Cam bolts on a 5-lug?
Discussion in 'Suspension' started by LordWard, Jan 8, 2025.
  1. Jan 8, 2025 at 12:37 PM
    LordWard
    LordWard [OP] New Member
    2015 Black 2wd Extended Cab Tacoma
    Hello everyone, for various reasons I had to remove my right lower control arm on my base 2015 5-lug, and upon further inspection my Cam bolts don't look to hot. Instead of throwing the old ones back in, I decided to do some digging and look for 5-lug Cam bolts. This is somewhat of a nuisance however because upon further inspection, they appear to differ from the Cam bolts for the 6-lug Tacoma's. Is there a part number out there for the part that I'm looking for? It's hard to sift through the information on the internet because the vast majority of it is about 6-lugs, so when I look for the part number I get 6-lug part numbers.
    Thanks a lot!
  2. Mar 24, 2025 at 5:54 PM
    singlecabmob
    singlecabmob New Member
    2013 Single Cab Tacoma 2wd
    Currently stuck with the same issue I over torqued my cam bolt and lm looking for a replacement but haven’t found anything.
  3. Mar 24, 2025 at 7:19 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    I don't have a model code offhand for a 5-lug (it'll be on your door VIN sticker/identification plate), but I would expect you'd be able to find them here (you'll need to input your model code to narrow it down):
    https://www.toyotapartsdeal.com/par..._chassis/front_axle_arm_steering_knuckle.html
    Edit:
    I put in TRN220L-TRMDKA and am seeing 5-lug brakes & hubs, along with the cam bolt parts, so looks like these would be them:
    48190-25010 = Cam bolt
    48198-25010 = Cam plate
    90178-A0013 = Nut
    (maybe someone can double-check those though)
    singlecabmob likes this.
  4. Apr 1, 2025 at 6:47 PM
    singlecabmob
    Thank you so much!!! I found the part I needed and ordered it! Quick last question I am new to this site and curious about the website and if their parts are OEM? I need a new catalytic converter and thinking about buying one from this site.
  5. Apr 2, 2025 at 11:05 AM
    4x4junkie
    So Calif. (SFV)
    I believe that site is all OEM parts, yes.
    I haven't ordered anything from there yet myself, but in the event I do need something that is OEM, it is 1st on my list of sources (their prices seem better than what is typical at a dealership).
  6. Apr 3, 2025 at 6:16 PM
    singlecabmob
    Thank you man, I’ve been using Autozone parts just to get by since the cost of oem is ridiculously high in my area atleast, but last week I ordered the cam bolt and just received it today! Quality is there and everything is labeled OEM from Toyota so I would 10/10 recommend the parts from their website, definitely going to order more parts and in the future! Thanks once again man for the help!
    Steves104x4 likes this.
  7. Apr 3, 2025 at 6:29 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    What a beautiful little truck you’ve got there. Moar pics!
