Calling all Virginians (Tidewater area)
Discussion in 'Virginia' started by Alaskaflyer, Dec 26, 2008.
  1. Mar 21, 2012 at 9:55 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    hes correct. the front diff is a automatic differential disconnect. so essentially, the differential disconnects from the axles? i just looked at a crap load of threads but cant remember. and yeah, it prolly is the drivers tire that recieves all the power. i read that somewhere a few days ago and i thought it was the passenger but i was skimming it and cant find it now
    and it doesnt lock both tires to pull, otherwise u wouldnt need a front locker like the ARB i have
  2. Mar 21, 2012 at 10:15 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    i put the front locker in and it fixed my vibe. i had it for a while and when replacing my front diff, the cv was fine and didnt have any crazy wear on it so we just reinstalled it. i went threw ecgs and got a new diff with arb already installed and sent them my old diff after the new one was installed
  3. Mar 22, 2012 at 4:38 AM
    Namyo
    Namyo -
  4. Mar 22, 2012 at 4:53 AM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    mornin bitches
  5. Mar 22, 2012 at 5:37 AM
    Namyo
    Namyo -
    Think I need a cap fer mah stereo :notsure: dono much about em...subs cut off for a bit when pushing them hard..
  6. Mar 22, 2012 at 5:38 AM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    Morning dudes and Dudettes! Gonna work a little late tonight since we skipped last night (forgot I had a family dinner!).
  7. Mar 22, 2012 at 6:14 AM
    Turd Herding Jim
    Turd Herding Jim What's wrong bro, DERPes flaring up?
    Big Jim
    Everett, WA
    07 SR5 4x4
    3" Icon Stage 3 lift, All Pro Off Road APEX front bumper, Amor Tech Off Road high clearance rear bumer, Armor Tech Off Road rock sliders. URD Short Shifter, HID Headlights, Level 8 Guardian Wheels, 285/75-16 Falken Rock Mountain ATS tires, 4.56's with front and rear ARB air lockers, BesTop Soft Cover
    cap or bigger, better amp with a greater cooling capacity. Had the same problems back in the day when I was all into stereo systems.
  8. Mar 22, 2012 at 7:02 AM
    wrmathis
    Bonaire, GA
    parts and stuff
    front diff was 1400 and my air supply stuff was 450
  9. Mar 22, 2012 at 7:09 AM
    Joben7726
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    what you meant to say was "worth the money" :cool:
  10. Mar 22, 2012 at 7:10 AM
    Namyo
    Namyo -
  11. Mar 22, 2012 at 7:17 AM
    Techoma
    Alta Mesa, AZ
    That sounds like an amp issue. The cap will stop the engine \ elecrical noise or "whine" if you have it.
    Makes me wonder... maybe if I installed a capacitor on my phone here at work... the whining I get would be reduced!!!! :D
  12. Mar 22, 2012 at 7:38 AM
    wrmathis
    Bonaire, GA
    parts and stuff
    yes.
  13. Mar 22, 2012 at 8:52 AM
    Namyo
    Namyo -
    Doesn't the cap just provide more volts to the amp when needed...like when it hits hard? That's three people say sounds like my amp needs to be replaced! :notsure: Seems to me it's just not getting enough food when maxed out...
    Pretty cool..still gotta get to gettin around inthere betta. Oh wait...fer the price...It's Awesome! :D
    wait...wut? :pout:
  14. Mar 22, 2012 at 8:58 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    Sorry Joe but def sounds like an amp problem... you would see your lights dim way down if you just needed a little juice. turn your headlights and interior lights on and jam out, if the amp cuts out before the lights dim out its more than a power issue
  15. Mar 22, 2012 at 9:00 AM
    Namyo
    Namyo -
    :thumbsup: will play radio loud moar to check it out...:D
  16. Mar 22, 2012 at 9:06 AM
    Burgman
    Stephen
    Ric VA
    not scientific at all but it should give you estimate of your power needs...
  17. Mar 22, 2012 at 9:07 AM
    wrmathis
    Bonaire, GA
    parts and stuff
    a cap is juts a band aid for a bigger problem. fix the bigger problem, then no need for a cap
  18. Mar 22, 2012 at 10:04 AM
    Namyo
    Namyo -
    Maybe the ground :notsure: Screwed to the sheet metal under door threshold. Been like that for years but with new source, cleaner signal or sumting and I can turn up louder w/out distortion....bumped it at lunch and sub amp poped and cut off again :(
    At work mang :pout: nice as fuk out!
  19. Mar 22, 2012 at 10:14 AM
    wrmathis
    Bonaire, GA
    parts and stuff
    j0ej0e j00 could also be clipping your signal. try turnin the gains down on you amp a little bit and see if it changes. also make sure ur amp isnt overheating and i also would move your ground to something better
  20. Mar 22, 2012 at 10:41 AM
    Namyo
    Namyo -
    Yea I probably should tighten up the whole install, kinda messy :eek: I did have to turn the bass down to 0 and sub volume to -2 with the new deck....had it turned up before on the old deck. Dono bout over heat...happens pretty quick if you turn it up loud.
    Will try gain down some on the amp and tighten up ground.
