caliper
Discussion in '4 Cylinder' started by george3, May 15, 2021.
  1. May 15, 2021 at 2:23 PM
    george3
    george3 [OP] Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Just put a new caliper on from NAPA - looked good so I checked the web site - impressive.
    • NAPA Total Eclipse Calipers offer an exclusive black weather-proof coating that stops rust from forming, maintaining a showroom appearance.
    • New stainless steel hardware clips and new mounting pins are included where applicable.
    • Rubber seals are replaced with new high temperature EPDM rubber for extended life and optimum performance.
    • Pistons are durable, resistant to cracking or pitting and handle great loads.
    • New banjo bolts are included where applicable to ensure a perfect fit and quick installation.
    • New bleeder screws provide trouble-free bleeding and a positive seal.
    I just did it 2 years ago with a caliper from Advance - this one looks mo'betta - hope it is - Advance was a POS.
    whatstcp likes this.
  2. May 18, 2021 at 10:53 AM
    AZDude
    AZDude Well-Known Member
    1996 Tacoma base
    Can you share your experience why the advance's calipers were a POS? Thanks.
  3. May 28, 2021 at 6:01 AM
    george3
    New Jersey
    Advance caliper piston was not working and inside pad was down to the rotor - outside pad was not worn at all - not that it matters but it was a rusty mess. Hoping the new caliper lives up to its description.
    AZDude likes this.
