Calipers/rotors/UCA's 2nd gen - 3rd gen compatibility
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2005TRD, Nov 29, 2020.
  1. Nov 29, 2020 at 2:26 PM
    2005TRD
    2005TRD [OP] Active Member
    capital district NY
    05 TRD 6spd BSP 3"
    Hi friends, I am fairly certain from some google research that these 3 items are cross compatible between 6 lugs. Can anyone confirm or deny? Thank you in advance for your time and consideration.
  2. Nov 29, 2020 at 2:32 PM
    Bishop84
    Bishop84 Well-Known Member
    Brakes yes, control arms are slightly different. You can make the UCA's work, its likely very small differences. SPC shows 2005+ for arms but most OEM shows different numbers for 2nd and 3rd gen.
  3. Nov 29, 2020 at 2:36 PM
    2005TRD
    capital district NY
    05 TRD 6spd BSP 3"
    I looked at the SPC listing for reference as well! Any idea what the generational difference is between stock. Thank you for the info on the different part #'s
  4. Nov 29, 2020 at 2:37 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  5. Nov 30, 2020 at 11:19 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    What would be the point of this?
  6. Nov 30, 2020 at 1:08 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    only difference that i know of on the front suspension between 2nd and 3rd gen is the LCA (it uses the larger 5th gen 4 runner/2nd gen FJ rear bolt). Outside of that everything should be cross compatible.
    2005TRD[OP] likes this.
  7. Nov 30, 2020 at 4:29 PM
    2005TRD
    capital district NY
    05 TRD 6spd BSP 3"
    Found a good deal on lightly used calipers and UCA's but they're off a 2019
  8. Feb 26, 2023 at 11:23 AM
    L4x4Tacoma
    L4x4Tacoma Member
    Ca.
    2010 regular cab 4x4
    -Custom ARE mx hightop shell -Kmc 535 16x8 on 265/75/16 hankook at2
    hey did you go ahead and do this 3rd gen on a 2nd gen swap? I have a 2010 and am looking a guy’s newer calipers off of 3rd gen. Did the calipers work out? Thanks!
  9. Mar 16, 2023 at 8:27 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    2005-2023 use the same upper control arms, calipers and rotors.
    Jeff
    shaeff and TnShooter like this.
  10. Mar 18, 2023 at 4:48 PM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    Holy crap, how’ve ya been, Jeff?
  11. Mar 26, 2023 at 11:46 AM
    L4x4Tacoma
    L4x4Tacoma Member
    Ca.
    Got a deal on a set of calipers off of a 2020 Tacoma. Put them on my 2010 4wd and can confirm that they fit and are the same as my old calipers.
