Calling all Virginians (Tidewater area)
Discussion in 'Virginia' started by Alaskaflyer, Dec 26, 2008.
  1. May 16, 2016 at 4:25 AM
    Patmac
    Patmac Well-Known Member
    Pat
    Chesapeake, VA
    14 TRD Sport
    20% tint, weather techs, icon stage 3. n-fab, bhlm, retrofits, SCS SR8, 285s
  2. May 16, 2016 at 12:12 PM
    Boone7531
    Boone7531 Well-Known Member
    2012 Tacoma dcsb 4x4
    5100 4 corners 885s 1/4 top spacer for drivers lean weavers 3 leaf progressive toyo atII
    Hey guys, just got my first Tacoma. 2012 do 4x4 base... Got everything to lift it.. 5100s etc. I can do the back but the front concerns me... Definite noob! Any suggestions advice etc. would help. I'm in vagina beach! And yes I said it.. Lol
    Techoma and Patmac like this.
  3. May 16, 2016 at 1:23 PM
    Patmac
    Pat
    Chesapeake, VA
    14 TRD Sport
    Easy work just get in there with a 14mm 17mm and 19mm you'll be done
  4. May 16, 2016 at 1:47 PM
    Boone7531
    What about the spring... That's the concern I have. As well as getting it in and out... Thanks for your reply!
  5. May 16, 2016 at 1:59 PM
    robertlhuffman049
    robertlhuffman049 Well-Known Member
    robert
    norfolk va
    02 sr5 tundra front bilsteins
    Front tundra bilstien 5100s
    Are you using the stock coil and the 5100s or aftermarket coil and bilsteins?
  6. May 16, 2016 at 2:08 PM
    Boone7531
    I will be using the stock coils set at 2.5
  7. May 16, 2016 at 2:11 PM
    robertlhuffman049
    robert
    norfolk va
    Gotcha. Well you can do the change 2 ways. One you can take the existing shock and coil out and take it to a shop and have them swap it out real quick. The safer way but it cost a few dollar. Worth it in my opinion. Or the other way would be is to rent a coil spring compressor and do it yourself. More dangerous but you could get the money back after you return the tool. It's really up to you if you want to mess with the springs yourself.
  8. May 16, 2016 at 2:13 PM
    Boone7531
    Do I have to remove the lca to get the strut out?
  9. May 16, 2016 at 2:14 PM
    robertlhuffman049
    robert
    norfolk va
    I have a first gen so it may be a bit different but I don't believe so. I'll send you a video link.
  10. May 16, 2016 at 2:19 PM
    Boone7531
    Sweet thanks!
  11. May 16, 2016 at 2:29 PM
    robertlhuffman049
    robert
    norfolk va
    https://youtu.be/X3_P06F2s-A
    Here you go dude. Careful with the hammer. Also. Use this for removal change your springs the way of your choice. Then reverse this to reinstall. Then get an alignment.
  12. May 16, 2016 at 2:29 PM
    Boone7531
    Thanks
  13. May 16, 2016 at 2:30 PM
    robertlhuffman049
    robert
    norfolk va
    Yea man. Just be careful with it if you do the spring yourself. I'm sure some of the other guys will chime in soon.
  14. May 16, 2016 at 3:15 PM
    Boone7531
    Yep... I probably should have gotten spacers... Would be less of a headache from what the video shows... Thanks again
  15. May 16, 2016 at 4:09 PM
    robertlhuffman049
    robert
    norfolk va
    No way. You went the right way. 5100s are way better than spacers.
  16. May 16, 2016 at 8:07 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    You only have to remove the UCA bolt that attaches to the spindle. I can have coils out in like 15 min each side at the most...
    m.reed.1 likes this.
  17. May 16, 2016 at 8:14 PM
    Michgnxj24
    Michgnxj24 Well-Known Member
    Virginia Beach
    2010 DCSB
    Jeraco Cap, Viair OBA
  18. May 16, 2016 at 8:49 PM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    Too many fun scary moments with rented compressors! Either take em to a shop, or use the jack method, which is what I prefer. I can't do em as fast as @Slimwood Shady , but 25 - 30 each side for sure!
    Slimwood Shady likes this.
  19. May 17, 2016 at 2:35 AM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    FTFY #moddaysupervisor
  20. May 17, 2016 at 2:58 AM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    NAILED IT. I read swimgoods post and was like LIES ALL LIES
