Caliraised OEM light switches burning out
Discussion in 'Lighting' started by mikeyphoto8, Apr 16, 2021.
  1. Apr 16, 2021 at 5:33 AM
    mikeyphoto8
    mikeyphoto8 [OP] Member
    07 Tacoma TRD Sport
    So I bough a 3 4WDKING lights with harnesses and changed the switches to caliraised light switches but everyone of the switches has burned out? I triple checked all my connections with a multimeter. All look good. What i was experiencing was that one of the switches only the backlight led would turn on the other 2 wouldnt so i tried all the switches on all 3 lights , one light would burn its the fuse everytime. Now all three switches are burnt? Why is the fuse shorting out? Ive tripple checked the the wiring. When i bypassed the the switch mech altogether the fuse wouldnt blow and the light operated normally. ???
    The relay came with an inline fuse with the opt to use 10a, 20a, or 30a depending on the length of the wire. It burned through all three.
    I have the red wire with the inline fuse for all three lights stacked and connected to the pos pole on the battery and the 3 black wires stacked to the chasis.
    All three lights are connected with the same harnesses but one seems to be burning up the switches and fuses.
    Maybe a bad relay? How do i test for that?
  2. Apr 16, 2021 at 5:44 AM
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    China junk
    Rock Lobster, DrummyTaco and CraigF like this.
  3. Apr 16, 2021 at 2:03 PM
    mikeyphoto8
    07 Tacoma TRD Sport
    Bluetaco i see youve applied occums razor. Not a great deal of help but you got to start somewhere i guess
    Babybluetaco[QUOTED] likes this.
  4. Apr 17, 2021 at 7:29 PM
    OilCapital2021
    OilCapital2021 Well-Known Member
    Brent
    Houston, TX
    ‘19 Cement DCSB OR
    CBI Sliders; Mobtown Skids; Prinsu Rack; BD Lights; Voodoo/MAX Bed Rack; Tepui RTT; MESO stuff
    Are you using relays? I’m not an expert at all, but i ran my BD Squadron Pro Ditch lights with a relay into a caliraised switch and havent had problems running it a lot for nearly a whole year. The relay is super important, otherwise you’re putting too high of amps through the switch itself.
    Tacoma13_NC likes this.
  5. Apr 17, 2021 at 7:43 PM
    mikeyphoto8
    07 Tacoma TRD Sport
    Yes i am. Thank for your question
  6. Apr 17, 2021 at 7:48 PM
    OilCapital2021
    Brent
    Houston, TX
    ‘19 Cement DCSB OR
    mikeyphoto8[OP] likes this.
  7. Apr 17, 2021 at 7:58 PM
    mikeyphoto8
    07 Tacoma TRD Sport
  8. Apr 17, 2021 at 8:06 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    What amp rating is the fuse for pwr into the switch? I limit my switches to 2A except once during install a 7.5 was lowest i had on hand and it still didn't burnout switch.
    If relay is wired correctly and none of your terminals/connections are shorting across one another, the amp draw through switch should be low.
    May just be bad batch of switches, hard to say.
  9. Apr 17, 2021 at 8:13 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I tend to agree, it sounds like something's not wired up correctly. Would help if you posted your wiring diagram, including terminal numbers you used on your relay.
  10. Apr 17, 2021 at 8:22 PM
    mikeyphoto8
    07 Tacoma TRD Sport
    The relays are each fused with 20amp or 30amps which came with the harness from 4WDKING(Amazon). I have all the reds from each harness tied into the battery stacked one on top of the other and the grounds stacked together on the chasis. Could this be the problem. Only one of the lights was blowing its fuse and when i had them all hooked up to the battery the truck wouldnt start but the cab lights and dash turned on?
  11. Apr 17, 2021 at 8:31 PM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    Might need to change out the relays. Either that or you might be getting some kind of short somewhere. It doesn't make sense as to why the switches are burning out unless they are receiving too much current.
  12. Apr 17, 2021 at 8:31 PM
    OilCapital2021
    Brent
    Houston, TX
    ‘19 Cement DCSB OR
    Again, I’m definitely not an expert, but the “truck wouldn’t start” part is mildly concerning to me. Please hit up the thread I posted above that has experts willing to take Q&A’s. I think you’ll find they are amazing at figuring stuff out.
  13. Apr 17, 2021 at 8:34 PM
    mikeyphoto8
    07 Tacoma TRD Sport
    I sent my dilemma on to Ken. Thanks for that
  14. Apr 17, 2021 at 8:36 PM
    mikeyphoto8
    07 Tacoma TRD Sport
    Only one harness was burning through the fuse. Its set up exactly the same way. I bypassed the switch and could operate the light without blowing the fuse? The switch smelled of burnt plastic and even saw some smoke
  15. Apr 17, 2021 at 8:39 PM
    Tacoma13_NC
    Something just doesn't seem right about the wiring, but, like you said it could always be the switches too. I have two CaliRaised switches, one to a CaliRaised hidden light bar, and one harnessed to Baja Designs ditch lights. Both work perfectly. I hope you can get an answer to the issue soon.
  16. Apr 17, 2021 at 8:43 PM
    mikeyphoto8
    07 Tacoma TRD Sport
    May be a bad relay? How do i test for that?
  17. Apr 17, 2021 at 8:50 PM
    Tacoma13_NC
    This is what I think it is too. I think the harness has the wrong relay(s) in it. Either that or it's bad. OP, look up how to test a relay because that I'm not sure of.
  18. Apr 17, 2021 at 8:50 PM
    OilCapital2021
    Brent
    Houston, TX
    ‘19 Cement DCSB OR
    This sounds like the current is coming through your switch—especially since you smelled burnt plastic. The switches aren’t mean for the current that powers the light to come through the switch. My understanding, again I’m a nobody, is that with a relay you are essentially setting up two circuits. The main one to power the light which has a lot more amps, and a second one with the switch that controls the first one through the relay. I would not hook up another switch until you have someone better than me looking at a diagram of your wiring.
  19. Apr 17, 2021 at 8:55 PM
    mikeyphoto8
    07 Tacoma TRD Sport
    Thats how i understand it. The harnesses and wiring are the same so its got to be the relay
  20. Apr 17, 2021 at 9:01 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Green to fused power, red 1 to post 86 on relay, red 2 to switched light power, black to ground. Run grounds to body ground, but make sure you scrape paint off under the ring terminal (or chase the threads to get paint out of them so the bolt gets a good connection to bare metal). If the ground is bad, it can cause issues.
