calipers sticking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brians05taco, Aug 30, 2010.
  1. Aug 30, 2010 at 4:40 PM
    brians05taco
    brians05taco [OP] Well-Known Member
    Brian
    Lafayette,La.
    05 prerunner white debadged 4.0
    lifted, bedcover,BHLM, grill, etc...
    anyone here with a 2005 and up tacoma ever had any problems with the calipers sticking...one side seems to be stopping sooner.....has anyone changed calipers on there truck due to a sticking caliper....
  2. Aug 30, 2010 at 5:00 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Yes, I had to have both my calipers rebuilt because of this. Most likely cause from mud.
  3. Aug 30, 2010 at 5:15 PM
    brians05taco
    Brian
    Lafayette,La.
    did that fix the sticking?
  4. Aug 30, 2010 at 5:28 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    of course :)
  5. Aug 30, 2010 at 5:29 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    Im experiencing same prob. plan on removing and relubing this weekend. If there is a fix, hope to find it here.
  6. Aug 30, 2010 at 5:32 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    What happened was. My caliper was sticking which warped my rotor. so, I had the calipers rebuilt and new rotors put on.
  7. Aug 30, 2010 at 5:42 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Yup, I'm after replacing both of mine over the past two years.
    A rebuilt replacement from an autoparts store may be your cheapest route.
  8. Aug 31, 2010 at 3:20 AM
    brians05taco
    Brian
    Lafayette,La.
    thats what i'm leaning towards but they are 117 dollars a piece and really don't have the extra money laying around.... guess i will soon have to bite the bullet....since its a daily driver
  9. Aug 31, 2010 at 4:27 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    4wd and pre-runners have fixed calipers but 4 pistons...is that what are sticking? Are these more prone than floating calipers to this?
    Do you think it's mudding that causes this? or getting wet a lot?
    Do ya think it's something to keep an eye on... like maybe be careful to wash off the rotors if I do get into mud?
  10. Aug 31, 2010 at 1:36 PM
    Fortech
    CANADA
    The rotors have nothing to do with it.
    If you're anal enough, your could remove your calipers and clean your pistons annually. A little brake cleaner and relubing with brake fluid is the typical way.
  11. Aug 31, 2010 at 2:15 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    If the glide pins are sticking, you can free them up yourself with penetrating oil. If its the piston that's sticking its best to replace the whole caliper.
  12. Aug 31, 2010 at 11:21 PM
    pinktaco808
    pinktaco808 Hot Steppa
  13. Sep 1, 2010 at 4:18 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Ya...i meant spraying off the calipers to get caked on mud out from between them and the rotor/pads.
    Tacobox: There aren't guide pins on the 4-piston calipers.
