Calling all Virginians (Tidewater area)
Discussion in 'Virginia' started by Alaskaflyer, Dec 26, 2008.
  1. Jan 16, 2018 at 3:59 PM
    BMValentine
    BMValentine Opportunity favors those who are prepared.
    Brad
    Cincinnati
    1989 FJ62 Land Cruiser - getting further & further from stock…
    Keep us posted on those 37’s when I have been thinking of jumping up when I buy new tires. Currently on 35’s.
  2. Jan 16, 2018 at 4:11 PM
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    Those are some meats. I’m afraid to step up to 35s
  3. Jan 16, 2018 at 4:12 PM
    BMValentine
    Brad
    Cincinnati
    Re-gear and trim.
  4. Jan 16, 2018 at 4:23 PM
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    I need someone to do a cab mount relocation and I’m gonna do a 1in body lift and front glass
    CorpsmanUp likes this.
  5. Jan 16, 2018 at 6:35 PM
    CorpsmanUp
    CorpsmanUp Well-Known Member
    Gibby
    Suffolk, VA
    2013 Taco DCLWB 6in lift 35s 4.56s, air lockers AP F&R bmpers warn 10k winch Rigid fogs & floods custom pro top shell
    6in procomp stage 2 lift with PC Coilovers, 35x12.50 Nitto MTs, Moto metal 18x10 with -44 offset HID and LED's everywhere, ladder bars, rear disk brake conversion, hood struts, K&N cold air intake, Flowmaster 40 series, pro comp skid plates, train horn, pa system, all silver trim inside painted black all pro apex front bumper with full hoops warn 10k winch, all pro high clearance rear bumper with custom door hinge tag holder, pro top custom windowless camper shell. ARB onboard air compressor, rear ARB air locker, 4.56 gears front and rear, waterport pressurized water system, pop and lock tailgate.
    I’ll give them a holler. Was able to track down the guy who did it all new in May of 2014 but definitely seemed kinda shady... only check PH and Iron level (which I had already done) to which he replied wow your iron levels are off we need to replace the whole system....
    So do you know what may need to be serviced ? All this is new to me and not much info online that I can find and I’ve searched solidly for the last two days for hours and hours. Trying to get someone out here for a second opinion but no one likes to touch another persons work or products they don’t sell. Royal PITA!
    VA SOFTACO and Casper66[QUOTED] like this.
  6. Jan 16, 2018 at 6:43 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    The neutralizer tank and the iron removal tank should be serviceable. You need to make sure they are there should be a screw off cap on the top of the tank. If so turn your water off or switch to bypass. remove the cap and stick something down in the tank and see how much material is in it. probably none. Get a piece of hose and siphon the water out then fill the tanks to the point where you can touch it. Screw the cap back on and when your done with them run them through their cycle manually.
    See if you can find a brand on the system and they can tell you what is the proper material for each tank. Also see if there is a manual for it laying around. If you can find a manufacturer and model you can probably find a Youtube video on how to service. Or find an authorized dealer for that system with good reviews and get them to check it out. They make all these systems just a little different. Hope this helps a little
    VA SOFTACO likes this.
  7. Jan 16, 2018 at 6:52 PM
    CorpsmanUp
    Gibby
    Suffolk, VA
    That was kinda what I was leaning towards tryin as there are caps on the two of them just have to trace a mess of plumbing between the 4 different tanks that are there to find the bypass valves for each. In sharpie written on the tanks it says Terminox but there’s only one place that sales them on the whole internet lol which is called budget water and their outta state sent them an email I’ll see if I get a response from them. Something I read somewhere said that iron/maganese filters need to be serviced every 4-6 years which I’m at the lower end on that but kinda find anything on “servicing” and what exactly that entails I’m guessin something to do with the resin or something in them but could be way off...
    thanks for the info though I really do appreciate yalls help on here! I’ll see if I can give it a shot without being electrocuted Or flooding the basement tomorrow evening
    Casper66[QUOTED] likes this.
  8. Jan 16, 2018 at 6:56 PM
    CaliDevilDoc
    CaliDevilDoc Well-Known Member
    San Diego, CA
    2016 Barcelona Red TRD Off-Road 4x4. 1995 FZJ80
    OME nitrochargers, 886, and Dakars
    Hey all, I'm TAD/TDY to Portsmouth naval hospital til April. Anyone here a fisherman? I want to fish the coast but there's no fishing headboats running and I'm not sure about where are good spots to fish from shore.
    Scrat and CorpsmanUp like this.
  9. Jan 16, 2018 at 6:56 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Look at the top of the tanks and find where the water lines enter and exit and the bypass should be right there. The tanks aren't usually under prssure but very full of water. Have some towels handy just in case
    CorpsmanUp[QUOTED] likes this.
  10. Jan 16, 2018 at 7:05 PM
    CorpsmanUp
    Gibby
    Suffolk, VA
    Some decent brackish water fishin out off a pier at 4700 sleepyhole Road In Suffolk caught some good size drum a few eels and 2 rays last time I went. Best place I’ve found so far out here.
    You run into a Gibby at NMCP that’s my other half lol.
    Haha thanks that’s good to know wasn’t sure if they were pressurized or not.
    CaliDevilDoc[QUOTED] likes this.
  11. Jan 16, 2018 at 8:50 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Major blizzard on the way. A menacing 1" to 2" of that white stuff that paralyzes Hampton Roads as soon as the first flake lands is predicted to fall and accumulate this time around. :eek:
    Hopefully it will be enough to play in. :burnrubber:
    VA SOFTACO, Casper66 and Boogyman like this.
  12. Jan 17, 2018 at 3:29 AM
    VA SOFTACO
    VA SOFTACO ...because who buys hard tacos
    Beauregard
    Virginia Beach, VA
    2015 Tacoma MGM OR DCSB
    what do you mean "as soon as the first flake lands" they are already closing down the schools and bunkering down for a blizzard that will not start until around noon. The last storm was good, this one will be lame.
    o0oSHADOWo0o[QUOTED] likes this.
  13. Jan 17, 2018 at 9:35 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Doing a timing belt job next weekend. Anyone need a driveway and help, we can make a mod day out of it. PM me if you're interested.
    MattJakobs and 4x4runner2002 like this.
  14. Jan 17, 2018 at 2:22 PM
    Boogyman
    Phoenix
    Corpus Christi, TX
    VA SOFTACO and o0oSHADOWo0o like this.
  15. Jan 17, 2018 at 2:44 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    So I now know what northerners feel like when we freak out over a few inches. I'm in Gulfport MS for business and everything was pretty much canceled, base closed, etc... Yesterday the schools closed 2 hours early because temperature dropped to 33*...
    Last night we had a "snow storm" and I woke up to find out the Navy base closed. I took this picture around 1000 this morning:
    o0oSHADOWo0o, VA SOFTACO and Casper66 like this.
  16. Jan 17, 2018 at 2:52 PM
    Boogyman
    Phoenix
    Corpus Christi, TX
    They closed the coast guard base early today lol we’re on standby for tomorrow
  17. Jan 17, 2018 at 3:48 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    Yeah, I saw that. Everything already closing because of the 1 to 2 inches that we might get. :der:
    Aw hell, we might have a hurricane hit in august. We had all better go out right now and stock up on water, batteries, and go ahead and board up all of our windows. :rofl:
    VA SOFTACO[QUOTED] and MCDavis like this.
  18. Jan 17, 2018 at 4:23 PM
    4x4runner2002
    4x4runner2002 Well-Known Member
    Zach
    2002 4x4 limited
    suspension and armor
    There is barley enough snow to cover the ground and I saw 4 accidents on my way to get dinner, it’s a 10 min drive round trip. I don’t understand it.
    VA SOFTACO and Boogyman like this.
  19. Jan 17, 2018 at 4:28 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Its not so much the snow on the ground as it is the stupid in peoples head.
  20. Jan 17, 2018 at 4:31 PM
    4x4runner2002
    Zach
    2002 4x4 limited
    @BMValentine you hear anything about the base for tomorrow?
