Calling all Virginians (Tidewater area)
Discussion in 'Virginia' started by Alaskaflyer, Dec 26, 2008.
  1. Feb 8, 2013 at 7:23 PM
    rjsimz
    rjsimz Well-Known Member
    Rob
    Huntersville, NC
    13 4x4 DCLB
    Thanks guys
  2. Feb 8, 2013 at 7:23 PM
    rjsimz
    Rob
    Huntersville, NC
    13 4x4 DCLB
    Looks badass!
  3. Feb 8, 2013 at 7:24 PM
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    about to get hammered up there!
  4. Feb 8, 2013 at 7:33 PM
    757 Taco
    757 Taco StormTrooper
    Tyler
    757
    2022 DCLB TRD Sport Premium 4x4 Ice Cap
    - Digital Fit WeatherTechs - Recovery Hitch Shackle - LED Map Lights - LED License Plate Bulbs - TRD License Plate Brackets - Front Recovery Shackle - Toyota Bed Mat -OEM Mudflaps -OEM Black emblem overlays - Removed front air dam - Goodyear Duratracs 265/75/16 - TRD Pro wheels
    Working on it. Already about 10". Supposed to get 2-3 feet
  5. Feb 8, 2013 at 7:34 PM
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    you can keep all of it :p
  6. Feb 8, 2013 at 10:42 PM
    sebassusmc
    sebassusmc Well-Known Member
    kevin
    va beach
    09 dub cab trd
    fox's on all 4 corners, expo leafs, BHLM D2S retro fit, custom grill, black out badges, lower bumper plasti- dipped........
  7. Feb 8, 2013 at 10:56 PM
    sebassusmc
    kevin
    va beach
    09 dub cab trd
    Alright so after that snow we had i tore a cv boot, so i took it in to let CB do it im not down for rolling in the snow ya know. i told them to do an oil change while they were at it. i get it back later that night right before they closed. when it started it seemed weird jumper passed 2k rpm and didnt drop:confused: i just shrugged it off i get down the road and it start sputtering and throws a check engine light. so i went back and they said to bring it back in the am, so i did i get a call bout 2 hours later saying from Steve the mechanic that i need spark plugs,carbon flush and MAFS about $500 worth of BS. mind you my truck was running perfect and never thrown a code. i told them it was bs and they need to fix it or have legal issues. they said they didnt care and they would not fix it for free. so i told them to leave in be and id pick it up soon. i pick it up and its running great but still has the codes. took it to a buddies and had him run the comp for bout 30 min all good. scam avoided and 500 saved
  8. Feb 8, 2013 at 10:59 PM
    dossfatboy
    dossfatboy Well-Known Member
    Gloucester, Virginia
    2011 Double Cab TRD 4x4
    I was considering the cab mount chop and now I have another question. My current lift is the toytec Bilstein Adjustable lift kit with 5100 shocks and the LR UCA's. Is there something I can add to that for another 1" to 1.5" lift that won't change the current ride? I would like to add wheel spacers and at the same time stop the rubbing of the cab mount and the front fender well rub at the same time.
  9. Feb 9, 2013 at 12:00 AM
    sebassusmc
    kevin
    va beach
    09 dub cab trd
    diff off set rims if you have stocks. if you add a top plate from what i know it makes the ride alot worse.
  10. Feb 9, 2013 at 4:24 AM
    757 Taco
    Tyler
    757
    already pulled out a 4x4 wrangler :cool:
  11. Feb 9, 2013 at 4:38 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    What codes? Check the oil level in case they forgot to drain before adding new oil.
  12. Feb 9, 2013 at 5:54 AM
    757 Taco
    Tyler
    757
  13. Feb 9, 2013 at 6:11 AM
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    X2 on the wheels to eliminate need for spacers. What are the 5100's set at right now and what coils are you using? As far as rub, ditch the mud flaps if you haven't already and anything 285/75/16 (285/70/17) or bigger pretty well requires the cab mount chop if you want the rubbing gone.
  14. Feb 9, 2013 at 6:15 AM
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    He has brand new mickey thompson Classic Locks in black...i looked at his truck and saw where it was hitting and it was the edge of his tire on the cab mount...if he ran a spacer it would push it out enough to clear the mount but he would hit plastic..this is what i did on 285s so i just trimmed the plastic right there and was done......he has the toytec setup..Eibachs with 5100s not sure what they were set at but i believe they come preset at the .85" setting..at least mine did
  15. Feb 9, 2013 at 6:20 AM
    loco
    loco Who wants to ride my Brack Burrito???
    Phil
    Virginia Beach, VA
    1996 Diesel Land Cruiser AKA Brack Burrito
    Well its a land Cruiser with a diesel so I've got that going for me.
    Damn that is a pelting right there.
  16. Feb 9, 2013 at 6:22 AM
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    cut that plastic!
  17. Feb 9, 2013 at 6:40 AM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    2011 TRD SPORT 4X4 DC
    Cobra 29 WXNWBT, Devil Horns, ARB Bumper, Avid Stepbars, Homer Taco Satoshi thin lip grille, ICON UCA's, ICON EXT Travel up front with King 700# springs, Dakar heavy springs, sumo bump stops, with ICON VS 2.0 shocks in the rear, K&N Drop In, AVS Ventshades and Bugflector, Whelen SPS 660 emergency strobes, Redline Hood struts and tailgate EZdown, Illuminated 4X4 Switch, TRD Floor mats, Flyzeye LED lighting, Kragen 7" HID behind grille, Kragen 4" HID back up lights, Rigid SR Series 10" LEDx2 Elusive elements Lightbar, Firestik antenna, Rear Diff breather mod, Fogs anytime, Hitch Safe, OEM door sill strips, mryo mirror relocate bracket, Prinsu designs roof rack, Tepui Autana RTT, ARB Awning,Engo 10k winch synthetic, Blue seas fuse block and breaker, ARE Topper
    Dude! So :jellydance: ! TITS!
  18. Feb 9, 2013 at 6:52 AM
    757 Taco
    Tyler
    757
    if you click it i think the video will play
  19. Feb 9, 2013 at 7:08 AM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    bad ass!!!
  20. Feb 9, 2013 at 7:23 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    anyone show up at loco's house yet?
