Calipers rusted on
Discussion in '1st Gen. Tacomas (1995-2004)' started by goldentaco03, Aug 2, 2017.
  1. Aug 3, 2017 at 10:12 AM
    goldentaco03
    goldentaco03 [OP] Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    Sadly I didn't have the time to find tundra calipers or do the research, maybe another time.
  2. Aug 3, 2017 at 10:24 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    It's not always as easy as just bolting on new calipers. I've read about plenty of people needing to either modify the Tundra calipers or get wheel spacers or other mods when running the stock 16" wheels.
  3. Aug 3, 2017 at 10:26 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    ive broken a caliper trying to hammer out a siezed pin. and ive had to cut off a caliper due to a snapped/siezed bolt. salt/rust sucks. thats why i now religiously put antisieze on anything i take apart now.
  4. Aug 3, 2017 at 10:31 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    You gotta modify the banjo bolt hole as well.
    I've heard the stock wheels should fit no problem. For myself I won't have stock wheels by the time I upgrade the brakes which opens a new can of worms. I'm aiming for moving the tires outboard to clear my tires butter so I "should" have more room to make them fit. No way am I running spacers though.
  5. Aug 3, 2017 at 10:56 AM
    jbrandt
    Justin
    Agree, spacers suck.
    The more I talk about it, though, the more I wonder if what I'm remembering is an issue with putting 15" wheels on the Tacos, and people filing down teh stock caliper to fit 15's. I briefly considered that since non-metric tires are generally a bit cheaper, but never went that route because it would 100% prevent doing the Tundra brakes.
    otis24[QUOTED] likes this.
  6. Aug 3, 2017 at 11:17 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    you are correct. the 15" Toyota wheel are too small for the 231mm calipers. The 16" Toyota wheels (maybe not the tri-star) were also on the Tundra up until '06 when it changed. The OffRoad editions still came with a 16" wheel, but it was just a standard 5-star. the 17" wheels were added as a visual upgrade and to give extra space for the calipers.
    jbrandt[QUOTED] and otis24 like this.
  7. Aug 3, 2017 at 8:32 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Plenty of guys run spacers including me in the past. No different than using wheels with less backspacing. Sometimes you have to use them for getting track widths to match up etc and they perform without issue. Do they make things a little more difficult on suspension and bearings? Sure. But no different than backspacing. Using high quality ones with common sense will be all good.
    I have yet to see a scientific study showing the effects of backspacing and its effects on wheel bearings and such besides scrub radius so when people saying that they're making things way harder on wheel bearings I have a hard time understanding what they have for information to be making this judgement.
    No reason to indiscriminately bash them. Don't like'm? Got it. Saying they suck? That is excessive.
  8. Aug 3, 2017 at 9:12 PM
    otis24
    Mark
    California
    Meh, I don't disagree. Increased leverage on drivetrain bits doesn't care if it comes from wheel off set or spacers.
    Slip on spacers are one thing as long as longer studs are used etc. depending of slop on spacer width of course.
    Bolt on spacers are fine too. For me, Id rather stick with my one set of lugs nuts per wheel rather than 2 sets of lug nuts per wheel.
    Additionally spacers make no sense for me because my stock wheels are super beat up from rocks. I want to replace them with a more off road capable wheel. Why not get a wheel with better off set for my needs rather than stock off set plus spacers?
    Dalandser likes this.
  9. Aug 3, 2017 at 9:24 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If someone have to go lower than 3.5" backspacing they'll need spacers since that's as far as most wheels on our trucks go. Anyway not applicable to OP's thread so I should keep my end of the debate succinct. BTW your double fuel tank idea is a great one.
    otis24 likes this.
  10. Aug 3, 2017 at 9:34 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    had an 08 4runner that the front brakes started to drag...took the wheel off and both caliper pistons were rusted and the guide pins were severely corroded...
  11. Aug 3, 2017 at 9:37 PM
    otis24
    Mark
    California
    I wonder if stainless guide pins would make a difference?
    goldentaco03[OP] and Dalandser like this.
  12. Aug 4, 2017 at 6:02 AM
    goldentaco03
    Liam
    NJ
    That's what I was thinking, do they make them anywhere ? Can someone here make them?
