Calling all Virginians (Tidewater area)
Discussion in 'Virginia' started by Alaskaflyer, Dec 26, 2008.
  1. Dec 22, 2013 at 5:44 AM
    VATACOEXP
    VATACOEXP Well-Known Member
    Jake
    Hampton, VA
    82 Hilux Flatbed.
    Also anybody have a nest thermostat?
  2. Dec 22, 2013 at 6:38 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Gimmick you'll use for awhile and forget about. They look cool though. Just get a timer thermostat and set your days of the week accordingly.
    Edit : some utility companies even give programmable thermostats for free if you ask/request one.
  3. Dec 22, 2013 at 6:43 AM
    VATACOEXP
    Jake
    Hampton, VA
    82 Hilux Flatbed.
    Need to either get a bedrack kit ordered or put in an order for one built locally before the 1st.
    Not going to do me any good sitting in the spare room.
  4. Dec 22, 2013 at 7:04 AM
    VATACOEXP
    Jake
    Hampton, VA
    82 Hilux Flatbed.
    Good to have options. Got a guy in NN who can weld it together once I have the pieces, and if ANB will set it up the way I want I'll probably just go that route. $425 shipped and then a case of beer for my buddy and I'll be set. Would still rather have it made out of Aluminum though.
    May give my dad's top shop guy a call before I pull the trigger. Would rather spend an extra 2-300 bucks and not have to worry about rust.
  5. Dec 22, 2013 at 7:08 AM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Good idea....considering that's what you'd spend for powder coat.
  6. Dec 22, 2013 at 7:16 AM
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    coming back from church threw p0776 an p2714 codes :(
  7. Dec 22, 2013 at 7:20 AM
    VATACOEXP
    Jake
    Hampton, VA
    82 Hilux Flatbed.
    Oh that's bad
  8. Dec 22, 2013 at 7:24 AM
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    pressure control solenoids B and D
  9. Dec 22, 2013 at 7:40 AM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Might try to wire up my switch inside the cab today for my D2's. Where are you guys tapping into your dimmer circuit? I know some guys use the shifter light but I'm mounting the switch on the left hand side near the trac/inverter factory switch. Gotta be an easy wire around there.
  10. Dec 22, 2013 at 7:43 AM
    VATACOEXP
    Jake
    Hampton, VA
    82 Hilux Flatbed.
    I'm lost what are you trying to do?
  11. Dec 22, 2013 at 7:44 AM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    For the independent light on the Carling switches, you can tap into your factory dimmer circuit. (Comes on when you turn headlights on) The dependent indicator comes on when you switch power to whatever it is that your switching.
  12. Dec 22, 2013 at 7:49 AM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    yep, hood mounts are where my D2's are. Both of those are pretty quick mods,shouldn't take too long! what kind of tubing are you using for your rear diff?
  13. Dec 22, 2013 at 8:33 AM
    DaveEli
    DaveEli Well- Known Member
    David
    Virginia Beach
    2011 Tacoma Sport 4X4
    Icon Extended Travel Coilovers, King 700lb springs, All-Pro Expo leaf springs, All-pro U-Bolt flip kit, Icon 2.0 Series custom length rear shocks, Wheelers Superbump Bumpstops, All-Pro extended rear brake lines, Warn 86255 VR10000 10,000 lb winch, Warn 90287 wireless remote, Redline Hood Struts, AVS Bugflector II, Pelfreybilt front bumper with Rigid 92031 SR- Series White 20" Spot/Flood lightbar, Brute Force rear bumper with short swingarm, Famous Fabrication Rock Sliders, Pelfreybilt Skid Plates, Rigid 50231 D2 Driving Lights, Rigid 20221 Dually Spotlights, Rigid 98000 SR-M backup lights, ARB CKMTA12 "12V"on-board twin high performance air compressor, Dick Cepek DC-2 17x9" wheels, 285/70R17 Goodyear MTRs with Kevlar tires, Wet Okole seat covers,Airflow snorkle, ARE CX HD cap, Front Runner Slimline II cap rack, TRD cat back exhaust, AVS in channel window vents, Toyota door sill protectors, Pop & Lock tailgate lock, Husky Rear floorliners, WeatherTech Front Floorliners, DeeZee bed mat, Window tint, TRD drop in air filter, Plasmaglow led bed lights, Hi-Lift jack mounted on bed rail, IMMRYO Rear View Mirror Relocate, ARB 63 Quart fridge freezer, Arb ARB209 Snatch Block, ARB ARB730US 3" x 10' Tree saver, ARB ARB705US 2-3/8" x 30' recovery strap, Bubba Rope 7/8" x 30' original rope 28600 lbs, Bubba Rope Gator Jaw soft shackle 7/16.
    Been using some Plastidip spray, and the nozzels have gotten clogged. One can came that way. Anything I can soak them in that won't melt the nozzels?
  14. Dec 22, 2013 at 8:39 AM
    757 Taco
    757 Taco StormTrooper
    Tyler
    757
    2022 DCLB TRD Sport Premium 4x4 Ice Cap
    - Digital Fit WeatherTechs - Recovery Hitch Shackle - LED Map Lights - LED License Plate Bulbs - TRD License Plate Brackets - Front Recovery Shackle - Toyota Bed Mat -OEM Mudflaps -OEM Black emblem overlays - Removed front air dam - Goodyear Duratracs 265/75/16 - TRD Pro wheels
    Paint thinner, acetone, gas...
  15. Dec 22, 2013 at 8:51 AM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Anybody thats considering the Eddy rack please do a little research before buying. Looks like some members had some possible issues this year with him.
  16. Dec 22, 2013 at 8:57 AM
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    Think there are two different eddies. One from SC as far as I know is cool, dude making soft toppers is not
  17. Dec 22, 2013 at 9:03 AM
    ckeene9
    Chesterfield, VA
    See Build Thread
    Ahhh whoopsie, disregard then.
  18. Dec 22, 2013 at 9:04 AM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    :goingcrazy: Wiring.
    I want to do a clean install and minimize rework for future expansion.
    Anyone think this is overboard?
    Run a dedicated power wire ~14-16G thats on a relay off a 12v "ign" source from under the hood to inside the cab for all of my aftermarket switches 12v power.
    Then run a multi-conducter jacketed 8 or 10 "trigger" wire set up from my switches location in the cab to under the hood for future expansion for more relays.
    = Clean install and easy installation of more stuff
  19. Dec 22, 2013 at 9:21 AM
    VATACOEXP
    Jake
    Hampton, VA
    82 Hilux Flatbed.
    Or just do S-Pod
  20. Dec 22, 2013 at 9:25 AM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    expensive. :rolleyes:
