Calling all Carpenters/Structural Engineers. New home construction ???
Discussion in 'Off-Topic Discussion' started by Gincoma, Dec 6, 2015.
  1. Dec 22, 2015 at 8:12 PM
    #121
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Usually we use concrete and lumber .
    DrFunker likes this.
  2. Dec 23, 2015 at 2:36 AM
    #122
    DrFunker
    DrFunker Well-Known Member
  3. Dec 23, 2015 at 4:19 AM
    #123
    silverpataco1968
    silverpataco1968 Tomorrow isn't Promised!
    Eric
    Eastern PA
    2007 DCSB and 2016 DCSB TRD Off-Road
    Plenty of great products so far !
    :cheers: I know that building many structures for my family and others! Just have fun ! I also figured some people on here have plenty of knowledge ! The people who don't and speak as if they do were the ones I was referring toooooo!:bananadance::dancingbacon::broccoli::drunk:
  4. Dec 23, 2015 at 5:22 AM
    #124
    Larry
    Larry CARL
    CARL
    I may build my next home with ICE blocks :thumbsup:
    http://www.iceblock.net/
  5. Dec 23, 2015 at 6:20 AM
    #125
    silverpataco1968
    Eric
    Eastern PA
    I would ,but, 72 in PA tomorrow where I live tomorrow! Won't last long!
  6. Dec 23, 2015 at 7:02 AM
    #126
    Zoot
    Zoot Well-Known Member
    2011 DC/SB TRD O/R 4X4
    Toyota bed mat, Wet Okole's F&R, Window Tint, custom trail-stripes, Cooper A/T3 265/75R16, MedlinAround interior LEDs, Leer 100r, aFe air filter, K&n cabin filter
    What's bad about OSB? The builder I'm using has 3/4" T&G OSB listed in the specs, we haven't started digging yet and I'm new to this.
  7. Dec 23, 2015 at 7:20 AM
    #127
    Larry
    Larry CARL
    CARL
    that 3/4 T&G is most likely for subflooring.
    Nothing wrong/bad about OSB. It is a replacement for plywood at a lower cost. Unless you are using quality plywood...you may be better off with the OSB. Do not let it get wet though.
    I've used it many times. But none on my newest home. I used 4-ply 1/2" on the walls. 5-ply 3/4" on the roof.
  8. Dec 23, 2015 at 7:39 AM
    #128
    Zoot
    Oops sorry I didn't type that out, it's the subfloor. The exteriors are definitely plywood, I don't know thickness, tyvek house wrap and vinyl siding, R38 roof and R13 ext walls, and I'm upgrading garage to R.. something from having none. I know the exterior are 2x6 16OC and interior 2x4.
  9. Dec 23, 2015 at 7:51 AM
    #129
    Larry
    Larry CARL
    CARL
    exterior 2x6 walls should be R19.
    by R38 "roof" you mean ceiling I suppose? Is yours a vented attic?
  10. Dec 23, 2015 at 8:43 AM
    #130
    silverpataco1968
    Eric
    Eastern PA
    Where do you live? I built my last house used Advantech 3/4" subfloors, 1/2" on all wall sheathing , 5/8" on my roof! It's like OSB much better product! The young growth trees are chipped up and the bonding material/ glue doesn't allow water to permeate the substrate! It's a few grand more in material cost for the same coverage area! Who cares about that in the entire project cost it's minimal! Most OSB sidewalls with plastic siding of some type , insulation rolled into stud bays, drywall , paint finish. You can kick with good steel boots right into your livingroom ! HaHa
  11. Dec 23, 2015 at 8:59 AM
    #131
    DrFunker
    Yeah, but a comment like this VVVV makes you sound like a know-it-all-douche.
    Just sayin'.
    :cheers:
  12. Dec 23, 2015 at 9:02 AM
    #132
    OZ-T
    Peter North
    British Columbia
    My main problem with that stuff is below grade waterproofing and insects
    What do you guys do in your area to solve those issues with ICF's ?
  13. Dec 23, 2015 at 9:11 AM
    #133
    Zoot
    SW Ohio, I searched and found they are actually 2x4 ext walls so the R13 is correct
  14. Dec 23, 2015 at 9:22 AM
    #134
    Larry
    Larry CARL
    CARL
    we don't use the ICE blocks below/at grade. we build a stem wall foundation with CMU's and pour a slab. the ICE blocks are built from the slab up.
  15. Dec 23, 2015 at 9:28 AM
    #135
    WFD
    WFD Well-Known Member
    Springdale, Utah
    '96 3.4L 4x4 5 Speed Man
    OME Suspension 2" lift, Leer high-rise topper w/ sleeping platform.
    OP and others - I would have no (read: very little) concerns with building styles or local building codes in relation to structural integrity. As long as you are using a licensed, experienced carpenter/contractor who is following building codes you should be fine. Modern building codes are (IMO) over engineered for structural integrity and insulating value. For good, safe, responsible reasons. OSB/plywood/16" or 19" OC studs/ 2X12 rafters etc all are fine when done correctly. If you are still worried after all that you have read here, I would recommend going and pulling the siding and roof off of a 150 y.o. Victorian anywhere in the country. You are likely to find studs and rafters at 24" on center, tarpaper not tyvek, and rafters and joists that are sometimes as small as 2X6 (though TRUE 2X6), and no joist hangers or rafter hangers.
    Are modern houses more rock-solid? yes. With much higher r-values? yes. Should you be concerned about whether your stud spacing is 16" OC or 19" OC? no.
  16. Dec 23, 2015 at 9:42 AM
    #136
    OZ-T
    Peter North
    British Columbia
    There's your first upgrade should you wish to make one , or alternately do exterior insulation , foam or rockwool
  17. Dec 23, 2015 at 9:43 AM
    #137
    OZ-T
    Peter North
    British Columbia
    I guess not a lot of basements in Florida
  18. Dec 23, 2015 at 9:45 AM
    #138
    OZ-T
    Peter North
    British Columbia
    Tarpaper is a better WRB than Tyvek IMO
    but I gotta agree having insulation versus no insulation will give you a better R value
  19. Dec 23, 2015 at 10:30 AM
    #139
    Larry
    Larry CARL
    CARL
    very few. there are a few hilly spots up here in N Florida where they have built "walk out" lower levels.
    I hate a basement anyway. I don't like useable attics or stairways either. so Florida fits me well. :laugh:
  20. Dec 23, 2015 at 10:32 AM
    #140
    Larry
    Larry CARL
    CARL
    I disagree. (assuming of course the Tyvek house wrap is installed correctly)
