them to a powdercoater if you have one close. they will look nicer and last longer than any paint IMO.
  5. Jun 10, 2012 at 8:22 AM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails WANT: Rear Plate Bumper, RokBlokz mud flaps, Steel bed cage
    Subbed, looks like a fun project! Question: What color are you painting them?
  6. Feb 2, 2013 at 4:50 AM
    hotrod45
    hotrod45 Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    i'm doing mine in chevy orange.
  7. Feb 3, 2013 at 9:55 AM
    68vert
    AZ
    DCSB 4X
    f I was to do it again. I'd paint it a brighter color also. I did mine black because I wanted a low key look but they are barely noticeable behind the stock wheels.
  8. Feb 3, 2013 at 10:00 AM
    68vert
    AZ
    DCSB 4X
    I put on Goodridge SS braided lines while I was at it. Ended up cross threading the last line. Luckily Ace had a tap and die even though I had to go to couple different locations. The size is M10 X 1.0 just FYI. Plus getting the air bled outta the ABS system was a royal PITA.
  9. Feb 6, 2013 at 7:33 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Phoenix / Payson, AZ
    98 Tacoma Limited
    Deck Plate, '17 rims, Tundra Brake Upgrade, All-Pro Expo Leaf Packs, 01-04 Center Console, Ultragauge, LED interior lights, HO alternator...
    Sub'd
    I am in the process of sanding down the calipers right now. Picked up the the rebuild kit from the dealership yesterday. Still have a few hours of work of sanding before I am ready to paint.
  10. Feb 6, 2013 at 7:34 AM
    Large
    Large Red
    Damn good job so far..
  11. Feb 6, 2013 at 7:40 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Bleeding can be a PITA but I just cracked the bleeders slightly, filled the reservior and let gravity do it's thing. I let them sit for a good 20 - 30 minutes then did the normal bleeding procedure. For the most part, they were ready to go, they bled on the first pump of the brakes (I still pushed some fluid through just in case).
  12. Feb 6, 2013 at 7:42 AM
    Chipskip
    Chipskip N7MCS
    Chip
    98 Tacoma Limited
    I see this being added to the How To/DIY sticky thread.
  13. Nov 17, 2013 at 5:03 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    anyone have part #'s for the rebuild kit?
  14. Nov 17, 2013 at 5:54 PM
    DoorDing
    DoorDing The game is afoot.
    Sussex Downs
    Hansom cab
    OP, looks good. Glad you were able to work your way out of the cross-threading. FWIW, I use a Vacula vacuum bleeder and have been very happy with it.
    G2's two-part paint holds up very well, much better than other brake paints I've used. I'll bet it'll be fine, especially with such a good prep job.
  15. May 3, 2014 at 12:38 PM
    rogerkamp8817
    rogerkamp8817 Well-Known Member
    Huntington Beach, CA
    2010 Toyota TRD Off-Road 4x4, AC, Superwhite
    How tight do you torque the 15 mm and 17 mm bolts that hold the caliper together? (ignoring the middle hole and the bottom left hole)
    I'm referring to the holes that are masked off in this picture:
  16. May 3, 2014 at 3:37 PM
    DoorDing
    Sussex Downs
    Hansom cab
    ^ Hmmm ... not finding those bolts listed in the FSR. Seems odd. I'll look some more.
  17. May 3, 2014 at 3:41 PM
    rogerkamp8817
    I checked the repair manual I have and didn't find it in their either. Hopefully it's listed somewhere else.
    They were relatively easy to turn, so I snugged them up a little bit.
