Calling all Toyota owners in the Lynchburg and Charlottesville and surrounding areas!
Discussion in 'South East' started by VAYoder4167, Jan 6, 2014.
  1. Feb 7, 2014 at 5:26 PM
    #501
    Taylor
    Taylor Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Hey guys drinking in the dorm if you want to join ;D
  2. Feb 7, 2014 at 5:29 PM
    #502
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    Not sure about 1st gens but I know that for us 2nd gens a diff drop kit typically isn't needed for only 2-3" lift.. Just a thought Frank
  3. Feb 7, 2014 at 5:37 PM
    #503
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    I think it's pretty much needed for 3 inches on a first gen.
  4. Feb 7, 2014 at 5:37 PM
    #504
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    Yep good point, no diff drop needed for less than 3" of lift for 1st or 2nd gens
  5. Feb 7, 2014 at 5:39 PM
    #505
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    The diff drops change the cv angles pretty bad, I wouldn't think 3 or under would need one, but then again, I don't have a first gen!
  6. Feb 7, 2014 at 5:53 PM
    #506
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    The good ole days haha
  7. Feb 7, 2014 at 5:57 PM
    #507
    VAYoder4167
    VAYoder4167 [OP] Well-Known Member
    Frank
    Lynchburg, VA
    Lifted 04 toyota tacoma sr-5
    Magnaflow dual catback exhaust, 5100 bilsteins all around with 1" body lift and stock coils, 33" BF Goodrich sitting on a set of 15" Alloy Ion wheels
    On the first gens the diff drop is needed for over 3". Taylor check them out they will work with you and Robert and Marie will answer any questions you have.
  8. Feb 7, 2014 at 7:04 PM
    #508
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    My diff drop actually came in today to the post office here on Campus.
    What do you mean "changes them bad" ?
    The lift changes them, the diff drop helps by lessening the angle.
  9. Feb 7, 2014 at 7:19 PM
    #509
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    I didn't mean in a "bad" way, well, for the 2nd gens it's a bad option, but it changes the angles (lessens) in first gens more so than other options that would correct cv angles. which is why it would be more appropriate for more than 3" lift, surely won't bother having it if you have say 2.75" lift, but there are better options at that amount if I understand it correctly.
    I know some have developed vibes with it.
    Basically, the diff drop can prolong the life of your cv's by lessening angles, but isn't necessary, and can in some cases be inappropriate for the application.
  10. Feb 7, 2014 at 7:57 PM
    #510
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    If you plan on running skids don't do the diff drop.
  11. Feb 7, 2014 at 8:37 PM
    #511
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    Can't you just get longer bolts and washers, maybe make a little bigger hole in the skid to fit it? There are some companies skids that will work with diff drops, others you have to modify I believe
  12. Feb 7, 2014 at 9:09 PM
    #512
    NewRider
    Travis
    '87 4runner
    Haha, I remember those days... Havin to think a little about an RA :cool:
    I almost got my fenders fixed completely guys.. Little more work tomorrow to make everything pretty then it'll be ready for paint!
    Also gonna be fixing my broken rear fender flare as well as mounting my fogs in the allpro.. Busy day but it should be awesome!
  13. Feb 7, 2014 at 9:11 PM
    #513
    NewRider
    Travis
    '87 4runner
    Not exactly. The problem is that with the stock mounting points the skid actually never makes contact with the front diff mounting bolts. When you do the drop those are now lower than the skid attachment points so it doesn't fit. Outing in longer bolts would hold it in place sure but not very securely.
  14. Feb 7, 2014 at 11:04 PM
    #514
    VAYoder4167
    Frank
    Lynchburg, VA
    I may or may not do the diff drop cuz no plan on getting skid here in the near future. We will see how it goes. Just bored at work till 6 so might be postin stupid stuff.
  15. Feb 8, 2014 at 2:00 AM
    #515
    VAYoder4167
    Frank
    Lynchburg, VA
    5 o'clock boredom. Sorry fellas.
  16. Feb 8, 2014 at 3:26 AM
    #516
    eaglesfn5402
    eaglesfn5402 Well-Known Member
    ordering a set of 285/75R16 general grabber at2s within the week, scs estimated a 60-90 day wait to get the matte black f-5s back in stock. that's ok though because I should have more money for them by then.
  17. Feb 8, 2014 at 4:29 AM
    #517
    ckeene9
    Chesterfield, VA
    See Build Thread
    Not sure of anyone that makes skids for diff drops. Yes you could space them down but now you're increasing the arm length and have a greater chance of shearing the mounting bolts off.
  18. Feb 8, 2014 at 5:49 AM
    #518
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    Oh I see, thanks.
  19. Feb 8, 2014 at 7:27 AM
    #519
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Wait, are you guys talking about second gens only, here? I bought a diff drop off of somebody on here and I want to use it after I lift it. I thought they made tons of first gen skids for diff drops?
    Also, some guy sprayed the fire extinguisher everywhere last night...
  20. Feb 8, 2014 at 7:32 AM
    #520
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    I'm hoping it's a 6, because I get off work at 4:30
