Calling all transmission experts
Discussion in '1st Gen. Tacomas (1995-2004)' started by smmarine, May 2, 2014.
  1. May 2, 2014 at 9:34 PM
    smmarine
    smmarine [OP] Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Just wondering if I should be concerned with the slight hiss that my 99 Prerunner makes when lightly accelerating. It's magnified when I put more of a load on the truck, suck as towing or backing a boat in at very low speeds. Is this just some slippage on the trans that I'm hearing and shouldn't worry about it, or could it be more? It's done it for the whole year I've had it
  2. May 3, 2014 at 12:05 AM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Vacuum leak?
  3. May 3, 2014 at 12:10 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Hiss doesn't sound like slippage... and IMHO, slippage is not something to "not worry about" unless it is within the range of typical torque convertor "buffering" when unlocked.
    Slippage glazes the clutches, increases heat, burns fluid, and contaminates the fluid.
    Just like a manual trans, slipping never gets better until the clutch is replaced and the pressure plate is resurfaced (or in the case of an auto, "plates" and "replaced."
    But the trans is generally not going to slip when lightly accelerating. It'll generally slip under load.
  4. May 3, 2014 at 4:08 AM
    smmarine
    Melbourne FL
    I can faintly hear it when very lightly accelerating. Add some weight behind the truck, or try to slowly back a boat in while lightly accelerating, and it's louder. And that's exactly what the sound is like. Just a hiss, can't really explain it much better. Once I get up to speed it goes away, it's just the initial takeoff, or moving weight really slow
  5. May 3, 2014 at 4:24 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It could be anything ....not necessarily the transmission.
    How are your tires & tire pressure?
    How is your driveshaft? When was the last time you lubricated the zerks/ujoints?
    Have you put it into 4WD? Does it still hiss.....??
  6. May 3, 2014 at 4:30 AM
    smmarine
    Melbourne FL
    Tires are new and pressured up. Just greased the driveshaft. Don't have 4wd but I'll take it if your offering ;). It doesn't make the sound when you rev in park or neutral, only when in gear
