Calling all Virginians (Tidewater area)
Discussion in 'Virginia' started by Alaskaflyer, Dec 26, 2008.
  1. Mar 13, 2014 at 8:42 AM
    Rons01TRD
    Rons01TRD Well-Known Member
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    I'm interested in the bed topper maybe the front bumper. Pics if possible.
  2. Mar 13, 2014 at 8:54 AM
    Enders Taco
    Enders Taco Well-Known Member
    Ben
    Hampton Roads VA
    DCSB 4x4 6SP
    All Pro APEX Front Bumper, All Pro Sliders, Icon Coilovers with rear shocks and add a leaf pack, URD short shifter, Pioneer X930BT Nav with Polk speakers
    Pics and info please
  3. Mar 13, 2014 at 9:10 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Factory bumper? What lift on the leafs and is it single or multi AAL?
  4. Mar 13, 2014 at 9:13 AM
    Enders Taco
    Ben
    Hampton Roads VA
    DCSB 4x4 6SP
    Someone whose had/has a fridge...
    I was wondering, is there any reason why they can't be mounted on their side? I know one side has a vent, but I was pondering this last night
  5. Mar 13, 2014 at 9:17 AM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    I've heard it's bad for the compressors. They are mounted a certain direction for vibration dampening.
  6. Mar 13, 2014 at 9:18 AM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    I don't think the oil would get to the compressor?
  7. Mar 13, 2014 at 9:18 AM
    Enders Taco
    Ben
    Hampton Roads VA
    DCSB 4x4 6SP
  8. Mar 13, 2014 at 9:32 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    this^^^
    its not a matter of the oil getting to the compressor, afterall that is where you want the oil, it is a matter of the oil leaving the compressor and either getting trapped on top of the piston in the compressor before start up when the hi and low side are equalized or just staying in the evap coil or equivalent and out of the compressor so that it is a dry start on the compressor and before the oil can feed back down the compressor going on lock down. for background, i used to build custom refrigerated cases like you see in grocery stores and gas stations, except the ones i built were all what is considered open air and ended up in whole foods, A&P's, or raceway/racetrack gas stations. I was a refrigeration supervisor and would have to help employees from time to time with this problem because a compressor had fallen on its side during storage and we had to right it and then go about the oil reclaimation process. this is a lot more extensive than a little fridge would need because it is going to be an all in one package where what i was working on was remote evap coils and anywhere from 1/2 hp to 10 hp compressors.
  9. Mar 13, 2014 at 9:35 AM
    ckeene9
    Chesterfield, VA
    See Build Thread
    Knew it was along those lines. Thanks for the insight, always like learning something new about items you use everyday.
  10. Mar 13, 2014 at 9:42 AM
    VATACOEXP
    VATACOEXP Well-Known Member
    Jake
    Hampton, VA
    82 Hilux Flatbed.
    And... I'm back up on the horse.
    Apparently my pimp hand is quite strong.
  11. Mar 13, 2014 at 9:47 AM
    TacoFMS
    Justin
    Louisa County, VA
    no problem, and sshhh! dont tell anyone i actually know something! it will ruin my plans. :D
  12. Mar 13, 2014 at 9:49 AM
    ckeene9
    Chesterfield, VA
    See Build Thread
    So is it true that it's good practice to allow your household fridge/freezer to stand for 24hrs before being turned on after moving?
  13. Mar 13, 2014 at 10:08 AM
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Its true for any ac system. The oil from the compressor gets into the lines... needs to settle back into the compressor so it dosnt burn up
  14. Mar 13, 2014 at 10:21 AM
    MadMtnMikey
    MadMtnMikey Well-Known Member
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    Ben, I don't want to clutter the board with Nissan talk. The car has been sitting and needs some work, I can provide pics and info though, it's something I had a hard time parting with, but reality set in a while back, and the wife's nagging. PM me and I'll throw you some details.
    I think it's a procomp AAL, single, got it from Toytec, was under $100. Had it on the truck for just over a year, Burg helped me install. Bumper is factory.
    Leafs will be coming out within the next 3 months, I've got the new ones, just waiting on a good time to do the work.
    Pics of Seadoo and Bed topper coming up.
    For the topper, just go to my build page, it's the same one, in the same condition, sitting on work horses in my backyard now
  15. Mar 13, 2014 at 10:28 AM
    Enders Taco
    Ben
    Hampton Roads VA
    DCSB 4x4 6SP
    Remember, women come and go, but an expo truck is forever
  16. Mar 13, 2014 at 10:46 AM
    Enders Taco
    Ben
    Hampton Roads VA
    DCSB 4x4 6SP
    I wonder if the evap system could be rotated.... Just how much custom work would it be
  17. Mar 13, 2014 at 11:10 AM
    TacoFMS
    Justin
    Louisa County, VA
    not worth it... at that point you might as well build an entire freezer/fridge out of your truck bed because it would end up taking about that much space to relocate the unit and such outside of the actual cooler/fridge. typically in things like that and mini fridges and even full size fridge or freezer, they are made to just barely fit the unit underneath in a certain way oriented a particular way and nothing else nor any variation... but if you wanted to purchase a compressor some copper and an evap coil i could prob gain access to some 507a refrigerant for a reasonable price and still have all my tools minus my leak detector and vacuum pump. but i can resolve that with soap bubbles and a cheapo vacuum pump from HB.
  18. Mar 13, 2014 at 11:47 AM
    Enders Taco
    Ben
    Hampton Roads VA
    DCSB 4x4 6SP
    That's for all the effort. Understand that it's not worth it
  19. Mar 13, 2014 at 1:00 PM
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
  20. Mar 13, 2014 at 1:45 PM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
