Calling all Tacos, what cold air intake or mod do you have?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoDfresh, Apr 1, 2021.
  1. Apr 1, 2021 at 5:16 AM
    TacoDfresh
    TacoDfresh [OP] Member
    2017 Blue Tacoma TRD Sport
    Looking for a cold air intake or mod I can do for the taco. Let me know what you have.
  2. Apr 1, 2021 at 5:19 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    Welcome to TW. I would spend about a month reading though the gazillion posts about mods, favorite mods, cheap mods, etc.
    Good luck, and I hope you like your wallet thin and light.
    TacoDfresh[OP] likes this.
  3. Apr 1, 2021 at 6:11 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Welcome. If you are looking for engine glitter and a louder sound then get the TRD.
    If you are looking for additional performance don't bother as the truck already has a CAI. It pulls air from above the right tire outside the engine compartment.
    @jberry813 really? I thought the dumbgeon was bad but upside down too? Lol
  4. Apr 1, 2021 at 7:11 AM
    omg_miiiike
    omg_miiiike Well-Known Member
    Maryland
    2017 Tacoma TRD Off Road | DCSB
    I'd say save your money.. But if you want just a little bit of deep noise wide open throttle, and whistle while cruising.
    I purchased the K&N (not a fan of them) that was on sale on Amazon because I wanted to try a different filter and I wanted to replace the OEM intake tube with something with better direct (straight) flow.
    I am OVTuned but I feel the intake did open the truck up just a bit more due to getting rid of the box thing on the OEM tube.
    Link to what I bought, but I paid $150 shipped which is the only reason I purchased it.
    https://www.amazon.com/57-9039-Perf...words=k&n+tacoma+intake&qid=1617286168&sr=8-3
  5. Apr 1, 2021 at 7:48 AM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Depends most are OPEN INTAKES air raid and afe most common COLD AIR INTAKES
  6. Apr 1, 2021 at 7:57 AM
    farmtacoma
    farmtacoma Date Farmer
    Julia
    Twentynine Palms, California
    2021 Cement TRD OR DCLB 4x4 & 2018 Silver SR ACLB 4x2
    Get a snorkel
    then
    Ko2
    TR4 replica wheels
    Lift
    RTT
    Pro grille
    Raptor lights
  7. Apr 1, 2021 at 8:01 AM
    bhughesru03
    bhughesru03 Well-Known Member
    Virginia
    20 TRD OR 4x4 MGM
    9377569F-AC5B-463C-A5E9-2E1CC850E168.jpg Bought my truck on a Saturday and by Sunday morning I installed a K&N performance intake. It definitely makes the truck louder at higher rpm’s. Almost annoyingly loud. Although listening to the engine helps me pay more attention to keeping the rpm’s down so I can get the best mpg’s possible. Although the main reason I got it was to improve the throttle response. It does do a good job at that. I went from a ‘15 TRD Sport to test driving a ‘20 OR and the few I tried I thought there was something wrong with the throttle bc how unresponsive it was. I added the CAI and it has fixed that problem. Don’t get me wrong, it’s not throw you back in your seat, but now it makes it feel more normal when I press on the accelerator.
  8. Apr 1, 2021 at 8:12 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    The URD TCAI is a solid product. Well engineered and very throaty and aggressive sounding at high RPMs. Also an attention grabber where it sits right behind the grille for maximum dense, cold air flow.
  9. Apr 1, 2021 at 8:25 AM
    NinGee87
    NinGee87 Well-Known Member
    AZ
    19 Cement DCSB TRD Sport 4x4
    I have an HPS Silicone intake tube which was maybe a little over $100 on Amazon. Opened the truck up a bit, doesn't have an annoying drone, and took about 20mins to install. The truck isn't geared like a sports car, so I wasn't expecting much. I am happy with it though.
    TacoPandaTRD and TacoDfresh[OP] like this.
  10. Apr 1, 2021 at 8:26 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    I have a drop in TRD air filter. I like to think the engineers knew what they were doing when they designed it. I have used CAI's before on naturally aspirated engines and never noticed a difference other than sound. Plus they can be expensive.
  11. Apr 1, 2021 at 8:48 AM
    eurowner
    eurowner Duke Sky
    Scoty
    TRD Intake Accelerator, Green Filter, HPS tube.
  12. Apr 1, 2021 at 8:58 AM
    Burqueboy505
    Burqueboy505 Well-Known Member
    Albuquerque, NM
    2019 Cement OR DCSB
    I went with S&B Filters. Its a huge airbox and filter. I did it purely for sound, which in my mind, sounds better than any exhaust out there. No performance gains however throttle response is much improved. If there was a mod I could live without, it would be this one.
  13. Apr 3, 2021 at 8:45 AM
    Steamy Longbottom
    Steamy Longbottom Well-Known Member
    1LT Browneye
    East TN
    '21 Army Green TRD O/R 6MT
    Modifications are bad and only bad people modify.
    I don't have a Taco yet as it's being built, but I have narrowed it down between the AFE Momentum GT or the iHolley intake because they utilize a scoop that may bring in colder air from the front at cruising speed and theoretically improve the IAT, which I plan to document in the future with my Bluedriver. My requirement is at least equal flow with better filtration, which is a lot to ask for in general. I don't think that there are meaningful "gainz" to be had but colder air might result in tiny but measurable efficiency gains. The dyno charts can be misleading as to date, gear, temperature, and other factors so be weary of snake oil.
  14. Apr 3, 2021 at 8:50 AM
    Shocked
    Shocked Well-Known Member
    2021 Tacoma TRD Pro
  15. Apr 3, 2021 at 8:53 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Whats wrong with the OEM CAI that came with the truck?
    I'm using the OEM CAI and getting about 19 mpg with a 4.0L V-6. Gots plenty of power. Gots enough throttle noise. Gots good throttle response.
    Don't know what else is needed. :notsure:
    Surely, I don't need to skinny my wallet.
    Steamy Longbottom likes this.
  16. Apr 3, 2021 at 9:00 AM
    Shocked
    2021 Tacoma TRD Pro
    Why not? It their truck. Some might ask why you need a Tacoma with 4 wheel drive? Why do you need a V-6? A 4 cylinder 2 wheel drive Geo Metro will also get you from point A to point B.
    Burqueboy505 likes this.
  17. Apr 3, 2021 at 9:04 AM
    Shocked
    2021 Tacoma TRD Pro
    I would love to have a snorkel.
  18. Apr 3, 2021 at 9:04 AM
    Knute
    @Shocked Perhaps my post was too subtle for your grasp.
    The point. Tacomas come equipped with a functional CAI. There is no performance gain from an aftermarket doodad. The aftermarket will only empty your wallet.
    Of course, it is the OP's truck. They can do as they wish. Although, many owners do not realize the Tacoma is equipped with a CAI from the factory.
    A bicycle or a pair of shoes will get you from point A to point B also.
  19. Apr 3, 2021 at 9:06 AM
    Shocked
    2021 Tacoma TRD Pro
    There are tons of info saying there is a gain. For some people, these trucks are a blank canvas, and want to have fun. Who am I or you to judge them for it? I say do whatever you want to your truck and be happy.
  20. Apr 3, 2021 at 9:08 AM
    Knute
    @Shocked If you read carefully.
    You will discover that I did not judge.
    I only offered that the truck already had an OEM CAI.
    I wish you a Happy Easter and a nice weekend.
