Calling lift experts!!!
Discussion in 'Suspension' started by cluck024, Nov 22, 2010.
  1. Nov 22, 2010 at 5:15 PM
    cluck024
    cluck024 [OP] -cluck
    Robert
    Greenwood, Arkansas
    09 Prerunner TRD-OR DC Barcelona Red
    Blacked out badges, Anytime Fog Light Mod, Sockmonkey Decals and Third Brake Light Cover, Yellow fog lights, custom homelink install, Radflo 2.0 coilovers, LR UCA's, AAL, Moto Metal 957 matte black with Nitto Terra Grappler 285/70/17 shoes, more to come...
    First let me say I have searched and not found the exact answer Im searching for.
    I just got my lift (radflo co's and aal with lr uca's) installed today and Im having a few rubbing issues. I have alleviated most with cutting plastic but have one tire rubbing the cab mount while the other does not. Then there is the slight wandering over 55 or 60.
    My toe and camber are at 0.2, but my caster is not where I would like it to be. I told the alignment guy I wanted it to be around 2.4 and he set it at 2.2 and 1.6(on the side that rubs the cab mount).
    Now the questions:
    Would the caster correct both issues? or...
    Should I crank the coilover up a little more and hope that corrects the rub?
    Thanks so much-
    cluck
  2. Nov 22, 2010 at 5:18 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    you will need to get a cab chop or a realignment. The lowest I have gone without rubbing the cab mount with 285s was 2.6
  3. Nov 22, 2010 at 5:22 PM
    cluck024
    Robert
    Greenwood, Arkansas
    2.6 caster?? I can take it back to the alignment guy for free if Im not happy so... the side with 2.2 caster isnt rubbing the cab mount.
  4. Nov 22, 2010 at 5:25 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    How did you set up your LR arms? Same on both sides? Did the tech use those to align or just the factory lower control arm cams? I would want to see your caster closer in spec from side to side. And the toe should be toed-in just a hair.
  5. Nov 22, 2010 at 5:29 PM
    cluck024
    Robert
    Greenwood, Arkansas
    Ok, toed in meaning closer to zero? And should this alleviate the rub if the caster is closer. He gave me some reason that he left it that way to keep it from pulling to the right?? Sounds funny to me, like he cant get it right.
  6. Nov 22, 2010 at 5:32 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    A lot of shops will set the caster a bit lower on the driver side to make up for road crown. But the difference you have is too much, I think. Ideally for tire wear, you want both camber and toe to be as close to 0 as possible. If the toe is set in just a tad though, it will help the vehicle drive nicer, with less wandering or grabbing issues.
  7. Nov 22, 2010 at 5:35 PM
    cluck024
    Robert
    Greenwood, Arkansas
    ok, so like 0.1 on toe and camber and then maybe 2.2? on caster both sides or 2.4 and 2.2? give me the numbers you would want!! LOL
  8. Nov 22, 2010 at 6:55 PM
    cluck024
    Robert
    Greenwood, Arkansas
  9. Nov 22, 2010 at 9:02 PM
    ktmrider
    Junk
    numbers i want
  10. Nov 23, 2010 at 8:41 AM
    sooner02r1
    sooner02r1 Well-Known Member
    Sounds like the alignment is crap. Also what tires and wheel offset are you running? Could be an offset issue, I'm running 285s on 2.5" lift with no rubbing.
  11. Nov 23, 2010 at 2:33 PM
    cluck024
    Robert
    Greenwood, Arkansas
    285/70/17 on -12 offset with 4.5 backspace. Got the alignment worked on today. Got the toe down to 0.1 and camber to 0.1, with caster of 2.1 and 2.2. Helped a ton with the cab mount but still catches slightly. Drives really good with a slight pull to right but no walking. Will have a little more trimming with plastic and cab mount mod to do, but its ok to drive til I have time to fix the cab mount.
    Does it sound like im better off now??
  12. Nov 24, 2010 at 10:04 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    How do you like the RadFlo's? I cant wait to get mine! :)
    should be here next week sometime.
    Sorry about your alignment/rubbing issues, I know it can be a pain sometimes! hope I dont have that problem when the time comes....
  13. Nov 25, 2010 at 6:19 AM
    cluck024
    Robert
    Greenwood, Arkansas
    I absolutely love the ride with the radflos. I just have to get the alignment sorted out. What size tires you going with and what rim offset. thats why im rubbing!
  14. Nov 25, 2010 at 10:46 AM
    ETaco23
    Evan
    PNW
    Im ganna go with a 285, and wheels are 17x9 4.5" back spacing.
  15. Nov 25, 2010 at 1:48 PM
    cluck024
    Robert
    Greenwood, Arkansas
    well thats what I have and Im rubbing like crazy!! If it helps you I went right at 3 inches of lift. With these coilovers you could go up to 3.5 inches. It may be enough to allow the clearance needed, however your ride will be quite stiff. O and go a little under the max psi on those tires for a smoother ride.
  16. Nov 25, 2010 at 9:03 PM
    ETaco23
    Evan
    PNW
    Thats odd, bc a buddy here on TW just did a 2.5" lift with 285's and stock uca's and he isnt rub that much. isnt even near the body mount. huh....
