calling all audio gurus....opinions please
Discussion in 'Audio & Video' started by SoCalTacos, Jan 26, 2012.
  1. Jan 26, 2012 at 12:26 AM
    SoCalTacos
    SoCalTacos [OP] Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    So I want to upgrade my stereo but want to keep stock hu...I was told by simply adding a six channel audio control(LC61), I can achieve good stereo quality. I will be running some decent equipment and am wondering if I should upgrade hu or just go this route.
    List of equipment:
    JL audio stealthbox..you're familiar with, I'm sure.
    Focal PS165 components front
    Focal PC165 coax rear
    Arc audio XDI805 5 channel for everything.
    LC61 audio control.
    I have a tendency to trust this shop as they win competitions all over and do very quality installs. However, other installers I've talked to say I absolutely need to change the hu for better sound quality. Again, I love the stock hu and would rather keep it. I'm not going cheap, I don't think, with the equipment and just want to get my moneys worth.
    Thanks in advance for all your input!
  2. Jan 26, 2012 at 1:05 AM
    commando
    commando Well-Known Member
    Brandon
    Oregon
    2006 SR5 Double Cab 4X4
    3" spacer lift
    It is true that a new head unit will provide better sound quality.
    Will your ears be able to recognize the difference?... I doubt it.
    Just the fact that you are upgrading to Focals and a better amp is going to be a night and day difference, and it is going sound much, much, MUCH better than stock speakers.
    I ran (4) 15" subs and 2 700 watt amps of a stock deck before and didn't have any problems.
    You are going to loose a little bit of signal quality going through the line out converter, but I wouldn't worry about it, especially if you are using a high quality one.
    I have used $20 Walmart ones before with good results!
  3. Jan 26, 2012 at 1:16 AM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Why would you not change out the HU? Looks like everything else is going to be top notch, I'd guess a new HU would sound way better than stock.
  4. Jan 26, 2012 at 1:24 AM
    commando
    Brandon
    Oregon
    3" spacer lift
    A digital signal is a digital signal, and that's about as good as it gets.
    You would need some very expensive
    real time analyzers and other very expensive testing equipment to tell the difference. Only a robot, or maybe your dog, would be able to distinguish between the two.
    What really matters is what is reproducing the music. New speakers (and amps) is what will make an audible difference.
    I have some Focal home audio speakers (that I built) they are the S$#T.
  5. Jan 26, 2012 at 6:01 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Why not just move forward with your plan? Worst case, if you don't like the stock HU and the LC61, all you'd be out is the cost between a new LC61 and the used price you'd sell it for. Sounds like a no-brainer to me.
  6. Jan 26, 2012 at 7:41 AM
    SoCalTacos
    socal
    Well I do love the new 2012 hu...functions, etc...also, rather keep the system hidden from los Angeles stereo jackers. The owner/installer also assured me if i didn't like the audio control route after installation and tuning he would take it back 100% refund and install hu. I just didn't want to delay the eventual if the majority said the audio control wouldn't get me my moneys worth. Thanks again, guys.
  7. Jan 26, 2012 at 8:25 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I would say pick a different amp. That ARC audio amp is fairly expensive and doesn't make much power on the sub channel. Maybe the Kenwood XR-5s?
  8. Jan 26, 2012 at 8:33 AM
    SoCalTacos
    socal
    Just curious...I'm paying $400.00 for the amp...the other option was to do a mono JL 600/1 for the subs and a JL 400/4 for the highs...it would obviously cost more to go the JL 2amp route...will it make much difference? Price-wise I think it'll be around $200-$300 more.
  9. Jan 26, 2012 at 8:48 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    He is saying get a more powerful 5 channel - keeps install easier/cheaper/cleaner, but you can do better on the price/power ratio.
    Alpine PDX, Kenwood XR5s would be good options.
  10. Jan 26, 2012 at 9:47 AM
    ItalynStylion
    Steven
    DFW, Tx.
    ^Yep, what he said.
  11. Jan 26, 2012 at 10:03 AM
    SoCalTacos
    socal
    So 400 watts rms at 2 ohms is not enough for these subs? I also liked the 2 year warranty arc audio provides with their product.
  12. Jan 26, 2012 at 10:08 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    I'd change it out for sure stock hu is garbage not even worth reselling
  13. Jan 26, 2012 at 11:18 AM
    SoCalTacos
    socal
    Not sure if you've seen the 2012 hu, but i do like it a lot and would rather keep a stock look. Besides, if I have a digital processor that should convert the signal to my liking...correct me if I'm wrong.
  14. Jan 26, 2012 at 12:10 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Didn't see that it made 400 on the sub channel at 2ohms. The spec chart on their side is split up weird and they pushed it to the bottom.:confused:
    If you're cool with the price and that satisfies your space constraints I say go for it. 400 is plenty, just make sure you buy a sub (or subs) that wires down to 2ohms.
  15. Jan 26, 2012 at 12:24 PM
    SoCalTacos
    socal
    Yeah I do believe the 10w1 JL subs in the stealthbox are 2ohm..thanks stallion.
  16. Jan 26, 2012 at 1:06 PM
    ItalynStylion
    Steven
    DFW, Tx.
    No prob man. Sorry I didn't see the other specs right off the bat.
  17. Jan 26, 2012 at 1:41 PM
    Cinco
    Cinco Team no taco
    Jose
    Rio Rancho,NM
    2012 Civic Ex Coupe
    You are 100% right.
    If your stock headunit does everything it need then the AC unit will do you great. I'm not 100% sure but I think the AC unit does 7 volt rms output IIRC My Kenwood KDC-X995 only does 4v rms. It also does summing which cleans up the signal significantly.
    I also second Steven in trying a different amp then the ARC model.
  18. Jan 26, 2012 at 2:45 PM
    SoCalTacos
    socal
    Why do you think a different amp is necessary?
  19. Jan 26, 2012 at 4:28 PM
    Wizzard005
    Wizzard005 Well-Known Member
    Greg
    Sacramento, CA
    Stock
    check out my youtube channel, this is what ya should do :)
    http://youtu.be/9D8dSSHdmPk?hd=1
  20. Jan 26, 2012 at 11:19 PM
    midniteben
    midniteben Member
    Glendale CA.
    2019 TRD OR
    I'm getting a system done in my '12 in about 2 weeks too. I'll be using the stock HU with a Audison Bit Ten, 2 way Hybrid's up front (active), no rears, and a single IDQ10 in a MrMarv enclosure. All powered by a ARC 300.4 and a 500.1 Mini.
    I'm in Socal if you wanna listen to it when done.
    CANT WAIT!
