Calling all third gens with remote starts installed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stoked4, Nov 14, 2016.
  1. Nov 15, 2016 at 9:26 AM
    #61
    DanielTaco
    DanielTaco Well-Known Member
    Daniel
    Iceland
    2016 Tacoma DCSB TRD OR 3.5
    I wouldn't start it back to back, that would make no sense. Why would you remote start it and then get right in and start it again? Most logical people would use it for what it's intended, meaning the starts wouldn't be "back to back" they would be 5 to 10 mins apart. Well outside of any problematic time frame.
  2. Nov 15, 2016 at 9:27 AM
    #62
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    you should start it 14 times a day.. it'll actually make your starter last longer!
  3. Nov 15, 2016 at 9:28 AM
    #63
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    gpb and dYL0n like this.
  4. Nov 15, 2016 at 9:32 AM
    #64
    DanielTaco
    Daniel
    Iceland
    I probably do more than that.
  5. Nov 15, 2016 at 9:34 AM
    #65
    dYL0n
    Dyl0n
    New Orleans, LA
    You starter will never break. You know the secrete man.
  6. Nov 15, 2016 at 9:36 AM
    #66
    swordfish
    swordfish Well-Known Member
    Jon
    CT
    ‘25 MT6 Off-Road
    Errrrrrr. I think I may have vomited a tiny bit.
  7. Nov 15, 2016 at 9:37 AM
    #67
    Stoked4
    Stoked4 [OP] Well-Known Member
    2017 trd sport DCLB (OVtuned)
    So I'm starting the car from in my house when it's snowing out, and when I walk out to get into the truck it shuts off So you're saying I should wait five minutes before restarting it so I can go to where ever I'm going?
    Starting it immediately after it's remotely started is because the truck shuts off when the doors opened. This is my original complaint
    dYL0n likes this.
  8. Nov 15, 2016 at 9:41 AM
    #68
    swordfish
    Jon
    CT
    ‘25 MT6 Off-Road
    @Stoked4 You are probably overthinking the issue. If you remote start the truck, finish putting on your boots and gloves, pour the shot of GM in the coffee mug, then walk out to the great white expanse you're going to be fine. If you are using the starter like a white chick and start it while you are 20 feet away in the mall parking lot you might eventually have an issue.
  9. Nov 15, 2016 at 9:46 AM
    #69
    Stoked4
    Right, but then when I walk up to the truck and open it, the truck will shut off. then I'll be restarting it again, I know it's silly but the whole fact that the truck shuts off when it's opened and there's no bypass.... is Silly
    Point of this thread was to see if anybody had figured out a way to avoid this , but it seems like not too many people have a remote start with their push to start vehicles
  10. Nov 15, 2016 at 9:47 AM
    #70
    DanielTaco
    Daniel
    Iceland
    Are you shitting me dude :rofl:
    You start the car from in your house, wait 5 mins before you go outside (because it's warming up) the engine turns off and you restart it.
    It's been 5 minutes between starts because you started it over 5 minutes ago.
  11. Nov 15, 2016 at 9:48 AM
    #71
    DanielTaco
    Daniel
    Iceland
    It will break, eventually when it's full of shit and corroded.
  12. Nov 15, 2016 at 9:50 AM
    #72
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Ya think? :D
    Do you think that's a typical use case? Throughout the year, every single time someone goes to start their vehicle they'll use the remote start first? I have trouble seeing this example as anything but a strawman.
    dYL0n[QUOTED] likes this.
  13. Nov 15, 2016 at 9:51 AM
    #73
    dYL0n
    Dyl0n
    New Orleans, LA
    Ok
  14. Nov 15, 2016 at 10:04 AM
    #74
    Stoked4
    Right, but read back in the post, a member stated that when he had done exactly what you said it took the car 20 seconds of cranking and it wouldn't start, he then had to sit and wait for a bit before starting it up
    The issue isn't time between starts, but time between the truck shutting off due to the opening of the door to the second start when you get in
    dYL0n likes this.
  15. Nov 15, 2016 at 10:10 AM
    #75
    gpb
    Atlanta
    I'd suggest you first determine that this is a real issue affecting anyone else before wasting any more of people's time on it. How many other instances of that behavior have you found? How do you know that is how it's supposed to be instead of a misconfigured setup or some other problem?
  16. Nov 15, 2016 at 10:10 AM
    #76
    DanielTaco
    Daniel
    Iceland
    The 20 second cranking thing is a problem, that's absolutely not supposed to happen and is likely an isolated issue.
    gpb likes this.
  17. Nov 15, 2016 at 10:13 AM
    #77
    Stoked4
    I've heard this from one person about the 20 second bs, I only brought it up because someone misunderstood one of my posts. Others have confirmed that there was no waiting involved
  18. Nov 15, 2016 at 10:21 AM
    #78
    gpb
    Atlanta
    Yet you keep bringing it up... :confused:
    ... and BTW the only misunderstanding came from you stating "push button starts were required to come with this type of fail safe" in reply to an exchange about the 20-second delay when you in fact meant the door-open shutoff.
  19. Nov 15, 2016 at 10:44 AM
    #79
    Stoked4
  20. Nov 15, 2016 at 10:49 AM
    #80
    Chris.taco.2016
    Chris.taco.2016 Well-Known Member
    2016 Tacoma trd sport mgm dclb
    I have push button start and my truck doesn't turn off when I use my aftermarket remote start just have to unlock the truck with the remote start fob.
