Calling all Virginians (Tidewater area)
Discussion in 'Virginia' started by Alaskaflyer, Dec 26, 2008.
  1. Dec 16, 2013 at 8:36 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
  2. Dec 16, 2013 at 8:39 AM
    rbraddock
    rbraddock Well-Known Member
    Randy
    Hampton, VA
    13 DCSB
    6" ProComp lift from the dealer, slow build in progress
    If you look at Map 27 of the MVUM, Shoe Creek is Forest Road 263 and it runs into Meadow Lane. From there you turn left onto RT56, follow that through Montebello and jump on RT608 and the Blue Ridge Parkway. Down on your left there will be a turn off to Forest Road 162 (which is the Big Levels Trails) that you can take through to Coal Road. Only problem is Forest Road 162 has a seasonal restriction and closes 01/10 until 04/01.
  3. Dec 16, 2013 at 8:59 AM
    superwhite10
    superwhite10 Well-Known Member
    Garner, NC
  4. Dec 16, 2013 at 9:00 AM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Anything else nearby to add on that'll be open in January?
  5. Dec 16, 2013 at 9:05 AM
    rbraddock
    Randy
    Hampton, VA
    13 DCSB
    I'll take a look! I am putting all the trails on the MVUM into Backcountry Navigator just for the purpose of trip planning. My intention is to share it once complete; but I am only 13 of 59 maps complete at this point.
  6. Dec 16, 2013 at 9:09 AM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    Take em wit u. I'll get there like 6:30... unless you're staggering... I mean walking!
  7. Dec 16, 2013 at 9:43 AM
    VATACOEXP
    VATACOEXP Well-Known Member
    Jake
    Hampton, VA
    82 Hilux Flatbed.
    I'll be there this evening!!
    Matt is now our spotter for trails down in Jogia.
  8. Dec 16, 2013 at 9:56 AM
    m.reed.1
    m.reed.1 Well-Known Member
    Adam
    Sacramento, CA
    2015 MGM TACOMA TRD OFFROAD 4WD
    A few
    spelt it wrong, its JAWGA lol!
  9. Dec 16, 2013 at 9:57 AM
    m.reed.1
    Adam
    Sacramento, CA
    A few
    I'll be there, a little late but there... i get off at 7pm FTL
  10. Dec 16, 2013 at 10:08 AM
    rbraddock
    Randy
    Hampton, VA
    13 DCSB
    :rofl:
  11. Dec 16, 2013 at 10:13 AM
    VATACOEXP
    Jake
    Hampton, VA
    82 Hilux Flatbed.
    ARB compressor died this morning. I recall asking people not to all air up at once with it and then everybody airing up with it. Not the fuse either.
    Guess it's time for a dual compressor and tank.
    This is why I like wheeling with TW guys, nobody just assumes that they're going to use someone else's shit.
  12. Dec 16, 2013 at 10:17 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Are they not rebuildable?
    Only 50% duty cycle too...argh. How many trucks you refill?!?!?
  13. Dec 16, 2013 at 10:21 AM
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    What kind is it . High capacity or the twin setup
  14. Dec 16, 2013 at 10:24 AM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
  15. Dec 16, 2013 at 10:26 AM
    superwhite10
    Garner, NC
    shit i know i bummed off linwoods at flagpole. did his, mine and i think half of one other guy and it overheated iirc
  16. Dec 16, 2013 at 10:28 AM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Arb I'm assuming Single or dual?
  17. Dec 16, 2013 at 10:29 AM
    BradyT88
    BradyT88 Well-Known Member
    You sure it's dead? Btnewman and I are both running that same CKMA12 compressor and we have abused the hell of them with no issues yet. When you run them too hot they will shut off until they cool back down and once they do they kick back on. In Moab 2012, Ben aired up like 6 guys with his. We ran it til it shut itself off and then waited for it to kick back on and ran it til it shut off again and waited til it kicked back on and were able to air the last guy up before it shut off the 3rd time.
    As AaronArf said, a tank is pointless on an ARB compressor since they can only run up to 90 psi. Personally I think a tank is pointless on any OBA setup unless it is huge or you have a valve to close off the tank once it is empty. After doing some math, even a 5 gallon tank at 200 psi won't do more than 2 tires, if you are on 35's I think it will barely do one tire. After it is drained, you are now filling up the tire and the tank at the same time which can add a couple minutes or more to each tire fill time.
  18. Dec 16, 2013 at 10:30 AM
    superwhite10
    Garner, NC
    i believe his in a single with a 1 gal tank :confused: have to ask him to make sure
    and what he said^^^ thats the compressor slim has and that what we did, waited for it to cool and kept it going
  19. Dec 16, 2013 at 10:33 AM
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
  20. Dec 16, 2013 at 10:34 AM
    superwhite10
    Garner, NC
