CaliRaised Wiring Problems...
Discussion in 'Lighting' started by BoulderNatty, Sep 13, 2017.
  1. Sep 13, 2017 at 9:09 AM
    BoulderNatty
    BoulderNatty [OP] Well-Known Member
    2017 Super White TRD Off-Road
    I recently purchased the side projecting pods and have been having trouble with the wiring. I looked it up online and used the recommended wire matching they gave me and still it doesn't seem to work. I have the Green from wiring > black on switch. Red/blue from wiring to green/yellow on switch and the yellow from wiring to the red on switch. It was weird the only way I could get the lights to turn on was to connect the yellow/red and red/green all together. I then found that I couldn't turn off the lights with that method so I am stuck again. Could the switch be faulty?
  2. Sep 13, 2017 at 9:54 AM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
  3. Sep 13, 2017 at 12:49 PM
    CaliRaisedLed
    CaliRaisedLed Well-Known Member Vendor
    Jake
    Texas (DFW)
    Could you take a picture of the wires, we can further help you out.
  4. Sep 13, 2017 at 1:01 PM
    BoulderNatty
    Tape and heat shrink will be put on better later just had to drive to work and didn't want the wires exposed.
  5. Sep 13, 2017 at 8:30 PM
    CaliRaisedLed
    Jake
    Texas (DFW)
    You will need to connect your green on the switch to the red/blue
    the red closest to green will go to the yellow
    and the black will go to the yellow wire
    The red wire on the switch that is closest to the black is for either a fuse tap or you can tie it in with the other red wire.
    Below will be a few videos for reference. The wire colors on the harness may vary but the function of them is still the same
    ScottyR and tcjacado like this.
  6. Sep 13, 2017 at 9:34 PM
    BoulderNatty
    Parker315 and outxider like this.
