Calling on all 4x4 reg cabs!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yoytoda, Apr 2, 2012.
  1. Apr 2, 2012 at 11:44 AM
    Yoytoda
    Yoytoda [OP] The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    I am about 3 hours from my truck, having my driveshaft repaired. Problem is I forgot to measure flange to flange on the rear drive shaft.
    Is there a chance someone with a reg cab 4x4 can measure the total length of the drive shaft from flange to flange or how long the section of tube is.
    If measuring flange to flange it is important to measure on the same part of the front and rear flange.
  2. Apr 2, 2012 at 12:10 PM
    mdkingen
    mdkingen Hang on, I saw this done in a cartoon once!
    Las Vegas
    2012 Tacoma
    The tube on my 2012 reg. cab 4X4 is 34 3/8 from outside edge of weld to outside edge of weld. I claim no responsibility for your outcome.
  3. Apr 2, 2012 at 12:15 PM
    Yoytoda
    Roland
    completely stock
    Thanks, and that goes unspoken. I'd never hold someone responsible for the outcome.
  4. Apr 2, 2012 at 12:23 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    From my OME suspension install thread, where you can see how I took the measurement:
    http://www.tacomaworld.com/forum/su...talls-full-ome-kit-rear-brake-lines-pics.html
    Now, keeping in mind that it varies depending on how far you're lifted and how your axle is shimmed: I currently have 51&3/4" on top 51&13/16" on the bottom, outside-of-flange to outside-of-flange.
    That's with OME Dakar springs in back, shimmed to make the flanges as parallel as possible, favoring the bottom 1/16" longer than the top.
    It would be shorter at unlifted ride height, with the slip-yoke further inserted into the tube.
  5. Apr 2, 2012 at 12:25 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    So, don't leave us in suspense - what did you do that required your driveshaft to be in need of repair?
  6. Apr 2, 2012 at 1:30 PM
    Yoytoda
    Roland
    completely stock
    Awesome thanks!!!
  7. Apr 2, 2012 at 5:42 PM
    tacoandy
    tacoandy Member
    Andy
    bristol pa
    3" rev tek
    Ouch ...
  8. Apr 2, 2012 at 6:52 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Uh. I think its broken.
  9. Apr 2, 2012 at 9:27 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    What trail?
  10. Apr 2, 2012 at 9:31 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Duct tape and Popsicle sticks, baby!
  11. Apr 2, 2012 at 10:27 PM
    Yoytoda
    Roland
    completely stock
    Scuba! Whats up? You working at AP now?
    It was on a hill climb on the north side of mead lake bed in JV. Got off the trail into trouble quick lol. The ground is soft and shifty with it so dry. I had no steering backing down. It was either potentially flopping trying to turn around or back straight into hell.
