Calling all Virginians (Tidewater area)
Discussion in 'Virginia' started by Alaskaflyer, Dec 26, 2008.
  1. Mar 22, 2012 at 11:40 AM
    Turd Herding Jim
    Turd Herding Jim What's wrong bro, DERPes flaring up?
    Big Jim
    Everett, WA
    07 SR5 4x4
    3" Icon Stage 3 lift, All Pro Off Road APEX front bumper, Amor Tech Off Road high clearance rear bumer, Armor Tech Off Road rock sliders. URD Short Shifter, HID Headlights, Level 8 Guardian Wheels, 285/75-16 Falken Rock Mountain ATS tires, 4.56's with front and rear ARB air lockers, BesTop Soft Cover
    Go ahead and try relocating the ground and turning the gain down. that may work for awhile. If you want to really pound your subs buy the cap and that will help equalize the electrical load throughout the truck, i.e. headlights as well as other illuminated objects wont pulse every time it hits.
    Your best bet is to upgrade your amp brother, or possibly finding a new place to locate it so it has better "breathing" capabilities. Most good amps have overheating protection which will shut it down to prevent any further damage, DO NOT try and cheat that by upping the fuse(s) in the amp either or it will fry(been there done that). I've dealt with this issue in the past and the only thing that fixed it was getting a better amp, but when you do that you start blowing subs and the money pit gets deeper!
  2. Mar 22, 2012 at 12:02 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    he could easily have his gains to high making his subs clip. to me, thats what it sounds like its doing. and a cap wont fix that. also, just having a better ground is just a good idea, regardless of the situation.
    having a shitty amp could be a culprit of his problem and guess what, a cap aint going to fix that either.
    a cap is generally a band aid for problems. which can be fixed with a better alternator, batter (or even a second battery) and better wiring.
    j0ej0e, what kind of amp do u have?
  3. Mar 22, 2012 at 12:11 PM
    Turd Herding Jim
    Big Jim
    Everett, WA
    07 SR5 4x4
    where is the "like" button?!
    It could also be an issue on how many subs he is running and how they are hooked up that could be causing the overheating
  4. Mar 22, 2012 at 12:38 PM
    Namyo
    Namyo -
  5. Mar 22, 2012 at 1:17 PM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
  6. Mar 22, 2012 at 2:12 PM
    Turd Herding Jim
    Big Jim
    Everett, WA
    07 SR5 4x4
    @JoeJoe
    from what I can tell from this picture of your amp, is if you are running 2 of those 12" W6V2's and only have 1 cable set(positive and negative) running from your sub box into the right side of the amp where you hook them up, then you are asking the amp to push a whole lot of power to those monster subs which would cause it to automatically turn off to cool down. Now if you were to wire one sub's +&- wires to one amp hook up and the other sub to the 2nd +&- amp hook up you should be fine. Better to have less total power running to each sub for sound quality and amp longevity IMHO.
    If you really want to go balls deep, buy another one of those JL audio amps and bridge them together and have one amp per sub!
    *to anybody else reading this, if I'm way off with this let me know please. I'm by no means an expert, just a been there done that kind of thing.
  7. Mar 22, 2012 at 2:21 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    i think u might be off a little. he has dvc subs. which means if they are 4 ohm DVC then u will get either 2 or 8 ohms out of one sub. depending on if u wire that sub up in paralel or in series. with both subs he could have 1 ohm, 4 ohm, or some other combination. anyways thats the theory kinda
    here is a mono amp runnin to subs. the subs are in parallel to each other, but the DVC's are wired in series. this is a 4ohm setup
    here is a mono amp runnin two subs. the subs are in parallel to each other and the DVC's are wire in parallel also. this is a 1ohm setup
    now if u had a mono amp, runnin two subs, with the subs in series to each other, but the dvc's in parallel, u will have a 2 ohm setup. i dont have the diagram for this, but not sure if its totally possible either
  8. Mar 22, 2012 at 2:30 PM
    Turd Herding Jim
    Big Jim
    Everett, WA
    07 SR5 4x4
    yup, when you start using big words like ohms, you lose me lol. My vote goes to dropping the extra $500 for another JL Audio 500/1 amp, bridge them together 1 amp per sub and blow your windows out, or women's clothes off, or turn your brain to mush, whichever he prefers
  9. Mar 22, 2012 at 2:40 PM
    Turd Herding Jim
    Big Jim
    Everett, WA
    07 SR5 4x4
    duty/hangover day :annoyed:
  10. Mar 22, 2012 at 2:42 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    heres the real question... if i have 2 old SPL subs that i have no idea of their impedance how do i wire them up in my friends car?
  11. Mar 22, 2012 at 3:06 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    uh, do whatever u can to find impedence and where they are SVC or DVC? it isnt on the magnet? personally, i bet they are 4 ohm svc. in that case, put them in parallel to get a 2ohm load if ur amp can handle 2ohm.
  12. Mar 22, 2012 at 3:10 PM
    Burgman
    Stephen
    Ric VA
    DVC. This should help the amp that they were originally wire to is a 4 ohm 4 channel amp. it was bridged to 2 channels to each sub.
  13. Mar 22, 2012 at 3:24 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    thats what i would go with
  14. Mar 22, 2012 at 3:31 PM
    Turd Herding Jim
    Big Jim
    Everett, WA
    07 SR5 4x4
    did that ebay parking brake bypass come in already?! if so let me know if it actually worked!!
  15. Mar 22, 2012 at 3:35 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    Sat is da way to get er done:thumbsup:
  16. Mar 22, 2012 at 3:38 PM
    Namyo
    Namyo -
    +/- to one sub and the other +/- to the other...god knows what's going on in the box...but them is not hooked together as the box is sealed in between. Should be 250 to each sub :notsure: Been like that for years....
  17. Mar 22, 2012 at 5:15 PM
    Namyo
    Namyo -
    bow chicka boaw boaw! :rockband:
  18. Mar 22, 2012 at 5:20 PM
    Namyo
    Namyo -
    Why you no have album foto? anybody kno how to get the album art? I has like 10,000 songs with the same foto!:goingcrazy:
    corrupted wif dis :confused:
    wtf is that anyway:confused:
  19. Mar 22, 2012 at 5:27 PM
    Namyo
    Namyo -
    punk ass lundon boyies sent me sum shiyt that corrupted mah album art :mad: das what happened!
  20. Mar 22, 2012 at 5:30 PM
    Nolawall
    Nolawall "And there I was just minding my own business"
    Nick
    Virginia Beach
    2002 Dbl Cab Tacoma
    6" Fabtech Suspension Lift. K&N Air Filter Cobra 18 CB with 2 3' firestik II antennas
    What's up fellas how's it going?
