Calling all Virginians (Tidewater area)
Discussion in 'Virginia' started by Alaskaflyer, Dec 26, 2008.
  1. Feb 5, 2014 at 4:55 AM
    rbraddock
    rbraddock Well-Known Member
    Randy
    Hampton, VA
    13 DCSB
    6" ProComp lift from the dealer, slow build in progress
    How does 1000 sound?
    Spend sometime thinking about the toolbox, I'm sure there is a way to make it work. Do you have the stuff to do the wiring? Let's do it!
  2. Feb 5, 2014 at 5:25 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Ur welcome for the other stuff :p
  3. Feb 5, 2014 at 5:32 AM
    VATACOEXP
    VATACOEXP Well-Known Member
    Jake
    Hampton, VA
    82 Hilux Flatbed.
    Some of the stuff I have, other stuff I need to source. Rigids and mini lights will be in today, so I'll start figuring out how far I need to extend lines and then get a parts list together.
    So far I know that I need the bed lights to come on with a switch from the cab and a switch in the bed.
    Dually's need to be tapped into reverse lights and a switch in the bed and a switch in the cab?? Probably going to be the most complicated setup here,
    Then the awning light strip is just going to be fed by a switch at the bed.
  4. Feb 5, 2014 at 9:47 AM
    Scalded_Dawg
    Scalded_Dawg Not as new as my post count would appear
    Brent
    Yorktown, VA
    Stripped Steel and Sex Appeal
    Tacoma daily and 4Runner to play
    Sounds good… guess I'm hosting a mod day this weekend.
    1000 Saturday, PM me for the address if you want/plan to come by.
    Only enough room to work on about three vehicles at one time; and pending weather only one will fit into the garage.
    I personally don't have any projects with all required pieces to work on, so it'll be all help from me.
    1) RBraddock - CMC and Slider fab
    2) VATACOEXP - Possible light wiring fiasco?? LOL!
    3)
  5. Feb 5, 2014 at 10:27 AM
    VATACOEXP
    Jake
    Hampton, VA
    82 Hilux Flatbed.
    I'll be there, but I probably won't be ready to wire anything light wise. Do need to finish my CB install though.
  6. Feb 5, 2014 at 3:17 PM
    tweeter1148
    tweeter1148 Well-Known Member
    Brandon
    Fort Worth, TX
    19 DBL CAB SHORT BED TRD OFF ROAD
    Does anyone know the best place to get an OEM roof rack or have one for sale?...thanks
  7. Feb 5, 2014 at 4:15 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  8. Feb 5, 2014 at 4:48 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Id like to show up in the morning but wont be able to stay long. You have a tap kit?
  9. Feb 5, 2014 at 4:53 PM
    Scalded_Dawg
    Brent
    Yorktown, VA
    I have two of them but they are both standard sizes, no metric :(
  10. Feb 5, 2014 at 4:55 PM
    rbraddock
    Randy
    Hampton, VA
    13 DCSB
    What size do you need? I can check to see if I have the right size. If not HF has a cheap kit and Northern sells individually
  11. Feb 5, 2014 at 5:02 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I need standard :D
    Not sure yet... Im in CA on a last min business trip. Depending on my flight time, Ill try to get a size Friday.
    Never mind, wife is going to a bridal shower so I have the kids... :(
  12. Feb 5, 2014 at 7:20 PM
    RFCsTaco
    RFCsTaco Member
    Randy
    Virginia Beach
    '05 Prerunner SR5 Access Cab
    :notsure:
    hey fellas, long time lurker here on the forums, haven't contributed a whole lot as my truck is bone stock, but awesome to see the mods you guys and gals do... I am in need of some advice, my '05 Taco 2wd Cab shakes/shudders alittle at speeds above 35 and worsens considerably after 45. Also if I come to a quick stop, then hit the gas, the truck pauses and lurches forward, sometimes squealing the tires, just a quick history on the truck...I bought the truck used last May from CB Toyota, it had 94000 miles on it and currently has alittle over 100,000 miles so I don't know a whole lot of prior services performed. From the few threads I have read, this issue seems to be more common than not, but I haven't found anything definitive as to resolving the issue, if a warranty covers transmission, etc..most threads say take to a reputable transmission shop to have fixed. Has anyone experienced this? and can someone point me in the direction to get my truck back in order...I appreciate any help you guys can give and thanks for the read...Randy
  13. Feb 5, 2014 at 7:50 PM
    m.reed.1
    m.reed.1 Well-Known Member
    Adam
    Sacramento, CA
    2015 MGM TACOMA TRD OFFROAD 4WD
    A few
  14. Feb 5, 2014 at 7:51 PM
    m.reed.1
    Adam
    Sacramento, CA
    A few
    I might possibly be there before work if i can't get this compressor problem fixed...
    http://www.tacomaworld.com/forum/technical-chat/314451-arb-ckma12-problems.html#post8145054
  15. Feb 5, 2014 at 8:06 PM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Probably the dude that made the harnesses fault! :anonymous:
    Borrow Jake's pressure switch and test it. If its not that it's gotta be the logic board/thermal overload on the compressor. I dunno though, I'd call ARB and see if they have encountered this issue. It's very easy to replicate so it should be simple to narrow it down. Also need to get a meter on there to see the draw throughout the whole cycle up until fuse pop.
  16. Feb 5, 2014 at 8:24 PM
    RFCsTaco
    RFCsTaco Member
    Randy
    Virginia Beach
    Thanks Bandit, I'm gonna try this first...
  17. Feb 5, 2014 at 9:27 PM
    LukeBo4x4
    LukeBo4x4 The more people I meet, the more I like my dogs.
    luke
    Big Island,Virginia
    03 TRD ext cab
    OME 882s, wheelers 5 leaf pack w/aal, ARB front bumper, 305/70/16 nitto mud grapplers,pro comp 7069s, Grey wire mod.
  18. Feb 6, 2014 at 3:14 AM
    jdhaas3
    jdhaas3 Well-Known Member
    Jimmy
    Virginia
    Jeep Rubicon
    Durango front bumper, Warn Dual Force Powerplant HP winch with synthetic line, 3.5 AE lift, regeared to 4.88, ARB diff cover
    Have you changed the transmission fluid? The first thing I did when I got my jeep was changed the transmission and oil, you can only take the PO or dealers word so far. New transmissions are very picky, if they put the wrong fluid in there that alone could cause issues. Start with the cheap fixes first...I know this from experience.
  19. Feb 6, 2014 at 6:56 AM
    VATACOEXP
    Jake
    Hampton, VA
    82 Hilux Flatbed.
    Guess who didn't get shipping info again.
    Avoid that guy like the goddamn plague
  20. Feb 6, 2014 at 7:00 AM
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    How? What company?
