Caliraised rack install
Discussion in 'Texas' started by Narutaki, Nov 16, 2022.
  1. Nov 16, 2022 at 10:48 PM
    Narutaki
    Narutaki [OP] Well-Known Member
    Brian
    2007 Blue Toyota Tacoma
    None
    Has anyone here installed these or can recommend a good shop to install these?
    Tread Depot quoted $125 x 4 hours to install, but the youtube videos show it takes about an hour. I'm debating on doing it myself but I'm probably gunna drop it on myself or something. I would pay 2 hours at the most, or am I thinking something else that this install is correct?>
  2. Nov 17, 2022 at 3:43 AM
    Squatting Pigeon
    Squatting Pigeon Remember, bird watching goes both ways. Moderator
    North Texas
    TRD OR 4R | GR Corolla
    There’s no drilling for the Tacoma rack right?
    If so I think assembling the damn thing would take longer than actually installing it. lol
    Naveronski likes this.
  3. Nov 17, 2022 at 7:17 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Yep! It’s really not hard to install, but a shop is going to have a minimum before it’s even worth their time.
  4. Nov 27, 2022 at 6:00 PM
    Perfuseme
    Perfuseme Well-Known Member
    Rick
    Just bought one…definitely gonna do myself
  5. Nov 27, 2022 at 6:16 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Have a garage? Get some pulleys and tie the rack to the ceiling. You could totally solo install it without any risk or fear of droppage then.
  6. Nov 27, 2022 at 7:45 PM
    Teliotex
    Teliotex Well-Known Member
    Super easy, less than 1 hour install and if you can get one other person to help lift at the end then you don't have to worry about scratching. What I did is on the weather stripping pull that up and lay it parallel to where it was and make a mark of the factory holes. Drill out the holes in the weather stripping where the holes are, quick tip get a pilot hole and increase to the size for the Spacers as there is a small metal piece inside that makes it a pain. Then put the spacers then brackets on hand tight. On the ground assemble the rack keeping things loose. With another pair of hands you can lift the rack up on top and each person can place the bolts for the brackets that holds everything together. Get it even and then start tightening everything down so it is nice and even and you're done. I did go back and put some silicon on the bolts going into the roof of the truck because I didn't want to chance a leak.
  7. Nov 27, 2022 at 8:06 PM
    Perfuseme
    Rick
    what light bar and side/rear did you go with if any?
    also, is the road/wind noise zero-minimal as described by manufacturer?
  8. Nov 27, 2022 at 8:11 PM
    Teliotex
    Went with no lights all together, I read around and seems like the light bar glares pretty bad off of the hood, so you have to either raise it or put some wrap down to manage it. Wind noise is not noticeable but I'm sure with a light bar there will be a lot more. I have plans to put a light bar behind the grill so I dont have to worry about either one of those problems.
    Perfuseme[QUOTED] likes this.
  9. Nov 27, 2022 at 8:16 PM
    Perfuseme
    Rick
    iv got a baja bar in my bumper and it’s a ton of light. Do I need a rack mounted bar too? Lol…prob not. As much as I’d like too do white light, maybe I should just do an amber bar. Just isn’t that much fog where I’m at
  10. Nov 27, 2022 at 8:19 PM
    Teliotex
    Id save the money and look for other mods or get the caliraised amber fog light or the tri color bulbs, been through some crazy fog and they do the job just fine.
  11. Nov 28, 2022 at 3:52 AM
    Squatting Pigeon
    North Texas
    I have a light bar in my caliraised roof rack, and I’ve only used it one time in the two years that the rack has been on the truck. Like @Teliotex said, if you want that light to get anywhere near illuminating the ground, it’s gonna light up the hood a fair amount.
    Now if you had a Baja laser bar up there, you could just use that to see into the future. :rofl:
