Cam Cap Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2cupscornstarch, Nov 16, 2020.
  1. Nov 16, 2020 at 3:49 PM
    2cupscornstarch
    2cupscornstarch [OP] New Member
    2003 Tacoma TRD v6
    There was an incident at a mechanic where they cracked 2 cylinders and ended up replacing the head and the cylinders, when they did this they forgot to put the cam cap on and I took it to another mechanic. The mechanic insists that they cant find a replacement one to order, that it would only come with a head, and that each cap is specifically milled for the engine head so I would need to get a new head as well. Can someone help me out? I have a feeling im getting taken for a ride here, and I've already had to deal with some pretty ridiculous things with this truck. Its a 2003 TRD with the 5VZ-FE.
  2. Nov 16, 2020 at 5:01 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Pretty sure they're not lying about needing a new head. On mine each was stamped with its location. Maybe @Speedytech7 or @Empty_Lord can pop in here and confirm.
    Speedytech7 likes this.
  3. Nov 16, 2020 at 5:08 PM
    billygoat
    billygoat Well-Known Member
    American Southwest
    08 TRD Offroad 4x4
    6” Fabtech Lift, 35’s, lots o’ goodies
    Did the first shop put everything back together? If so, then forgetting to put a cam cap on is an unforgivable fuckup. That’s major. So is cracking two cylinders though...
    The machinist is correct about the cap being milled specifically for the head (and that particular location on it too). You might be able to find a machinist to resize the bearing journal/cap if you get one from a junkyard, but there’s no guarantee it’ll work. You probably are looking at getting a new head.
  4. Nov 16, 2020 at 5:10 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Cam caps are a machined set, the cam journals are line bored, you put another cap from a random head on and you'll have a journal that's the wrong size and possibly on the wrong datum. You need a new head
  5. Nov 16, 2020 at 6:01 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Yea if the cam caps were misplaced and accidentally put on the wrong head, it’s a new head.
  6. Nov 16, 2020 at 7:13 PM
    2cupscornstarch
    2003 Tacoma TRD v6
    I'm trying to sell this thing, is there any way to avoid paying for a whole new head and everything? I mean I could try to make the other mechanic pay for it.
  7. Nov 16, 2020 at 7:48 PM
    Speedytech7
    Try to make the other mechanic fix it, otherwise you're up shit creek and the price of a paddle is a new head and associated labor.
