Cam position sensor 95 3.4 liter
Discussion in '1st Gen. Tacomas (1995-2004)' started by Crazyak17, Jul 21, 2018.
  1. Jul 21, 2018 at 11:29 PM
    Crazyak17
    Crazyak17 [OP] Member
    Nol
    Colorado
    95 Tacoma 4x4 xtcab
    3 inch leveling kit.
    Swapped out the throttle position sensor and now I have a code for cam position sensor and engine is running rough. Changed out cam position sensor still running rough and throwing a code. Have traced back wires to harness and no visible damage. Anyone have this issue or ideas i can try
  2. Jul 22, 2018 at 12:02 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    What code #?
  3. Jul 22, 2018 at 12:03 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Why did you change TPS sensor to start with?
  4. Jul 22, 2018 at 4:50 PM
    Crazyak17
    Nol
    Colorado
    95 Tacoma 4x4 xtcab
    Code is P0340
    Changed the TPS sensor because is has been shifting hard. And higher than normal idle. It fixed that issue. Shifts better and idle is better. Now I have the P0340 code and says bad camshaft sensor and now runs rough.
  5. Jul 22, 2018 at 5:11 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Your cam sensor is in your distributor correct? Check the bushing in dist for wear. See if shaft has any side to side play.
  6. Jul 23, 2018 at 4:55 PM
    Crazyak17
    Nol
    Colorado
    95 Tacoma 4x4 xtcab
    No the cam position sensor is in the front with the timing belt. Its electronic ignition system.
