Calling all third gens with remote starts installed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stoked4, Nov 14, 2016.
  1. Nov 15, 2016 at 10:52 AM
    #81
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    I feel like going outside and turning my truck on and off continuously.
    DHSteeze and Tucktuck8 like this.
  2. Nov 15, 2016 at 10:54 AM
    #82
    Cold_Toad
    Cold_Toad Well-Known Member
    I'd advice you never to buy any vehicle with the stop/start feature if you really believe starters are that fragile.
    02TRDXTRA likes this.
  3. Nov 15, 2016 at 10:57 AM
    #83
    mikmabz
    mikmabz Well-Known Member
    2016 Magnetic Gray Metallic Tacoma 4x4 TRD SPORT DCLB
    Roof Rack, Side Step Bars, Chrome Exhaust Tip
    I have the push start button and yes, once you open the door the engine shuts off. But as soon as I get in and push the start button again the engine starts right off. There is no 20 second cranking like the other guy experienced on his truck. It has always been that way including the Rav4 that was traded-in for the Taco.
    I have a friend who owns a 2016 Nissan Rogue with push button start. And the work around for the engine not to shut off when the door is opened. First, he has to unlock the vehicle with his remote starter unlock button. Then once he is inside the vehicle, close the door BEFORE depressing the brake pedal and he can put the vehicle in gear. That way it won't shut the engine off. Does not work with my Taco or the previous Rav that we traded in though.
  4. Nov 15, 2016 at 10:59 AM
    #84
    4RNR
    4RNR トヨタ
    Ge
    America
    16 Tundra 1UR-FE | 10 4Runner 1GR-FE | 16 2GR-FKS DCSB 4X4 - sold
    2016 Tundra crewmax
    X2
  5. Nov 15, 2016 at 11:12 AM
    #85
    mikmabz
    Do you have an aftermarket remote starter? What brand? Thanks.
  6. Nov 15, 2016 at 11:16 AM
    #86
    dYL0n
    Dyl0n
    New Orleans, LA
    I've never said theyre fragile. Never once. I never said it will break by doing this. Im saying if you cycle a piece of equipment 2 times when it can be one...it will wear down faster. If you deny that.. I can't help you.
    The starter may outlast my truck.. who knows. But I know im not adding some aftermarket shit to my 40k truck to have it start remotely, warm it up (it might not even get to normal operating temperature) then i open my door, then i have to restart it.
  7. Nov 15, 2016 at 11:22 AM
    #87
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    As I mentioned above, that's a strawman.
    In what use case do you possibly envision someone using a remote start every single time they get in their truck to go somewhere? Typical in the north may be once or twice a day in winter after the truck's sat for hours. In the south it may be once or twice at lunch and in the afternoon if the truck has sat out in the sun.
    Not a lot of need for that in New Orleans I imagine. ;)
    *shrug* Your choice of course. I just don't see the logic in it. You can get in a cooled down truck and press the start button and go, or you can get in a 140F truck and press the start button and go.
  8. Nov 15, 2016 at 11:25 AM
    #88
    Chris.taco.2016
    Chris.taco.2016 Well-Known Member
    2016 Tacoma trd sport mgm dclb
    Compustar
    mikmabz[QUOTED] likes this.
  9. Nov 15, 2016 at 11:28 AM
    #89
    mikmabz
    So the engine does not shut off when you open the door after remote starting it, right? Thanks!
  10. Nov 15, 2016 at 11:29 AM
    #90
    dYL0n
    Dyl0n
    New Orleans, LA
    Only way I'd buy a remote start is if were OEM and it didn't cut off when I open the door.
    Only time I'd use a remote start is in the winter.
  11. Nov 15, 2016 at 11:29 AM
    #91
    gpb
    Atlanta
    Are you using a Compustar 2way remote to start and then unlock the vehicle, yes?
    What happens when you use the OEM fob to unlock after you've remote started?
  12. Nov 15, 2016 at 11:31 AM
    #92
    gpb
    Atlanta
    So go talk to your Toyota dealer rather than posting here?
    Let us know what you find out.
  13. Nov 15, 2016 at 11:31 AM
    #93
    dYL0n
    Dyl0n
    New Orleans, LA
    It's not available.
  14. Nov 15, 2016 at 11:33 AM
    #94
    DanielTaco
    DanielTaco Well-Known Member
    Daniel
    Iceland
    2016 Tacoma DCSB TRD OR 3.5
    It's not "some aftermarket shit" the OEM factory remote start operates this way on all toyota's with push start. I'm not saying Toyota engineers know it all, they clearly f plenty of things up, but simply put the number of times the starter is engaged does not directly correlate to the failure of the part. There is no evidence for that. It's designed to start the engine god knows how many times, and if you've ever taken apart a "worn out" one, you'd see they go bad for reasons that have nothing to do with usage.
  15. Nov 15, 2016 at 11:34 AM
    #95
    swordfish
    swordfish Well-Known Member
    Jon
    CT
    ‘25 MT6 Off-Road
    So much hate and anger over a non-problem.
    DHSteeze, 0210, IPNPULZ and 1 other person like this.
  16. Nov 15, 2016 at 11:35 AM
    #96
    dYL0n
    Dyl0n
    New Orleans, LA
    :pccoffee:
  17. Nov 15, 2016 at 11:35 AM
    #97
    Chris.taco.2016
    It's a one way and nothing it just won't unlock it
  18. Nov 15, 2016 at 11:35 AM
    #98
    gpb
    Atlanta
    You'll only install a remote-start that doesn't exist, to only use it in winter in New Orleans. I see why I got puzzled.
  19. Nov 15, 2016 at 11:36 AM
    #99
    dYL0n
    Dyl0n
    New Orleans, LA
    If it existed.
  20. Nov 15, 2016 at 11:38 AM
    #100
    gpb
    Atlanta
    Which? Winter in New Orleans, or an OEM Tacoma remote start?
    :crapstorm:
