Cam bolts maxed out. Can't get the camber right. What could be the issue?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AbdullaJaafari, Jul 8, 2021.
  1. Jul 8, 2021 at 12:48 PM
    AbdullaJaafari
    AbdullaJaafari [OP] Dubai Taco
    Abdulla
    Dubai, UAE
    2018 Tacoma TRD Off-road
    So I got my car on the alignment machine today just to dial it in as it's a second hand buy.
    I did the toe angle right but my left front camber is still off and the cam bolts are maxed out and I can't get it to camber in any more.
    I visually can't seem to find any damage on the upper or lower control arms. Are the knuckles/spindles weak that they can bend and cause such an issue?
    On another note, I do have a clunking/squeaking sound at speed bumps from the front left.
  2. Jul 8, 2021 at 12:59 PM
    eurowner
    eurowner Duke Sky
    Scoty
    What suspension mods do you have?
  3. Jul 8, 2021 at 1:47 PM
    AbdullaJaafari
    Abdulla
    Dubai, UAE
    Absolutely none.
    Just 265/75r16 tires
  4. Jul 8, 2021 at 1:49 PM
    naked farmer
    naked farmer Well-Known Member
    Nor Cal
    ‘17 B.Red Off Road
    Spindles can bend. That’s a reason for welding gussets on them.
  5. Jul 8, 2021 at 1:51 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    What is the order of the adjustments that you are doing?
    Camber, Caster, Toe
    Toe, Camber, Caster
    Caster, Toe, Camber
    You may want to take it to a shop with alignment equipment, skill and experience.
    Hobbs likes this.
  6. Jul 8, 2021 at 2:08 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Maybe try a shake down of your front end to make sure everything is tight. Ball joints ,bearings all that good stuff.
  7. Jul 8, 2021 at 2:22 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Cars are cars, trucks are trucks. If you're aligning a Tacoma, you are not working on a car.
    Tac0Tic0 likes this.
  8. Jul 8, 2021 at 2:24 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    The machine thinks its aligning a vehicle with 245 tires....
    Tac0Tic0, Jojee117 and MalinoisDad like this.
  9. Jul 8, 2021 at 2:27 PM
    Clearwater Bill
    Billy
    Largo Florida
    Why would that matter? The hubs are what's being aligned, not the wheels/tires. They are just along for the ride. (so to speak)
    whatstcp and H6G like this.
  10. Jul 8, 2021 at 2:28 PM
    Dayman Karate
    Dayman Karate Ruffling feathers and turning eagles into vultures
    Clay
    Central Alabama
    2001 4Runner, JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Dang, that’s a lot of tires for one truck.
  11. Jul 8, 2021 at 2:29 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I'm pretty sure if you have that much castor you still have room to pull it back to get the camber correct.
  12. Jul 8, 2021 at 2:33 PM
    Clearwater Bill
    Billy
    Largo Florida
    If you're working on a fully adjustable double wishbone coil-over shock IFS, what difference does it make what type vehicle it's on? I mean that's what a Tacoma is.
    jerkwithkeyboard, stu8319 and H6G like this.
  13. Jul 8, 2021 at 2:44 PM
    MalinoisDad
    Michael
    Are 18 wheelers cars too? Are jet skis boats because they go on the water...? Call your truck a car if you want, seems silly to me.
  14. Jul 8, 2021 at 2:48 PM
    Clearwater Bill
    Billy
    Largo Florida
    You must make an amazing fruit salad! Mixing apples, oranges, grapes, bananas, etc.
    whatstcp and stu8319 like this.
  15. Jul 8, 2021 at 2:51 PM
    $yoda$
    Tom
    2007 Tacoma 4.0
    18 wheelers are tractors. Jet skis and boats are all watercraft. Tacoma’s are 4x4 cars with a bed. F-150 or bigger is a truck.
  16. Jul 8, 2021 at 2:57 PM
    Reh5108
    Idaho
    Jet ski is a boat.
    A Ridgeline is a car. Tacoma has body on frame making it a truck.
  17. Jul 8, 2021 at 3:00 PM
    angerbot
    angerbot Well-Known Member
    Congratulations on contributing absolutely nothing but a massive derail to the thread. Fucking tacomaworld, honestly.
    OP: If the truck has been offroaded or hit a curb or something in the past it could be the spindle, they're pretty easy to bend if hit wrong which is why spindle gussets are so common on trucks that get wheeled a lot. Could be a mall injury as well, especially if you're getting clunking over speed bumps on that side. I'd take it to another shop and see if they can get it in case you're missing something before chasing that though.
    RH007, japjoe7, stu8319 and 4 others like this.
  18. Jul 8, 2021 at 3:00 PM
    $yoda$
    Tom
    2007 Tacoma 4.0
    I don’t know man I think they are more like Japanese El Camino‘s accept the El Camino came with a v8
  19. Jul 8, 2021 at 3:01 PM
    kpinthebay
    kpinthebay Well-Known Member
    Hawaii ==>>SF Bay Area
    I get reamed Everytime I call my 4Runner a truck.
    parel likes this.
  20. Jul 8, 2021 at 3:41 PM
    shaggy666
    shaggy666 Active Member
    Scott
    2021 Taco 4-dr
    none, yet
    Alignment guys get lazy. Check tire pressure all around. If they are in spec, then I’d look for worn and/or damaged parts. Any slop in the front end can contribute. When was the last time the alignment machine was calibrated. Should be yearly, yet many are never calibrated until they are forced to get a software update and the “Hunter” guy (or whatever company) has to make a visit anyways. Alignment racks that are not level can do wonky things, not usually camber, but...
