Calling all Virginians (Tidewater area)
Discussion in 'Virginia' started by Alaskaflyer, Dec 26, 2008.
  1. Nov 4, 2014 at 3:10 PM
    rbraddock
    rbraddock Well-Known Member
    Randy
    Hampton, VA
    13 DCSB
    6" ProComp lift from the dealer, slow build in progress
    Are you worried about frame stress/rust? I would be worried about adding all that weight and stress to a 20+ year old frame coupled with the added HP upfront. But it would make a slick spot for putting the drag chute; have to check the NHRA rule book.
  2. Nov 4, 2014 at 3:26 PM
    Scalded_Dawg
    Scalded_Dawg Not as new as my post count would appear
    Brent
    Yorktown, VA
    Stripped Steel and Sex Appeal
    Tacoma daily and 4Runner to play
    :ohsnap:
  3. Nov 4, 2014 at 3:41 PM
    MadMtnMikey
    MadMtnMikey Well-Known Member
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    Since the swingout is bolted to such a rigid bumper that would be bolted or welded to the frame I think it would be legal
  4. Nov 4, 2014 at 4:15 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Rear frame is boxed. No chute :rolleyes:
  5. Nov 4, 2014 at 4:18 PM
    rbraddock
    Randy
    Hampton, VA
    13 DCSB
    Good on the boxed frame...did Brent weld that?
    Thought chute was mandatory at strip...sorry! But you got to admit a chute on the swingout would be bad ass!
  6. Nov 4, 2014 at 4:20 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    No strip either :rolleyes:
    No, I did...
  7. Nov 4, 2014 at 4:25 PM
    rbraddock
    Randy
    Hampton, VA
    13 DCSB
    Wasn't there a whole conversation about you drag racing the truck awhile back?
    If not, my bad
  8. Nov 4, 2014 at 4:29 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    If there was Linwood started it... :rolleyes:
    Nope, just getting a little extra power for less $$$ and less heat, wear and tear than the TRD blower... Install is going to be a bit harder though...
  9. Nov 4, 2014 at 4:33 PM
    rbraddock
    Randy
    Hampton, VA
    13 DCSB
    Doesn't turbo compressor use exhaust gas as motive force for turbine? Seems to me there would be more heat vice less :confused:
  10. Nov 4, 2014 at 4:46 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Less intake heat as in less heat generated when compressing the air. The TRD blower is inefficient and doesn't have an intercooler and intake temps get pretty high. It also has a pinging issue in high gear/high load that you cant get rid of without pulling a lot of timing, running E-85, or installing meth injectors. Turbo intake temps should be much more manageable.
    Sure, heat under the hood might get higher with the turbo but I got that figured out. Oil cooler and water lines will keep it running cool and a heat blanket will help further manage the heat. Shouldn't get too much hotter than your typical TRD bower + headers setup :notsure:
  11. Nov 4, 2014 at 5:01 PM
    cdj1
    cdj1 Well-Known Member
    Clint
    Muuurville, TN
    97 Tacoma
    King Extended travel coilovers, 5100 Shocks, Daystar shackles,OME Leaf Springs,255/85/16, front diff drop, RAT skid plates, 4.56 gears, LSD in rear, Aussie locker in the front, Front Range Offroad twin sticks, trail gear/ Bash Fab rear bumper, elite off road front bumper and sliders, warn m8000 winch, in cab winch control
    Shit, here we go again...... :cool:
  12. Nov 4, 2014 at 5:11 PM
    rbraddock
    Randy
    Hampton, VA
    13 DCSB
    Your swingout started it...
  13. Nov 4, 2014 at 5:12 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Well no one has measured my intellect based off how many times Ive driven over a rock yet...
  14. Nov 4, 2014 at 5:15 PM
    VATACOEXP
    VATACOEXP Well-Known Member
    Jake
    Hampton, VA
    82 Hilux Flatbed.
    Oh for fucks sake. Turbo is never going to turbo, and I'll probably never get an FJ or any rig of any kind.
  15. Nov 4, 2014 at 5:17 PM
    rbraddock
    Randy
    Hampton, VA
    13 DCSB
    I would think it important to keep all under hood temperatures low...a modern engine is designed and modeled very precisely within a normal operating band with deviations outside of the design parameters effecting efficiency...that said is there compensation performed by hacking the ECU?
  16. Nov 4, 2014 at 5:18 PM
    rbraddock
    Randy
    Hampton, VA
    13 DCSB
    But if you do I want dibs on parts I'll post a deposit now...lol
  17. Nov 4, 2014 at 5:29 PM
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Shit.. all this talk is making me price out a supercharger
  18. Nov 4, 2014 at 6:12 PM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Do it!
  19. Nov 4, 2014 at 7:22 PM
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    Long travel first!
  20. Nov 5, 2014 at 3:02 AM
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    Good morning peeps! Supercharger!
