Calling all third gens with remote starts installed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stoked4, Nov 14, 2016.
  1. Nov 15, 2016 at 11:39 AM
    #101
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    OEM tacoma remote start.
    Im used to the heat. Not used to the cold. It'll get into the upper 30's - 40's. Thats cold enough for me to use it!
  2. Nov 15, 2016 at 11:42 AM
    #102
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    I know, I just couldn't resist kidding around a bit. ;)
    I grew up and spent years in the frozen north before deciding to GTFO and moving south.
  3. Nov 15, 2016 at 11:43 AM
    #103
    dYL0n
    Dyl0n
    New Orleans, LA
    I like it down here. Not too cold in the winter. And the salt doesn't eat up my taco!
  4. Nov 15, 2016 at 11:47 AM
    #104
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    A OEM Toyota remote start is available from the dealer for the Tacoma
  5. Nov 15, 2016 at 11:49 AM
    #105
    dYL0n
    Dyl0n
    New Orleans, LA
    Link? Why wasn't in an option when I ordered my truck?
  6. Nov 15, 2016 at 11:56 AM
    #106
    gpb
    Atlanta
    Because it doesn't exist as a Tacoma part. Not as best as I've found. My dealer also couldn't come up with one two months ago when I had money in hand.
    It seems some may be using either a Tundra or 4Runner part. Having looked at the instructions for the Tundra install, I'd be more comfortable using a known-brand aftermarket model with Tacoma specific instructions in absence of a true factory supported OEM install.
    dYL0n[QUOTED] likes this.
  7. Nov 15, 2016 at 11:59 AM
    #107
    dYL0n
    Dyl0n
    New Orleans, LA
    Exactly. If it's not available on the Tacoma.. it won't be covered under warranty.
  8. Nov 15, 2016 at 12:02 PM
    #108
    gpb
    Atlanta
    Do realize that any accessories added now, even if Toyota OEM, will only have a 1 year warranty.
    Provided one sticks with a known name brand any issues are much more likely due to a poor installer than due to the unit itself.
  9. Nov 15, 2016 at 12:02 PM
    #109
    IPNPULZ
    going to be fun!
    Genuine Toyota Accessories PT398-03120 Remote Engine Starter is what I was told from Toyota parts Dept.....
  10. Nov 15, 2016 at 12:04 PM
    #110
    gpb
    Atlanta
    https://trdparts4u.toyotaofdallas.com/scripts/prodView.asp?idproduct=331437
    It may work on a Tacoma, but if it's not listed for Tacoma we're back to the concerns above.
    dYL0n likes this.
  11. Nov 15, 2016 at 12:09 PM
    #111
    dYL0n
    Dyl0n
    New Orleans, LA
    :cheers:
  12. Nov 15, 2016 at 12:12 PM
    #112
    gpb
    Atlanta
    Did they reference any install instuctions for the Tacoma?
    Here are the Camry instructions: http://toyotaparts.sparkstoyota.com/install/PT398-03120inst.pdf
    Much less involved than the Tundra, but again I'd like to see a lot more info on how it's all wired up before dropping three bills on something I don't know will work when I can install a Fortin for half the price myself, or pay $275 to have a local shop install whatever one they use (Avital I think).
  13. Nov 15, 2016 at 12:38 PM
    #113
    IPNPULZ
    going to be fun!
    Then I guess if you want a remote start you will either have to deal with the shutting off of the engine when you open the door....
  14. Nov 15, 2016 at 12:51 PM
    #114
    gpb
    Atlanta
    Moot. Not a self-install part apparently.
    The referenced part requires Techstream Notebook to complete registration of the module to the ECU according to the instructions. They state that Techstream Lite won't do the trick.
  15. Nov 15, 2016 at 1:03 PM
    #115
    jamier2
    jamier2 Member
    Jamie
    2017 Tacoma TRD-OR DCLB
    No, I'm saying if I use remote start on my Ram or Infiniti, just had to get in and push button to go (but not use starter again - the engine didn't die). Whereas in our Toyota Sienna if you use remote start it dies when you open door and you have to restart it. Just like everyone on this thread is complaining about.
  16. Nov 15, 2016 at 1:34 PM
    #116
    Stoked4
    Stoked4 [OP] Well-Known Member
    2017 trd sport DCLB (OVtuned)
    And when you get in to drive to you have to push the push to start button or tap the brake?
    Or press the brake put truck into drive and go?
  17. Nov 15, 2016 at 1:36 PM
    #117
    Stoked4
    How is this not a possibility for Toyota?
    This is my predicament, reason for complaining
    mikmabz[QUOTED] likes this.
  18. Nov 15, 2016 at 1:43 PM
    #118
    Tucktuck8
    Tucktuck8 Well-Known Member
    2016 White DCLB
    Does any remote start system turn your seat heaters on below certain temps?
  19. Nov 15, 2016 at 1:51 PM
    #119
    mikmabz
    mikmabz Well-Known Member
    2016 Magnetic Gray Metallic Tacoma 4x4 TRD SPORT DCLB
    Roof Rack, Side Step Bars, Chrome Exhaust Tip
    I hear ya!
  20. Nov 15, 2016 at 2:39 PM
    #120
    Goochwarmer
    Goochwarmer Well-Known Member
    2017 Tacoma TRD Off Road MT
    False assumption that it doesn't work, it is considered a safety feature maybe but not inoperable. It is a compustar and is set to run for 25 minutes, if it is interrupted by a door opening than it kill switches it. If it runs it's time down or I stop it by the remote I can just in and it will start right up. I tested it several times by starting it and trying to unlock with both key fobs (compustar and Toyota) and just getting in the truck. It appears to be a safety feature to me..and yes it cranked for 20+/- seconds several times if I just opened the door without stopping it by the FOB. Annnnd it was installed by the dealership and the weather was not a factor as I did the test outside (below 35°) and in the garage.
    oldman52 likes this.
