cam and nitrous question
Discussion in 'Performance and Tuning' started by tacoman316, Oct 2, 2008.
  1. Oct 2, 2008 at 12:54 PM
    tacoman316
    tacoman316 [OP] go big or go home
    Mobile AL
    08 SR5 Prerunner
    K&N drop in filter, Banks monster exhaust
    iv got a couple of questions. Does anybody out there make a performance camshaft for the 4.0 v6. and where can i get one. and also is anyone out there running nitrous and if so what system and how big of a shot I was wanting a safe maybe 40 or 50 shot. Would that hurt my engine and would it be safe setup.
  2. Oct 2, 2008 at 1:42 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Nitrous is never good you will be rebuilding your engine often. although its cheaper than a supercharger still wouldnt put that in my truck. As far as cams i will look around to see if there is one.
  3. Oct 2, 2008 at 1:59 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    I have really been thinking about this. Is there a hp gain?... Sorry if that is a stupid question
  4. Oct 2, 2008 at 2:02 PM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    isn't that the only reason to mess with the engine?
  5. Oct 2, 2008 at 2:02 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    In what the Cam yes and nitrous double yes but only when you hit the nitrous.
  6. Oct 2, 2008 at 2:03 PM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    With the right cam there is usually hp gain but also a different set of heads to go with it.
    as for the 4.0 i think cams is the more important word i do believe were are duel over head cams and that would be 4 cams to replace.
    Nitrous in the right amount and with the right spark plug you wont hurt anything there are some v8s been running it for years. now if you put like a 200 shot and run it at every stop light kiss that engine good bye.
    but you said a 40-50 shot shouldnt hurt but the only way i would run that is if i had a x-runner and went to the track a lot. just to much to get properlly set up just for fun.
  7. Oct 2, 2008 at 2:04 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    Camshaft... I was thinking about getting a new camshaft but I have heard it is very expensive. I am not a big fan of nitrous.
  8. Oct 3, 2008 at 6:37 AM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    As of right now there is no aftermarket camshafts available for the 1GR. A new set of cams would open up quite a bit of power in these trucks. The heads flow more then fine to support cams with a slightly longer duration.
    I believe the stock duration on our cams is around 160-ish.. A 210* would be KILLER, and would be fine for our stock heads.
    As far as nitrous is concerned, as long as you set it up correctly, and have it tuned responsible with a good fuel management tool, it is perfectly safe. The issue with nitrous is too many people have ran it carelessly and have destroyed their vehicles.
  9. Nov 9, 2008 at 7:53 PM
    notbrigum
    notbrigum Well-Known Member
    Chandler AZ
    08 double cab 4x4
    TRD intake, Magnaflow exhaust, billet grille, tube steps
    Agreed, done properly, it's a gas! I have it on my Supra. Just 50hp. Nothing close to stupid. It's only on WOT. Supposedly.. any motor should be capable of taking bursts of no more than 50% of its rated max. A 50hp shot on my Supra is 20-25% max. Very safe. A few years and no probs. You should have an intake and exhaust done too. These V6s are what, ~230hp? A 40-50 hp shot should be fine. Not a hard install at all. The trickiest part is tapping into the fuel line safely and in a location that makes good sense.
    Agreed, done wrong and kiss your motor goodbye.
  10. Nov 9, 2008 at 8:32 PM
    311offroad
    311offroad Stock Taco For Now
    Milledgeville, GA
    2005 TRD OffRoad SR5 4x4 Short Bed Debadged
    20% tint, Debadged, Pioneer AVIC-Z110BT, Infinity component door speakers, MagLite mod
    If tuned correctly... nitrous will NOT hurt your motor. Know alot of guys that spray large shots with a nitrous tune. No problems with motors.... a few tranny problems tho haha.
  11. Nov 10, 2008 at 4:02 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    NOS is good. when does safe and right...
    40 to 50 shop with the right heat range spark plugs is great.
    going 75 to 100 things get iffy.. but can be done if you can add the right amount of extra fuel and a good knock sencer...
    Just find a good tuner shop to help. 1 with results and a good client base...
  12. Nov 18, 2008 at 7:09 PM
    notbrigum
    Chandler AZ
    08 double cab 4x4
    OK, in the last few days I've discoverd (what most may have known, but hey, I've had my truck for ~6 weeks) that these things have a fly by wire throttle. Regarding the addition of nitrous, the EASY way to turn it on is to use a micro switch on the throttle linkage so that under WOT the switch is closed and the solenoids are turned on. With this fly by wire throttle, how do you get a WOT signal? There must be some REASONABLE way of getting it or can it only be done these days by using some kind of piggyback computer system? Just seems like a huge waste, to design a computer to detect WOT. Comments?
  13. Nov 19, 2008 at 11:43 AM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    you know if anyone has ported out the heads on these engines?>
  14. Nov 19, 2008 at 6:45 PM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Stock heads flow well enough where it hasn't been needed. And I now retract my prev statement about the cams... they are now available.
    Brand new!! http://www.xr-underground.com/forum/showthread.php?t=20546
