Caliraised OEM switches
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xxtavixx, May 14, 2018.
  1. May 14, 2018 at 12:08 PM
    xxtavixx
    xxtavixx [OP] Well-Known Member
    Jacksonville fl
    2018 6MT
    ARB rear locker OVtune Mobtown sliders Core-shifter short throw Trd bro-phony grill Caliraised bumper light bar Caliraised ditch lights Rigid ignite back up lights FN Five Star 16x8 Et0 255/85/16 cooper st maxx MesoJDM fuse box cover MesoJDM led interior lights Bilstein 6112 fronts Bilstein 5100 rears Headstrong 3 aal Toytec 3* shims Mesjodm dome and map lights Diode dynamix ss3 pro yellow Mobtown aluminum front skid 2lo mod SOS front recovery point
    Hello everyone
    I called Caliraised a while back but they couldnt give me a specific answer, has anyone figured out what style/size switches fit the third gen switch panel?
    https://caliraisedled.com/collectio...016-2018-toyota-tacoma-oem-style-switch-panel
    I need to get a three way (non momentary, on-off-on) for back up lights, but I cannot seem to locate one through at my local auto store. Online, it's a useless search full of "almost what you searched for". Even if I have to use a blank and drill a whole for a simple toggle switch, I'd be OK with that if a switch does not exist.
    About the best solution Ive found is this, but I'm not quite sure if it will fit:
    https://www.amazon.com/dp/B00EBR0U5...a7df-eac93c35e970&ie=UTF8&qid=1526324748&sr=3
    Thank you!
  2. May 14, 2018 at 12:48 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
  3. May 14, 2018 at 1:06 PM
    xxtavixx
    Jacksonville fl
    2018 6MT
    Good find, I really like the two different colors for the on positions. That thing scares me with 10 prongs, wiring is not my best...
  4. May 14, 2018 at 2:03 PM
    xxtavixx
    Jacksonville fl
    2018 6MT
    Looks like they have a wiring diagram here
    https://www.gamainc.com/product/232e3-bb/
    Maybe it's me, but that seems more complicated than I expected for a DPDT switch. Would this be considered a double pole DPDT? Any help on how this might work would be greatly appreciated.
    Edit - Actually, thinking through it - it's not too bad. I think I let the number of prongs intimidate me.
  5. May 14, 2018 at 2:24 PM
    Anchovy
    TRD Ferguson
    It's a double pole double throw, from just looking at it i believe the top two prongs will be turned on when flipped that direction and vice versa for the bottom prongs
  6. May 16, 2018 at 5:04 AM
    xxtavixx
    Jacksonville fl
    2018 6MT
    Posting in case anyone else needs the info. I broke out my reloading calipers and took some measurements, the caliraised cut outs are 1.381 tall and .665 wide. (note, that is the measure of mine - yours may be slightly different). The "Toyota OEM switch" is not the same size as most auto/marine switches, so you'll want to be careful when ordering switches.
    The good news is, using digikey.com you can find all kinds of switches. I found several that would work well enough, just look as nice as the previous ones posted.
