Calling all Virginians (Tidewater area)
Discussion in 'Virginia' started by Alaskaflyer, Dec 26, 2008.
  1. Feb 1, 2015 at 8:28 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Oddly enough, I've heard 4.56 for the 5-sp and 4.88 for the auto on 35's. I would think it was the other-way around but I believe the auto's OD gear is a bit taller than the 5sp's.
    Either way, I think both should work; 4.56 should be good and give a bit better MPG's and 4.88's a bit more power :notsure:
  2. Feb 2, 2015 at 5:28 AM
    Tanner757
    Tanner757 Well-Known Member
    Tanner
    virginia beach
    2003 tacoma v6 4door 4x4 swap
    new radio removed mudflaps weld typhoons bed lined bumper Cb radio air resenator removal flowmaster outlaw
    So this happened yesterday
    Getting alot closer
    Now just gotta hook up driveshafts, wires, radiator and get my hubs pressed in
  3. Feb 2, 2015 at 5:28 AM
    MadMtnMikey
    MadMtnMikey Well-Known Member
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    So you basically want to think of it in terms of a percentage... Manual OR auto, same rule applies, soooo, when you're going down the highway at cruising speed for 4.56, if your RPM is 2000 add 10% for stock size tires, your RPM to maintain same speed will go up 200, if you're running 33's that's 5% bigger for tire diameter so only add 5%. Final drive for manual is lower, and first gear might feel like more of a granny gear with 4.88's, not necessarily a bad thing. If you use the percentage rule, and find the factory ratio's for each gear, you can easily figure and have a rough idea of how it will affect RPMs in each gear. There's other complicated ways to do exact calculations, but percentage is easiest and it's still spot on if you do the math with the real numbers.
  4. Feb 2, 2015 at 8:35 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Sweet! You going to be free this weekend btw?
  5. Feb 2, 2015 at 8:38 AM
    Tanner757
    Tanner
    virginia beach
    I will hopefully be free sunday
    My boss has me working all day friday and saturday and im hopeing not sunday if he does i may call and tell him i cant come one of the days haha
  6. Feb 2, 2015 at 8:40 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Shit that sux. Hopefully Ill be done by Saturday though.
  7. Feb 2, 2015 at 8:43 AM
    Tanner757
    Tanner
    virginia beach
    Gotcha well if i end up taking off saturday ill message you and come help
    How much boost you plan on running once everythings ironed out and running decently?
  8. Feb 2, 2015 at 9:29 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Not sure. Dont like the size of this turbo and may go smaller. Probably around 8-10psi; no more than 300-350 at the crank.
  9. Feb 4, 2015 at 7:16 AM
    CorpsmanUp
    CorpsmanUp Well-Known Member
    Gibby
    Suffolk, VA
    2013 Taco DCLWB 6in lift 35s 4.56s, air lockers AP F&R bmpers warn 10k winch Rigid fogs & floods custom pro top shell
    6in procomp stage 2 lift with PC Coilovers, 35x12.50 Nitto MTs, Moto metal 18x10 with -44 offset HID and LED's everywhere, ladder bars, rear disk brake conversion, hood struts, K&N cold air intake, Flowmaster 40 series, pro comp skid plates, train horn, pa system, all silver trim inside painted black all pro apex front bumper with full hoops warn 10k winch, all pro high clearance rear bumper with custom door hinge tag holder, pro top custom windowless camper shell. ARB onboard air compressor, rear ARB air locker, 4.56 gears front and rear, waterport pressurized water system, pop and lock tailgate.
    Anyone have a vibration or shivering in your truck went you're in park or neutral idling? Goes away when I put it in drive. Just noticed a week or so ago and it's driving me nuts. I'm wondering if I've got something loose on the exhaust or maybe a torque converter bolt.
  10. Feb 6, 2015 at 9:41 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Doing turbo install tomorrow, can use some hands if anyone is free. Ill provide pizza and beer. Willing to help any other installs as well; will have two open spots in the driveway and plenty of room on the curb.
    Going to be a cold day but will be working in the garage and should have a heater going.
    PM if interested for address.
  11. Feb 6, 2015 at 6:47 PM
    99nmtaco
    99nmtaco Well-Known Member
    Patrick
    NM / VA
    2001 4 Runner
    ADS racing shocks ext travel front, ADS FJC piggyback shocks rear, Addicted Offroad front plate bumper, 4xinnovations rock sliders and rear plate bumper, SCS Stealth 6s
    PM'd
  12. Feb 7, 2015 at 7:37 AM
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Where's everyone at? Turbo install?
  13. Feb 7, 2015 at 8:08 AM
    99nmtaco
    Patrick
    NM / VA
    2001 4 Runner
    At home bein lazy lol! I PM'd him about helping with the turbo today but haven't heard back. Looks like you're having a taco party haha!
  14. Feb 7, 2015 at 8:53 AM
    skygear
    skygear                    
    No one told me. I would have brought the arsenal of tools and a few propane heaters,
  15. Feb 7, 2015 at 9:24 AM
    Scalded_Dawg
    Scalded_Dawg Not as new as my post count would appear
    Brent
    Yorktown, VA
    Stripped Steel and Sex Appeal
    Tacoma daily and 4Runner to play
    Uhhhh.... It's literally 5 posts back and he talked about it the page before that... :stirthepot:
  16. Feb 7, 2015 at 9:55 AM
    99nmtaco
    Patrick
    NM / VA
    2001 4 Runner
    Hows the rear bumper build goin brent?
  17. Feb 7, 2015 at 10:47 AM
    skygear
    skygear                    
    You are right. You know me, normally so consumed with projects I loose sight of things right in front of me. Lots of times these things are planned a couple weeks out. :p
  18. Feb 7, 2015 at 11:16 AM
    Scalded_Dawg
    Brent
    Yorktown, VA
    Still in cardboard mock-up... Been too busy with life to get back out there. Hope to finalize this weekend.
    I know man... Just giving you a hard time. I don't where you find time for TW with all your projects!
  19. Feb 7, 2015 at 11:18 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    No worries, the coupling I was sent was the wrong size. Going to be delayed yet another week. If you can make it, its been a while since you've last came around. Can def use your help.
  20. Feb 7, 2015 at 11:59 AM
    skygear
    skygear                    
    Any kids? Might make a weekend road trip and camp somewhere with the wife and kids.
