Calling all Toyota owners in the Lynchburg and Charlottesville and surrounding areas!
Discussion in 'South East' started by VAYoder4167, Jan 6, 2014.
  1. Feb 25, 2017 at 3:40 AM
    #4381
    Marbleyard
    Marbleyard Thread killer
    Virginia
    2019 4Runner Pro
    SOLD 2016 taco: premium technology and tow package. OV Tune 1.05; A.R.E. V Camper Shell; BRO grille & Tails; OEM bed mat; Xenon Depot HID headlight conversion; reflective gray tailgate letter inserts; GoPro session; Hondo radio knobs; K&N cold air intake, quicksand painted dash bezels, Subaru dash speakers, Kicker CS 6x9 fronts and 6.5 rear speakers; All LED interior lights and LED high-beam headlights. Redline elite hood shock props. prinsu cab and camper rack with rough country 30" light bar; (2) 8" rear facing “F.U.”rough country black LED lights; prinsu cargo basket kit, (2) prinsu load racks; roadshower 4; ARB 2500 awning and room kit; weather tech floor mats; carhart seat covers; ckma12 ARB air compressor under the hood; blue ridge overland gear air tools bag, tool bag, driver's seat molle. Rack mounted TRED 800 recovery treds and plano case. Rotopax water and fuelpax fuel canisters; Pelican cased first aid kit in bed. rockblokz mud flaps. ARB rear dif. breather. Stand alone fuse block. SSO bumper with 10k smittybilt synthetic line winch and factor55 ultrahook. Pro Eagle 2-Ton “The Beast” jack. OME lift kit: 90000 front shocks and 886 OME coils, Camburg 310078 UCA, 60091 rear shocks with light duty Dakar leafs. Good Year duratracs 285/75R16. Black vinyl inlays on factory OR wheels; RCI Steel Front/Trans/Trans Case/Rear Diff Skids, Alum A-Arm; Mobtown bolt-on sliders with scorpion bed coating; pelfreybilt aluminum fuel tank skid; Cali-Raised full length Molle storage LH & RH bed sides; Caliraised bedside reinforcements; HELLA sharptone horns; Optima blue-top battery with AJT machined red tiedown bracket. AJT quicksand key fob. Overland Bound member #6996
    :rofl:I'm still down, just still looking.
  2. Feb 25, 2017 at 4:10 AM
    #4382
    TRD-Merchant_Marine
    TRD-Merchant_Marine Well-Known Member
    Austin
    2014 White Tacoma TRD Sport DCLB
    Just Found this thread! I'm from Troy, just East of Charlottesville. I'd be down for meet and greets/mod days for sure! I'll be back stateside the end of April. I have a big ole pile of parts waiting for me so I can't wait!:cheers::mudding:
    Casper66, Marbleyard and Bsheriff11 like this.
  3. Mar 7, 2017 at 4:17 AM
    #4383
    Loganc08
    Loganc08 Well-Known Member
    Logan
    Charlottesville, VA
    2009 Black Tacoma AC TRD OR
    OME front and rear with 886s
    Yeeesss I really want to get these shocks filled and installed.
  4. Mar 11, 2017 at 5:54 AM
    #4384
    J_Hacker
    J_Hacker Well-Known Member
    Somewhere in Virginia
    '19 White Tundra Crewmax
    Bilstein 6112, CB +2 Shackles, Soft Topper, Method 316, 295’s
  5. Mar 11, 2017 at 8:00 AM
    #4385
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    Very hard to diagnose with just video sound. Id say go through and tighten everything that moves. LCA, shocks, UCA, etc look for rubs on the springs and metal surfaces? Maybe the uca is slightly rubbing the springs, just gonna have to get in there to make sure everything is torqued properly. Then retest.
  6. Mar 11, 2017 at 8:35 AM
    #4386
    J_Hacker
    That was going to be my first step and then go from there. I appreciate the help.
  7. Mar 11, 2017 at 8:38 AM
    #4387
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    Yea man check that stuff and then let me know what you find
    J_Hacker[QUOTED] likes this.
  8. Mar 11, 2017 at 8:44 AM
    #4388
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    I found a penny and a quarter this morning. That's what I found.
  9. Mar 11, 2017 at 11:03 AM
    #4389
    J_Hacker
    One thing that has crossed my mind, could I have not driven my ecgs bushing in far enough causing the cv axle to make noise? :notsure:
  10. Mar 11, 2017 at 11:33 AM
    #4390
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    Forgot you did that, def. Worth checking
  11. Mar 11, 2017 at 8:10 PM
    #4391
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    Although it seems like a passenger side issue so seriously doubt thats the problem. It may be more closely related to the LCA or UCA imo
    J_Hacker likes this.
  12. Mar 12, 2017 at 12:21 PM
    #4392
    J_Hacker
    Went through everything. Pulled the CV axle, egcs bushing was good and flush. Reinstalled everything. Torqued everything to spec or spec + a couple lbs. Still getting the noise. I believe I am goin to chock it up to my driver's side sway bar link. It is aftermarket Moog. From my memory the noise started about the time I replaced it. @Bsheriff11
  13. Mar 12, 2017 at 12:23 PM
    #4393
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    Make sure tie rod end and sway bar link is flush and the washer is on the correct side so the bolt doesnt have slack enough hava a slight wiggle.
    At least you have piece of mind that everything is on properly now though!
  14. Mar 12, 2017 at 12:27 PM
    #4394
    J_Hacker
    The sway bar link washer? I don't remember there being a washer on the tie rod end.
    I am relieved it is not something major. Piece of mind is good!
  15. Mar 12, 2017 at 12:30 PM
    #4395
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    Maybe, i dont have an aftermarket piece to compare, thought the moog ones had some but i guess not haha
  16. Mar 12, 2017 at 12:37 PM
    #4396
    J_Hacker
    The Moog does have a washer that goes on the sway bar link. I have it on the side without the bolt. Picture for reference red side is where I have the washer. Green side I do not have a washer.
    Bsheriff11[QUOTED] likes this.
  17. Mar 12, 2017 at 1:36 PM
    #4397
    TacoFMS
    Justin
    Louisa County, VA
    I believe the washer should be beside the nut, but I could be wrong.
  18. Mar 14, 2017 at 9:55 AM
    #4398
    J_Hacker
    Well bad news, the noise has returned and is louder than ever. It is now more of a loud pop when turning and hitting a bump at the same time. Still have no clue what it is. Unfortunately I got back to work tomorrow for a 4 day stretch guess I'll spend those days pondering a fix :frusty::frusty:
  19. Mar 14, 2017 at 10:53 AM
    #4399
    TacoFMS
    Justin
    Louisa County, VA
    CV axle???? :notsure:
  20. Mar 14, 2017 at 10:59 AM
    #4400
    J_Hacker
    I am thinking that is what it may be. Maybe something inside the boot broken that I can't see. Not sure if I should just replace it or what. Gonna have to wait til Sunday though.
