Calling all Toyota owners in the Lynchburg and Charlottesville and surrounding areas!
Discussion in 'South East' started by VAYoder4167, Jan 6, 2014.
  1. Jan 27, 2014 at 6:41 AM
    #221
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Replace your u-bolts while you're in there.
  2. Jan 27, 2014 at 7:08 AM
    #222
    Taylor
    Taylor Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Okay. Anything else? Is a diff drop necessary? I have the ADD. Will I need any new bolts or anything? Bumpstops?
  3. Jan 27, 2014 at 10:42 AM
    #223
    VAYoder4167
    VAYoder4167 [OP] Well-Known Member
    Frank
    Lynchburg, VA
    Lifted 04 toyota tacoma sr-5
    Magnaflow dual catback exhaust, 5100 bilsteins all around with 1" body lift and stock coils, 33" BF Goodrich sitting on a set of 15" Alloy Ion wheels
    Change of plan now I'm going to go with wheelersoffroad.com because they have a big variety as great prices as well. I'm think eithe a nice set off OME shocks and coilovers and rear shocks or a nice set billies just depends on how much money I get back if I get enough I might go with a nice set of long travel icons or fox.
    Taylor it depends on how much lift your going with if your going with 3" or more or maybe 2.5" you will probably have to go with the diff drop and just depends on what setup you go with just depends some kits come with hardware some don't you may need center pins and u-bolts and whatever else.
  4. Jan 27, 2014 at 11:09 AM
    #224
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    What's your plan on the rear?
    And ugh, I don't have the money for a diff drop. Nevermind. Guess it's just spacer plates?
    I wish there was a list of the bolts and bushings I'll need to replace.
    So, billies up front set all the way up with stock springs and diff drop. 2.5 inches of lift.
    In the rear, allpro leaves and shocks, extended brake lines, new u bolts. 3 inches of lift.
    I wonder how awkward that rake would look? Would the rear settle down more than the front?
  5. Jan 27, 2014 at 2:10 PM
    #225
    VAYoder4167
    Frank
    Lynchburg, VA
    2" AAL and either billies or OME's. I think you'll be ok and of you need anymore let me know or pm me.
  6. Jan 27, 2014 at 2:11 PM
    #226
    wheelerkr2
    wheelerkr2 Well-Known Member
    Kevin
    Richmond, VA
    08 TRD Rugged Trail
    Blacksburg count?
  7. Jan 27, 2014 at 2:24 PM
    #227
    VAYoder4167
    Frank
    Lynchburg, VA
    Yea man of course happy to have your interest. Is tht where you live or are you just at school?
    On another note 4 decals down 6 more to go. Claim em if you want them.
  8. Jan 27, 2014 at 2:35 PM
    #228
    wheelerkr2
    Kevin
    Richmond, VA
    08 TRD Rugged Trail
    School, I'm from yorktown
  9. Jan 27, 2014 at 3:01 PM
    #229
    ckeene9
    Chesterfield, VA
    See Build Thread
    Don't waste your money on a diff drop, at least on the 2nd gens their not worth it. Don't you 1st gen guys need a BPV bracket when lifting?
  10. Jan 27, 2014 at 3:02 PM
    #230
    VAYoder4167
    Frank
    Lynchburg, VA
    Ok cool thanks for the interest and keep an eye on this thread. We are planning an meet and eat and hopefully another trail ride here in the very near future.
  11. Jan 27, 2014 at 3:16 PM
    #231
    ckeene9
    Chesterfield, VA
    See Build Thread
    Nice, make sure you get down in between the hitch and plate area. I don't think I did mine very well and am now concerned with all this salt on the road.
  12. Jan 27, 2014 at 3:22 PM
    #232
    ckeene9
    Chesterfield, VA
    See Build Thread
    I think I'm going to drill a couple of holes in the bottom there as well to drain any water, just seems like a rust breeding ground back in there.
  13. Jan 27, 2014 at 3:25 PM
    #233
    ckeene9
    Chesterfield, VA
    See Build Thread
    Sweet! Chopping sounds a lot more fun than moving.
  14. Jan 27, 2014 at 3:40 PM
    #234
    VAYoder4167
    Frank
    Lynchburg, VA
  15. Jan 27, 2014 at 4:55 PM
    #235
    wheelerkr2
    Kevin
    Richmond, VA
    08 TRD Rugged Trail
  16. Jan 27, 2014 at 5:12 PM
    #236
    VAYoder4167
    Frank
    Lynchburg, VA
    Yea I know I found this alittle bit ago. It's awesome that we have so many different parts available to us.
  17. Jan 27, 2014 at 6:39 PM
    #237
    VAYoder4167
    Frank
    Lynchburg, VA
    I think and hope I finally found what I'm going to get and here is the winner so far:
    Bilstein 5100 Front adjustable shock x 2
    Bilstein 5100 Rear shock x 2
    Deaver 2" AAL
    Eibach Front Coils
    Diff Drop Kit
    Brake Proportioning Valve Bracket Kit (for 2" lift or more)
  18. Jan 27, 2014 at 7:12 PM
    #238
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    I can't use websites like that because I need new leaves entirely. Not AALs.
    Also, I've heard anything about a new BPV. Where is that even located?
  19. Jan 27, 2014 at 7:24 PM
    #239
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
  20. Jan 28, 2014 at 1:20 AM
    #240
    eaglesfn5402
    eaglesfn5402 Well-Known Member
