Calling all Tacoma gurus - What are some major issues with Tacomas after 2006?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballin, Nov 7, 2017.
  1. Nov 8, 2017 at 11:07 AM
    #41
    njcoma
    njcoma Well-Known Member
    California
    2017 Accord Sport Special Edition
    Previous: 2006 Tacoma SR5 Prerunner: 2010 4Runner sr5 Rims, TSB rear leafs, Wetokole neoprene seat covers, JVC LED color matched head unit, scanguage II, Flowmaster 40 cat back exhaust, hankook dynapro atm tires, Class 4 Uhaul Hitch. Kicker 12 inch sub and amp. Focal speakers. jba offroad UCAs.. Detroit truetrac rear end... bilstein 5100 rear and 6125 front coilovers. Nfab front bumper with KC apollo lights, bed lights, bluesea systems fuse box....lots of painted stuff.
    I did the valve cover gasket in about an hour.. both sides. If that's where the leak is coming from.. it's easy..
    If it's from behind the water pump.. it's more involved.. but mine leaked for over 20k miles and I never really had to add oil between normal oil changes..
    As for other issues... my 06 had most of its problems attributed to steering.. the rack... the intermediate shaft..etc..
  2. Nov 8, 2017 at 12:26 PM
    #42
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
  3. Nov 11, 2017 at 5:13 PM
    #43
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    My 07 has had a seeping rack for 40-50k miles, I keep flushing it every couple of years... gonna see how long it will go, as long as its not dripping I'm not gonna worry about it. I never have to add fluid, so its not losing much. just enough to wet the boots. I have broke several mudflaps now, I ran without them for a while but i kept chipping the paint on my doors... I drive a gravel lane every day. Now I have a set of Husky mudflaps that are shorter than stock, they've been on for several years now, luckily I haven't broken one of these yet. I did have the timing cover leak fixed under my platinum extended warranty as well as a window motor on the drivers door, the window motor hadn't failed but did sound bad, my dealer took care of me. I had previously taken my truck to a closer dealership and they wouldn't fix the timing cover, but the dealer I bought it from did..along with the window motor, no questions asked. I no longer go to the closest dealership, unless I'm in a pinch and have to have parts.
    Otherwise, the idler/belt tensioner pulleys don't tend to last real long.
    I need to fix/replace my blower motor connector and resistor, that's a common problem on these as well.
    I did the ECGS bushing on my drivers side as preventative maintenance.
    I'm one day gonna get around to adding a zerk to the slip yoke on the driveshaft to make greasing it easier, if I don't grease it from time I get a clunk when I stop or take off from a stop.
    My compressor sounds rough, but the a/c is ice cold still. I suspect that the bearings in the compressor are getting bad, I should replace it before it fails and takes everything else with it... depending on how long I decide to keep it.
    Overall, I'd say these are pretty solid trucks, over 11 years I haven't had any major repairs or problems that I would classify as abnormal. I'd buy another one.
  4. Nov 12, 2017 at 6:31 AM
    #44
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    I would source a low mileage used engine and install in your current ride. ALOT less work, less downtime and probably cheaper.
  5. Nov 12, 2017 at 6:50 AM
    #45
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    X5 on the throw out bearing.
    Rack n pinion was leaking slowly, replaced at 85k. Interestingly my Sequoia is doing the same thing.
    09s headunit is glitchy, switches between CD and aux randomly .
  6. Nov 12, 2017 at 6:51 AM
    #46
    archerm3
    archerm3 Well-Known Member
    Nebraska
    97LX (sold) 15DCSB BRM MT OR(RIP) 09 Tahoe
    Brake controller, Snugtop, Hellwig981, Gentex, custom frame bending and body removal by red light runner.
    2nd gen whistling/kazoo sounds from the door seals with crosswinds on highway.
    BenJammn5 likes this.
